Home » Language IDEs » Java Development Tools (JDT) » Ctrl+Shift+I shortcut to inspect: is it gone?
Re: Ctrl+Shift+I shortcut to inspect: is it gone? [message #922561 is a reply to message #922229] |
Tue, 25 September 2012 05:49 |
Mauro Molinari Messages: 285 Registered: July 2009 |
Il 24/09/2012 23:20, Stephan Herrmann ha scritto:
> I haven't seen this particular instance and for me this shortcut works
> fine in Juno.
> However, you might want to check your error log if there's any handler
> conflict or anything related to key bindings.
> You're definitely not the first person to see problems with shortcuts in
> Juno ...
You anticipated me, in fact I see this in my log:
eclipse.buildId=I20120608-1400
java.version=1.7.0
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=it_IT
Command-line arguments: -os win32 -ws win32 -arch x86_64 -debug -consoleLog
Warning
Mon Sep 24 11:33:05 CEST 2012
A conflict occurred for CTRL+SHIFT+I:
Binding(CTRL+SHIFT+I,
ParameterizedCommand(Command(org.eclipse.jdt.debug.ui.commands.Inspect,Inspect,
Inspect result of evaluating selected text,
Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Debug command
category,true),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.dialogAndWindow,,,system)
ParameterizedCommand(Command(org.eclipse.php.debug.ui.commands.Inspect,Inspect,
category,true),
,,true),null),
What I can't understand is what this shortcut is conflicting with... It
seems like it's conflicting with itself?
Mauro.
Current Time: Thu Apr 25 10:21:35 GMT 2024
Powered by FUDForum. Page generated in 0.03850 seconds
