Home » Eclipse Projects » Eclipse 4 » Declaring parts being based on PartDescriptors in E4XMI
Declaring parts being based on PartDescriptors in E4XMI [message #926051] Fri, 28 September 2012 09:01 Go to next message
Ralph Schuster is currently offline Ralph SchusterFriend
I have an application that needs to open three instances of the same part when starting up. I described the PartDescriptor but I can't get the parts being instantiated when the application comes up.
1) Is it possible to reference the part descriptor in the part description within e4xmi file? If so, how?
2) If not, at what stage I can use partService.create(descriptorId) to programmatically create the parts? I wasn't able to find a hook in the lifecycle where this is possible. Usually it throws an application saying that the application doesn't have any active window yet, e.g.
java.lang.IllegalStateException: Application does not have an active window
	at org.eclipse.e4.ui.internal.workbench.ApplicationPartServiceImpl.getActiveWindowService(ApplicationPartServiceImpl.java:36)
	at org.eclipse.e4.ui.internal.workbench.ApplicationPartServiceImpl.createPart(ApplicationPartServiceImpl.java:95)
	at myapp.rcp.ui.model.ApplicationLifecycleHook.addPart(ApplicationLifecycleHook.java:143)
	at myapp.rcp.ui.model.ApplicationLifecycleHook.configurePerspective(ApplicationLifecycleHook.java:109)
	at myapp.rcp.ui.model.ApplicationLifecycleHook.elementVisible(ApplicationLifecycleHook.java:78)
Re: Declaring parts being based on PartDescriptors in E4XMI [message #928581 is a reply to message #926051] Sun, 30 September 2012 19:37 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot CelaFriend
1) No
2) The exception happens because the construction happens too early (even before the window is created). You can listen for the window activation event like described in http://www.eclipse.org/forums/index.php/mv/msg/383895/922990/#msg_922990 or you can also listen for the window-bringToTop event (explore the UIEvents interface for more possibilities)
Re: Declaring parts being based on PartDescriptors in E4XMI [message #928934 is a reply to message #926051] Mon, 01 October 2012 04:43 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Why not directly adding the them in the base model when they should show
up in the initial state?
Tom
Am 28.09.12 02:01, schrieb Ralph Schuster:
> at
> at
> at
> at
> at
Re: Declaring parts being based on PartDescriptors in E4XMI [message #928977 is a reply to message #928934] Mon, 01 October 2012 05:41 Go to previous messageGo to next message
Hi Tom,
because the parts will have menus and toolbars that all need then be repeated, and I still would need the part descriptor to open a new instance dynamically.
Of course this could be done in e4XMI, but the duplication of definition doesn't seem right at all to me.
Re: Declaring parts being based on PartDescriptors in E4XMI [message #929776 is a reply to message #928581] Mon, 01 October 2012 19:07 Go to previous messageGo to next message
Hi Sopot,
I tried subscribe to all Window events (TOPIC_ALL) but none of them arrived. No BRINGTOFRONT, ACTIVATE or any other. Occasionally I see HEIGHT and WIDTH events in the startup.
Ralph
Re: Declaring parts being based on PartDescriptors in E4XMI [message #929842 is a reply to message #928977] Mon, 01 October 2012 20:31 Go to previous message
Ok - that's what snippets are good for! Add your template there and add
a processor which clones the snippet to your final destination (IIRC the
model service has support for that) ;-)
Tom
Am 30.09.12 22:41, schrieb Ralph Schuster:
> Hi Tom,
Previous Topic:.e4css Folder
Next Topic:Quick Context View from Navigate Menu
Current Time: Fri Feb 28 23:03:31 GMT 2020
Powered by FUDForum. Page generated in 0.02284 seconds
