Dynamically extend parts of the grammar [message #921587] |
Mon, 24 September 2012 08:45 |
Gaspar Din Messages: 21 Registered: September 2012 |
Hi all,
supposing an xtext definition with the following snippet:
IntegerTerm:
IntegerLeaf | StringGetLength | FloatRound | ... |
IntegerTermExternal
IntegerTerm returns an int value.
IntegerLeaf is an int value like '0', '1', '2', ...
IntegerTermExternal is not yet known. It has to be generated from java classes.
For example:
At runtime I have a list of java functions (from a library) which will return an int value. Some of them will have parameters. They're collected via reflection api.
How do I have to specify IntegerTermExternal (in .xtext and in some(which?) java file) to support this java functions, e.g.:
java function:
Goal: Supported xtext definition :
IntegerTermExternal: Mult | ... ;
Mult: {Mult} "Mult" "(" int1=IntegerTerm "," int2=IntegerTerm ")";
The editor now should accept entries like
Mult (5, StringGetLength("abc"))
[Updated on: Tue, 25 September 2012 09:20] Report message to a moderator
Re: Dynamically extend parts of the grammar [message #923854 is a reply to message #923031] |
Wed, 26 September 2012 08:49 |
Hi Aaron,
okay, I've now written a ProposalProvider to introduce external function calls for the suggestion list.
I also had to wrote a Validator to only allow existing function calls.
Gaspar
Aaron Digulla wrote on Tue, 25 September 2012 10:49The grammar in Xtext is static because ANTLR doesn't support dynamic grammars, so you need a trick. In your grammar, use something like this:
IntFunctionCall: name=ID '(' ')'
You can offer the user a list of possible function names by creating your own ProposalProvider which examines the classpath via reflection.
When you "execute" the DSL, you will have to do the same: When you encounter a "IntFunctionCall" node, find the function via reflection and invoke it.
[Updated on: Wed, 26 September 2012 08:50] Report message to a moderator
FUDForum. Page generated in 0.02838 seconds
