Home » Modeling » M2T (model-to-text transformation) » Workflow configuration error - classes not found
Workflow configuration error - classes not found [message #921048] Sun, 23 September 2012 19:28 Go to next message
Yasser Khan is currently offline Yasser KhanFriend
What is wrong with my workflow definition :
<?xml version="1.0"?>
<workflow>
<!-- set up EMF for standalone execution -->
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" platformUri=".." />
<!-- prepare for performing uml -->
<bean class="org.eclipse.xtend.typesystem.uml2.Setup" standardUML2Setup="true" />
<!--UML2 Profile - Metamodell-->
<bean id="mm_profile" class="org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel">
<profile value="platform:/resource/xpand.uml2.generator/src/test.profile.uml"/>
</bean>
<!-- load model and store it in slot 'model' -->
<component class="org.eclipse.emf.mwe.utils.Reader">
<uri value="platform:/resource/xpand.uml2.generator/src/example-profiled.uml" />
<modelSlot value="model" />
</component>
<component id="generator" class="org.eclipse.xpand2.Generator" skipOnErrors="true">
<metaModel idRef="mm_profile"/>
<expand value="templates::Root::Root FOR model"/>
<fileEncoding value="ISO-8859-1"/>
<outlet path="src-gen">
<postprocessor class="org.eclipse.xpand2.output.JavaBeautifier"/>
</outlet>
</component>
</workflow>
I get the following errors:
0 INFO WorkflowEngine - --------------------------------------------------------------------------------------
2 INFO WorkflowEngine - EMF Modeling Workflow Engine 1.1.1, Build v201108020506
3 INFO WorkflowEngine - (c) 2005-2009 openarchitectureware.org and contributors
3 INFO WorkflowEngine - --------------------------------------------------------------------------------------
3 INFO WorkflowEngine - running workflow: C:/Users/yasser/Desktop/workspace/my.generator.project/src/workflowWithProfile.mwe
319 ERROR WorkflowEngine - [ERROR]: Class not found: 'org.eclipse.xtend.typesystem.uml2.Setup'(Element: bean bean class='org.eclipse.xtend.typesystem.uml2.Setup' in C:/Users/yasser/Desktop/workspace/my.generator.project/src/workflowWithProfile.mwe:7; Reported by: -UNKNOWN-)
320 ERROR WorkflowEngine - [ERROR]: No getter or adder method for property 'standardUML2Setup' in clazz 'java.lang.Object' found.(Element: standardUML2Setup='true' in C:/Users/yasser/Desktop/workspace/my.generator.project/src/workflowWithProfile.mwe:7; Reported by: -UNKNOWN-)
320 ERROR WorkflowEngine - [ERROR]: Class not found: 'org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel'(Element: bean bean class='org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel' id='mm_profile' in C:/Users/yasser/Desktop/workspace/my.generator.project/src/workflowWithProfile.mwe:10; Reported by: -UNKNOWN-)
320 ERROR WorkflowEngine - [ERROR]: No getter or adder method for property 'profile' in clazz 'java.lang.Object' found.(Element: profile='platform:/resource/xpand.uml2.generator/src/test.profile.uml' in C:/Users/yasser/Desktop/workspace/my.generator.project/src/workflowWithProfile.mwe:11; Reported by: -UNKNOWN-)
320 WARN WorkflowEngine - [WARNING]: The type of the referred bean (java.lang.Object) is not assignable to org.eclipse.xtend.typesystem.MetaModel(Element: -UNKNOWN-; Reported by: -UNKNOWN-)
320 ERROR WorkflowEngine - Workflow interrupted because of configuration errors.
Mainly class not found errors. Using eclipse indigo.
Re: Workflow configuration error - classes not found [message #921067 is a reply to message #921048] Sun, 23 September 2012 19:50 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Make sure you add the required plugins to the manifest.mf
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Twitter : @chrdietrich
Day Job: https://www.everest-systems.com
Re: Workflow configuration error - classes not found [message #1745111 is a reply to message #921067] Wed, 05 October 2016 09:50 Go to previous messageGo to next message
babou boubou is currently offline babou boubouFriend
in this case i should add all the list of plug-ins required for the operation of this plug-in?
Re: Workflow configuration error - classes not found [message #1745112 is a reply to message #921067] Wed, 05 October 2016 10:23 Go to previous message
salha salha is currently offline salha salhaFriend
Member
how i do?
Previous Topic:[Acceleo] Supress generation popups?
Next Topic: Workflow interrupted because of configuration errors.
Current Time: Tue Dec 03 11:45:21 GMT 2024
Powered by FUDForum. Page generated in 0.23995 seconds
