Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Innacuracies while comparing lists of very similar elements
[EMF Compare] Innacuracies while comparing lists of very similar elements [message #123712] Thu, 29 May 2008 16:49 Go to next message
Victor Roldan Betancort is currently offline Victor Roldan BetancortFriend
Sorry to bother again about EMF Compare. I hope to help while reporting
my findings.
Try to imagine a multivalued referenced with lots of referenced
children. These elements are simple named elements. Take a look at the
following example (I'll put just 2 lists of names of these elements):
ELEMENT01 -- ELEMENT01
ELEMENT02 -- ELEMENT02
ELEMENT03 -- ELEMENT03
ELEMENT04 -- ELEMENT04
ELEMENT05 -- ELEMENT05
ELEMENT06 -- ELEMENT06
ELEMENT07 -- ELEMENT07
If I remove one element from the second EReference:
ELEMENT03 -- .........
The comparison will result in (its an example, but happens most of the
times):
ELEMENT01 -- ELEMENT01 <match>
ELEMENT02 -- ELEMENT02 <match>
ELEMENT03 -- ......... <deleted>
ELEMENT04 -- ELEMENT05 <modified>
ELEMENT05 -- ELEMENT06 <modified>
ELEMENT06 -- ELEMENT04 <modified>
ELEMENT07 -- ELEMENT07 <match>
This is just an example situation, but as you can see, the engine tries
to match elements in the same position, and gets a high similarity score
(since these elements are very similar, even in the name).
In my opinion, the engine should take a look in the neighborhood to
search for a perfect match. In case there is no perfect match, then it
could match those with the highest similarity score.
Cheers!
Víctor.
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #124040 is a reply to message #123712] Fri, 30 May 2008 07:46 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------080500040509030101030602
V
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #124053 is a reply to message #123712] Fri, 30 May 2008 08:06 Go to previous messageGo to next message
Cedric Brun is currently offline Cedric BrunFriend
Hi Víctor,
thanks for your feedback, you're not bothering us *at all* and the issues
you may encounter are likely to be encountered by other users not taking
the time to ask on the newsgroup, then thanks again :)
Cédric
> my findings.
> times):
> Cheers!
> Víctor.
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #124800 is a reply to message #124053] Mon, 02 June 2008 09:39 Go to previous messageGo to next message
--------------070408040506040808080108
Hi Víctor,
I took some time to tests this and couldn't reproduce your behavior with
the latest version of EMF Compare (0.8RC2 as I write this). My test case
was a simple ecore model with classes named ELEMENTx as you outlined in
your example, then deleting class ELEMENT3 was detected accurately by
EMF Compare. The same occured with EEnumLiterals named LITERALxx ... The
elements' name was the only thing I modified for this test.
Which version of Eclipse/EMF Compare are you using to reproduce this
bug? And can you provide us with the models you were comparing if they
do not contain any confidential information (preferred form is of course
a bug on Eclipse bugzilla ;)).
Laurent Goubet
Obeo
Cédric Brun a écrit :
> Hi Víctor,
> Cédric
>> my findings.
>> times):
>> Cheers!
>> Víctor.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------070408040506040808080108--
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #124859 is a reply to message #124800] Mon, 02 June 2008 11:15 Go to previous messageGo to next message
Laurent,
I think I must have correct one premise I posted in first instance:
these model elements aren't just plain elements, I mean, these element
weren't just classes with attributes, but rather classes with a mix of
attribs and references to other elements. Furthermore, another
characteristic I see is that these elements are part of a particular
hierarchy of EClasses. Using the original example, this would mean that
"ELEMENTx" is inherits from a somehow complex inheritance tree (lets
say, for instance, something like ELEMENTBASE -> ELEMENTABSTRACT -> ...
-> ELEMENT).
I'm using bleeding-edge stuff (All RC2 that's available). Using EMF
Compare 0.8RC2.
Unfortunately, as you say, the models I'm working on have confidential
information. I'll elaborate an "open source" clone of these
"confidential models" so I can provide it to you as test case ;) ;)
Víctor.
laurent Goubet escribió:
> Hi Víctor,
> Laurent Goubet
> Obeo
>> Hi Víctor,
>> Cédric
>>> my findings.
>>> times):
>>> Cheers!
>>> Víctor.
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #124884 is a reply to message #124859] Mon, 02 June 2008 11:39 Go to previous messageGo to next message
--------------000109080502080507080501
Thanks, will be waiting to try and fix these ;)
Laurent Goubet
Obeo
Víctor Roldán Betancort a écrit :
> Laurent,
> -> ELEMENT).
> Compare 0.8RC2.
> Regards,
> Víctor.
>> Hi Víctor,
>> with the latest version of EMF Compare (0.8RC2 as I write this). My
>> test case was a simple ecore model with classes named ELEMENTx as you
>> outlined in your example, then deleting class ELEMENT3 was detected
>> accurately by EMF Compare. The same occured with EEnumLiterals named
>> LITERALxx ... The elements' name was the only thing I modified for
>> this test.
>> course a bug on Eclipse bugzilla ;)).
>> Laurent Goubet
>> Obeo
>>> Hi Víctor,
>>> issues
>>> Cédric
>>>> my findings.
>>>> times):
>>>> score
>>>> Cheers!
>>>> Víctor.
--------------000109080502080507080501--
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #124924 is a reply to message #124884] Mon, 02 June 2008 12:48 Go to previous messageGo to next message
Ok, got to reproduce it in a test metamodel. Should I open a bugzilla
and attach the files , or...?
> Laurent Goubet
> Obeo
>> Laurent,
>> that "ELEMENTx" is inherits from a somehow complex inheritance tree
>> (lets say, for instance, something like ELEMENTBASE -> ELEMENTABSTRACT
>> -> ... -> ELEMENT).
>> Compare 0.8RC2.
>> Regards,
>> Víctor.
>>> Hi Víctor,
>>> this test.
>>> they do not contain any confidential information (preferred form is
>>> of course a bug on Eclipse bugzilla ;)).
>>> Laurent Goubet
>>> Obeo
>>>> Hi Víctor,
>>>> issues
>>>> taking
>>>> Cédric
>>>>> reporting
>>>>> my findings.
>>>>> times):
>>>>> tries
>>>>> score
>>>>> Cheers!
>>>>> Víctor.
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #124936 is a reply to message #124924] Mon, 02 June 2008 12:50 Go to previous message
--------------000100020104050708010102
Yes, bugzilla will be easier to track evolutions of this.
Thanks!
Laurent Goubet
Obeo
>> Laurent Goubet
>> Obeo
>>> Laurent,
>>> element weren't just classes with attributes, but rather classes with
>>> a mix of attribs and references to other elements. Furthermore,
>>> another characteristic I see is that these elements are part of a
>>> particular hierarchy of EClasses. Using the original example, this
>>> would mean that "ELEMENTx" is inherits from a somehow complex
>>> inheritance tree (lets say, for instance, something like ELEMENTBASE
>>> -> ELEMENTABSTRACT -> ... -> ELEMENT).
>>> Compare 0.8RC2.
>>> confidential information. I'll elaborate an "open source" clone of
>>> these "confidential models" so I can provide it to you as test case
>>> Regards,
>>> Víctor.
>>>> Hi Víctor,
>>>> you outlined in your example, then deleting class ELEMENT3 was
>>>> detected accurately by EMF Compare. The same occured with
>>>> EEnumLiterals named LITERALxx ... The elements' name was the only
>>>> Laurent Goubet
>>>> Obeo
>>>>> Hi Víctor,
>>>>> issues
>>>>> taking
>>>>> Cédric
>>>>>> reporting
>>>>>> my findings.
>>>>>> the
>>>>>> the
>>>>>> times):
>>>>>> tries
>>>>>> score
>>>>>> then it
>>>>>> Cheers!
>>>>>> Víctor.
--------------000100020104050708010102--
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #619095 is a reply to message #123712] Fri, 30 May 2008 07:46 Go to previous message
V
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #619096 is a reply to message #123712] Fri, 30 May 2008 08:06 Go to previous message
Hi Víctor,
Cédric
> my findings.
> times):
> Cheers!
> Víctor.
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #619136 is a reply to message #124053] Mon, 02 June 2008 09:39 Go to previous message
Hi Víctor,
Laurent Goubet
Obeo
> Hi Víctor,
> Cédric
>> my findings.
>> times):
>> Cheers!
>> Víctor.
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #619141 is a reply to message #124800] Mon, 02 June 2008 11:15 Go to previous message
Laurent,
-> ELEMENT).
Compare 0.8RC2.
Víctor.
> Hi Víctor,
> Laurent Goubet
> Obeo
>> Hi Víctor,
>> Cédric
>>> my findings.
>>> times):
>>> Cheers!
>>> Víctor.
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #619143 is a reply to message #124859] Mon, 02 June 2008 11:39 Go to previous message
Laurent Goubet
Obeo
> Laurent,
> -> ELEMENT).
> Compare 0.8RC2.
> Regards,
> Víctor.
>> Hi Víctor,
>> this test.
>> Laurent Goubet
>> Obeo
>>> Hi Víctor,
>>> issues
>>> Cédric
>>>> my findings.
>>>> times):
>>>> score
>>>> Cheers!
>>>> Víctor.
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #619146 is a reply to message #124884] Mon, 02 June 2008 12:48 Go to previous message
> Laurent Goubet
> Obeo
>> Laurent,
>> -> ... -> ELEMENT).
>> Compare 0.8RC2.
>> Regards,
>> Víctor.
>>> Hi Víctor,
>>> this test.
>>> Laurent Goubet
>>> Obeo
>>>> Hi Víctor,
>>>> issues
>>>> taking
>>>> Cédric
>>>>> reporting
>>>>> my findings.
>>>>> times):
>>>>> tries
>>>>> score
>>>>> Cheers!
>>>>> Víctor.
Re: [EMF Compare] Innacuracies while comparing lists of very similar elements [message #619147 is a reply to message #124924] Mon, 02 June 2008 12:50 Go to previous message
Thanks!
Laurent Goubet
Obeo
>> Laurent Goubet
>> Obeo
>>> Laurent,
>>> Compare 0.8RC2.
>>> Regards,
>>> Víctor.
>>>> Hi Víctor,
>>>> Laurent Goubet
>>>> Obeo
>>>>> Hi Víctor,
>>>>> issues
>>>>> taking
>>>>> Cédric
>>>>>> reporting
>>>>>> my findings.
>>>>>> the
>>>>>> the
>>>>>> times):
>>>>>> tries
>>>>>> score
>>>>>> then it
>>>>>> Cheers!
>>>>>> Víctor.
Previous Topic:EMF Compare - Comparing XSD (XML schema)
Next Topic:[Teneo] Switch to DB2 and not getting identity columns
Current Time: Mon Jan 18 01:58:46 GMT 2021
Powered by FUDForum. Page generated in 0.02912 seconds
