Verification hook problem [message #125255] |
Tue, 04 March 2008 12:10 |
Originally posted by: gopi_tptp.yahoo.com
hi,
i am using tptp to execute testcases.
after runnig the test cases i had inserted hook point in order to validate
the test case.
in most cases the test cases are executed properly, but some times the
hook doesn't get executed.
it gives the following message
Failed to locate the context view/com.ca.harvest.ui.explorerView required
by the verification point testco39:Qorg.eclipse.ui.IViewPart;
i think this is a memory related problem,because this problem comes not
often.
what are the main causes for this problem????
thanks,
gopi
Re: Verification hook problem [message #125339 is a reply to message #125268] |
Wed, 05 March 2008 04:50 |
Hi Jimmy,
i am using
TPTP: tptp.runtime.allInOne.win32.win32.x86-TPTP-4.4.0.3(4.4.0.3 version)
AGR: org.eclipse.tptp.test.auto-TPTP-4.4.0.3.zip(4.4.0.3 version)
Eclipse Version: 3.3.1
gopi
Re: Verification hook problem [message #125885 is a reply to message #125859] |
Mon, 10 March 2008 12:41 |
hi paul,
the first alternate is present in the macro code itself i.e while
recording the testcase by agr, wait macro is present(i maen recorded)
before verification hook and after the hook.
could you please tell the second alternate i.e using a custom widget
resolver to locate the view part.
thanks,
gopi
FUDForum. Page generated in 0.03579 seconds
