Home » Archived » Visual Editor (VE) » Manually add swt.jar will make SWT controls invisible
Manually add swt.jar will make SWT controls invisible [message #124671] Fri, 12 May 2006 12:26 Go to next message
Originally posted by: javacard.hotmail.com
Creat a new project,then open project properties->java Build Path->Libraries tab page.If add swt.jar via 'Add JARs' or 'Add External JARs',the SWT controls would NOT be parsed correctly,which means invisible in the VE editor.If add swt.jar via 'Add Library'->SWT,then it works fine.
It only takes some inconvienence for me,not so serious a bug.
Xu Song
Re: Manually add swt.jar will make SWT controls invisible [message #124685 is a reply to message #124671] Fri, 12 May 2006 13:02 Go to previous messageGo to next message
You mustn't add SWT.jar itself. You need to use the SWT Library
Container. That is how it works.
> Xu Song
Rich Kulp
Re: Manually add swt.jar will make SWT controls invisible [message #124745 is a reply to message #124685] Fri, 12 May 2006 20:58 Go to previous messageGo to next message
Thank you for the prompt answer.Could you give me more comments on the 'Library Container'?A link is also helpful.But if it's a complex concept, just forget it.
XS
Re: Manually add swt.jar will make SWT controls invisible [message #124833 is a reply to message #124745] Mon, 15 May 2006 06:27 Go to previous message
Originally posted by: liouxiao.gmail.com
Right click on your porject, select "Build Path" -> "Configure Build Path"
in the popup menu, then, in "Java Build Path" dialog you'd select
"Libaraies" tab, and click "Add Library" button, afterward you'd select
"Standard Widget Toolkit (SWT)" libaray.
"song.xu" <javacard@hotmail.com> ????
news:33091737.1147481932495.JavaMail.root@cp1.javalobby.org...
just forget it.
> XS
Re: Manually add swt.jar will make SWT controls invisible [message #612880 is a reply to message #124671] Fri, 12 May 2006 13:02 Go to previous message
> Xu Song
Rich Kulp
Re: Manually add swt.jar will make SWT controls invisible [message #612893 is a reply to message #124685] Fri, 12 May 2006 20:58 Go to previous message
XS
Re: Manually add swt.jar will make SWT controls invisible [message #612904 is a reply to message #124745] Mon, 15 May 2006 06:27 Go to previous message
just forget it.
> XS
Previous Topic:Manually add swt.jar will make SWT controls invisible
Next Topic:Subtle problem with expression 'BorderFactory.createTitledBorder(BorderFactory.createEtchedBorder(),
Current Time: Mon Jul 07 23:26:50 EDT 2025
Powered by FUDForum. Page generated in 0.06565 seconds
