Re: Can't open Eclipse Juno [message #920078 is a reply to message #919183] |
Sat, 22 September 2012 18:04 |
How did you unpack the Juno Java EE download? What did you use to unzip it? Did you extract it into a clean directory? Is that also a 64-bit JRE you have installed?
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Can't open Eclipse Juno [message #922147 is a reply to message #922032] |
Mon, 24 September 2012 19:44 |
Crystal Pavis Messages: 4 Registered: September 2012 |
Thanks for your suggestion. I had also seen that on StackOverflow before I posted here. I had tried it by pasting
Dosgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@
to the bottom of the eclipse.ini file and I receive this error:
Could not find the main class:
Program will exit.
When I close that I get a popup that says
Java was started but returned exit code=1
C:\Java\jre\bin\javaw.exe
-Dosgi.requiredJavaVersion=1.5
and more text but I can't copy and paste it.
So I pointed it to a different JDK I have on my computer and it went back to the original error message:
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
[Updated on: Mon, 24 September 2012 19:57] Report message to a moderator
FUDForum. Page generated in 0.09344 seconds
