Home » Newcomers » Newcomers » C/C++(Launch failed. Binary not found.)
C/C++ [message #920296] Sat, 22 September 2012 23:42 Go to next message
Nicole Pilipow is currently offline Nicole PilipowFriend
I keep getting the Binary not found message after I build. I've looked at a couple youtube tutorials and when they click Build Project, a box shows up with a progress bar for a few seconds. This doesn't happen for me. I'm not sure if it's just that I have a newer version or what. So my problem is that I don't know if the issue is in the building or running stage. I just downloaded eclipse today and I'm not sure what version I have. Any suggestions?
[Updated on: Sat, 22 September 2012 23:42]
Report message to a moderator
Re: C/C++ [message #922037 is a reply to message #920296] Mon, 24 September 2012 17:19 Go to previous message
Eliseo Ocampos is currently offline Eliseo OcamposFriend
Hey Nicole,
I'm not using Eclipse C/C++, so sadly I can't help you, but If you are not getting any responses here, you can try asking in the recommended forum in this sticky post: http://www.eclipse.org/forums/index.php/t/161206/
Previous Topic:Sonar plugin for Eclipse - Installation Problems
Next Topic:a rank newcomer like me needs help and support
Current Time: Fri May 20 04:27:57 GMT 2022
Powered by FUDForum. Page generated in 0.03592 seconds
