Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Can't persist reference when EOpposite is set.
Re: [Teneo] Can't persist reference when EOpposite is set. [message #125681 is a reply to message #125636] |
Wed, 11 June 2008 06:21 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi François,
A special issue for sure. I will probably have time tomorrow to look at this in more detail.
gr. Martin
François M. wrote:
> Hi Martin,
> I was able to reproduce it. The problem is caused by the order in which
> the EClass are declared in the genmodel.
> In the test case I attached:
> Person has 1 Team
> Team has 0 to Many Person.
> Person eOpposite is team.members.
> Team eOpposite is Person.team
> In the model description, if Person is declared before Team. The column
> "person_team_e_id" from the "person" table is correctly set to an id
> from the team.members table.
> The problem rise when Team is declared before Person. In this case the
> column "person_team_e_id" from "person" table is always set to null.
> This cause the person.getTeam() call to always return null.
> To go from a working to failing state, simply change the order of the 2
> EClass and restart the application.
> Is there anyway to fix that issue without changing the order of the
> EClass, it maybe impossible to do for me because my EClasses are from
> different package.
> François
> François M. wrote:
>> I am using emf 2.4 (dynamic efeatures) and teneo 0.8.0RC1A. We have
>> this issue where the relation between 2 object is not persisted when
>> both object`s reference to each other has their EOpposite set to each
>> other.
>> ex:
>> A Book.author is referring [1] to an Author, with EOpposite set to
>> Author.book
>> An Author is referring [1 to *] to Book, and with an EOpposite set to
>> Book.author
>> When I set the author of the book, then persist the book (and author
>> through cascading) and commit, the author and the book are persisted
>> but the relation between the twos is not.
>> Any idea why from this brief description?
>> If not, I will try to provide a sample.
>> Regards
>> François
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Can't persist reference when EOpposite is set. [message #125960 is a reply to message #125636] |
Sat, 14 June 2008 22:23 |
Hi François,
I tried your testcase but I could not reproduce the exception. Maybe I misunderstood you, I
exchanged the order of Team and Person several times in the ecore file. Each time I started with an
empty database and all the time the test passed.
Can you try again?
gr. Martin
François M. wrote:
> Hi Martin,
> Person has 1 Team
> different package.
> François
> François M. wrote:
>> other.
>> ex:
>> Author.book
>> Book.author
>> Regards
>> François
The Netherlands
Re: [Teneo] Can't persist reference when EOpposite is set. [message #125973 is a reply to message #125960] |
Mon, 16 June 2008 12:35 |
Francois Messages: 17 Registered: July 2009 |
Junior Member |
I confirm that I get the issue.
After I move the declaration of Team before the declaration of Person in
the ecore, I save the ecore, and reload the genmodel from the ecore,
then I "Generate the model code". I run the same test case and my
person_team_e_id is set to NULL.
When Person is defined first:
mysql> select * from person;
| e_id | dtype | e_version | name | section | person_team_e_id |
| 1 | Person | 0 | LaPoune | NULL | 1 |
1 row in set (0.00 sec)
When Team is defined first:
| 1 | Person | 0 | LaPoune | NULL | NULL |
Martin Taal wrote:
> Hi François,
> misunderstood you, I exchanged the order of Team and Person several
> times in the ecore file. Each time I started with an empty database and
> Can you try again?
> gr. Martin
> François M. wrote:
>> Hi Martin,
>> which the EClass are declared in the genmodel.
>> Person has 1 Team
>> column "person_team_e_id" from the "person" table is correctly set to
>> an id from the team.members table.
>> 2 EClass and restart the application.
>> different package.
>> François
>> François M. wrote:
>>> Hi,
>>> other.
>>> ex:
>>> Author.book
>>> Book.author
>>> Regards
>>> François
Re: [Teneo] Can't persist reference when EOpposite is set. [message #126003 is a reply to message #125960] |
Mon, 16 June 2008 12:57 |
Originally posted by: stapounch.hotmail.com
--------------050900090501070003080605
Hi Martin,
When the code runs, no errors are generated. But...
What I did to reproduce the problem, was simply to change the order,
declare Team before Person, reload the genmodel, regenerate the model
code, run my test case and voil
Re: [Teneo] Can't persist reference when EOpposite is set. [message #126017 is a reply to message #126003] |
Mon, 16 June 2008 21:25 |
Hi Luc/Francois,
Yes, I should have looked in the db with your previous testcase...
Using your last testcase I could re-produce this. It showed that bidirectional lists with jointables
do not work well in all cases. In addition Hibernate does not support bi-directional lists.
Therefore Teneo maps them as two independent relations: one-to-many with a join-table and
many-to-one (with a fk) for the other side.
I made some changes in the code to handle this better. This will be in a new build.
As a workaround (for now) you can set a @OneToMany(indexed=false) on the members efeature. Let me
know if this works.
Btw, as Teneo is graduating to 1.0.0 it will move to the main EMF newsgroup. I have cross-posted
there so we can continue the thread there.
gr. Martin
Luc wrote:
> Hi Martin,
> code, run my test case and voilà, the "person_team_e_id" is gone, see
> below (with attached softball.ecore.bad):
> mysql> select e_id, dtype, person_team_e_id from person;
> | e_id | dtype | person_team_e_id |
> | 1 | Person | NULL |
> mysql> select e_id, dtype from team;
> | e_id | dtype |
> | 1 | Team |
> Yet when I declare Person before Team, reload the genmodel, regenerate
> the model code, run my test case, the "person_team_e_id" is set to 1,
> see below (with attached softball.ecore.good):
> | 1 | Person | 1 |
> | e_id | dtype |
> | 1 | Team |
> Thanks for your help!
> Luc
> Martin Taal wrote:
>> Hi François,
>> Can you try again?
>> gr. Martin
>> François M. wrote:
>>> Hi Martin,
>>> Person has 1 Team
>>> the column "person_team_e_id" from "person" table is always set to
>>> null. This cause the person.getTeam() call to always return null.
>>> different package.
>>> François
>>> François M. wrote:
>>>> Hi,
>>>> each other.
>>>> ex:
>>>> Author.book
>>>> to Book.author
>>>> Regards
>>>> François
The Netherlands
Re: [Teneo] Can't persist reference when EOpposite is set. [message #619232 is a reply to message #125636] |
Hi François,
gr. Martin
François M. wrote:
> Hi Martin,
> Person has 1 Team
> different package.
> François
> François M. wrote:
>> other.
>> ex:
>> Author.book
>> Book.author
>> Regards
>> François
The Netherlands
Re: [Teneo] Can't persist reference when EOpposite is set. [message #619253 is a reply to message #125636] |
Hi François,
Can you try again?
gr. Martin
François M. wrote:
> Hi Martin,
> Person has 1 Team
> different package.
> François
> François M. wrote:
>> other.
>> ex:
>> Author.book
>> Book.author
>> Regards
>> François
The Netherlands
Re: [Teneo] Can't persist reference when EOpposite is set. [message #619254 is a reply to message #125960] |
Junior Member |
Martin Taal wrote:
> Hi François,
> Can you try again?
> gr. Martin
> François M. wrote:
>> Hi Martin,
>> Person has 1 Team
>> different package.
>> François
>> François M. wrote:
>>> Hi,
>>> other.
>>> ex:
>>> Author.book
>>> Book.author
>>> Regards
>>> François
Re: [Teneo] Can't persist reference when EOpposite is set. [message #619257 is a reply to message #126003] |
Hi Luc/Francois,
know if this works.
gr. Martin
Luc wrote:
> Hi Martin,
> | 1 | Person | NULL |
> | e_id | dtype |
> | 1 | Team |
> | 1 | Person | 1 |
> | e_id | dtype |
> | 1 | Team |
> Luc
> Martin Taal wrote:
>> Hi François,
>> Can you try again?
>> gr. Martin
>> François M. wrote:
>>> Hi Martin,
>>> Person has 1 Team
>>> different package.
>>> François
>>> François M. wrote:
>>>> Hi,
>>>> each other.
>>>> ex:
>>>> Author.book
>>>> to Book.author
>>>> Regards
>>>> François
The Netherlands
Current Time: Thu Apr 25 14:00:12 GMT 2024
Powered by FUDForum. Page generated in 0.04046 seconds
