Home » Eclipse Projects » P2 » Tycho eclipse-repository not setting the +x bit inside the zip archive
Tycho eclipse-repository not setting the +x bit inside the zip archive [message #923075] Tue, 25 September 2012 15:25
Valerio Santinelli is currently offline Valerio SantinelliFriend
Member
I reported the following error: https://bugs.eclipse.org/bugs/show_bug.cgi?id=389829
Basically, when running maven+tycho on OS X, the eclipse-repository part of the build that creates the .app executable does set the +x bit on the executable, but during the archival process, that bit gets lost.
The end result is that if you unzip che OS X zip file and try to run the .app file, it does not run because of the missing executable bit.
Is there anyone who's got a workaround for that until someone takes care of fixing it in Tycho?
Thanks!
Previous Topic:How do we set Available Software Sites
Next Topic:p2.inf copy
Current Time: Sun Jan 26 20:19:36 GMT 2020
Powered by FUDForum. Page generated in 0.01641 seconds
