Re: Change Labels of PopupBar [message #11446 is a reply to message #11409] |
Wed, 22 April 2009 10:53 |
Originally posted by: atoulme.intalio.com
Verena wrote:
> I'm trying to change the labels of the popupbar - I'm not sure wether
> this is the correct name. I mean the kind-of-contextmenu-thing that
> appears after dragging a connection. I need to change the labels of the
> entries there - is there any chance to do that?
It's a PopupMenuCommand showing a list of IElementType for you to pick one.
You need to hack the ConnectionAndEndLabelProviderEx in the
PromptForConnectionAndEndCommandEx class that is used in the
PromptForConnectionAndEndCommandEx edit policy.
Best to extend ContainerNodeEditPolicyEx, override
getPromptForConnectionAndEndCommand and return there your own command
with your hacked label provider.
> In the same context I need to change the ToolTips of the other "Tool"
> that provides the graphical views of the available elementtypes (I also
> do not know a name for that) and appears on CTRL+Space.
That's named the popup bar. You need to override PopupBarEditPolicyEx
and look at the populatePopupBars method.
Antoine
Re: Change Labels of PopupBar [message #11520 is a reply to message #11483] |
Wed, 22 April 2009 21:32 |
Do a Ctrl+Shift+G on ContainerNodeEditPolicyEx to see where it is used:
in the edit parts when they create their edit policies. Same for
PopupBarEditPolicyEx.
That's where you hook them up.
Antoine
Verena wrote:
> Antoine Toulme wrote:
>> Verena wrote:
>>> Hi,
>> one.
> I tried that, but it is never called. Do I need to 'register' that
> somewhere?
> This one goes the same - never called. I'd probably have to do something
> to tell the 'Framework' that this one should be used, but I have no idea
> where.
> Thanks gaain for your help.
FUDForum. Page generated in 0.02822 seconds
