Profiles: Properties of Type String [message #921946] |
Mon, 24 September 2012 15:27 |
Simon Schwichtenberg Messages: 127 Registered: September 2011 |
I've created a profile and added a property "expression" to a stereotype and set its type to String (from UML Primitives), its multiplicity to 0..1 and its default value to a StringLiteral (emptyString="").
When I run the Eclipse Application, apply the stereotype to the respective element and open the stereotype definition in the properties view (profile tab) I get the error:
Quote:java.lang.IllegalArgumentException: expression
at org.eclipse.uml2.uml.internal.operations.ElementOperations.getValue(ElementOperations.java:566)
at org.eclipse.uml2.uml.internal.impl.ElementImpl.getValue(ElementImpl.java:296)
at org.eclipse.papyrus.uml.profile.tree.objects.AppliedStereotypePropertyTreeObject.getValue(AppliedStereotypePropertyTreeObject.java:120)
at org.eclipse.papyrus.uml.profile.tree.ProfileElementLabelProvider.getText(ProfileElementLabelProvider.java:127)
at org.eclipse.jface.viewers.WrappedViewerLabelProvider.getText(WrappedViewerLabelProvider.java:108)
at org.eclipse.jface.viewers.WrappedViewerLabelProvider.update(WrappedViewerLabelProvider.java:164)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn.java:152)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(AbstractTreeViewer.java:953)
at org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeRunnable.run(AbstractTreeViewer.java:113)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(AbstractTreeViewer.java:1033)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRunnable.run(StructuredViewer.java:485)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(StructuredViewer.java:2167)
at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem(AbstractTreeViewer.java:848)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:823)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:797)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:644)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:768)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpand(AbstractTreeViewer.java:1500)
at org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeViewer.java:952)
at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded(AbstractTreeViewer.java:1511)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:132)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7565)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:5534)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:1896)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:5086)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4584)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2440)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1534)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:6435)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4564)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5958)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2546)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3756)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
What's wrong here?
Edit: I registered the profile with the extension point "org.eclipse.papyrus.uml.extensionpoints.UMLProfile"
Edit2: The profile seems to be broken. I've created a minimal example which contains only one Stereotype with only one boolean attribute. Then, I can simply set the value of the property.
[Updated on: Mon, 24 September 2012 17:45] Report message to a moderator
FUDForum. Page generated in 0.02662 seconds
