Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] False positives on multivalued EReferences with containment=false
[EMF Compare] False positives on multivalued EReferences with containment=false [message #123636] Thu, 29 May 2008 15:53 Go to next message
Victor Roldan Betancort is currently offline Victor Roldan BetancortFriend
Hi!
I've used EMF Compare with some models of mine, receiving some false
positives (sometime too much false positives). Those occur only in
multivalued EReferences that are apparently equal (referenced values
where equal). The only different thing from other ERefereces of the same
metamodel I've noticed is having no EOpposite and containment=false.
Take a look at these two models that generate a false positive (using
UMLX's QVT Core metamodel):
########### Model 1 #############
<?xml version="1.0" encoding="ASCII"?>
<eqvtbase:Transformation xmi:version="2.0"
xmlns:eqvtbase="http://www.eclipse.org/gmt/umlx/EQVTbase" xmi:id="ast0"
name="umlRdbms" nsURI="umlRdbms" nsPrefix="umlRdbms">
<modelParameter xmi:id="ast8" name="middle">
<usedPackage
href=" platform:/resource/com.foo.org/models_ecore/TumlRdbms.ecore# / "/>
</modelParameter>
</eqvtbase:Transformation>
########### Model 2 #############
xmlns:xmi="http://www.omg.org/XMI" xmlns:eqvtbase="umlRdbms"
xmi:id="ast0" name="CHANGED" nsURI="test" nsPrefix="umlRdbms">
<usedPackage
</modelParameter>
- The only differences' I've introduced is the nsURI of the root node.
EMF Compare shows correctly the changes on the nsURI, but also changes
on "usedPackage" EReference, indicating that
" platform:/resource/com.foo.org/models_ecore/TumlRdbms.ecore# / " has been
added on the first model, and deleted in the second one.
I've been digging a little bit in the source code and noticed what's
going on.
- Root node is marked as not equal (similarity = 0.6....)
- Typed model node is marked as equal (similarity = 1.0)
These four nodes are properly added to
"GenericDiffEngine::eObjectToMatch" hashMap.
The problem appears in "GenericDiffEngine::computeAddedReferences" and
"GenericDiffEngine::computeDeletedReferences", while trying to retrieve
from the map the matchModel of
" platform:/resource/com.foo.org/models_ecore/TumlRdbms.ecore# / ", which
doesn't actually exist in "eObjectToMatch" (what makes sense, since that
reference wasn't matched during first matching phase).
So I guess there are two solutions:
- Add these referenced resources to "eObjectToMatch"
- Filtering what "(List<EObject>)EFactory.eGetAsList..." returns
("GenericDiffEngine::createNonConflictingReferencesUpdate" method)
I'm sorry if I haven't been clear. If necessary, I'll send you the
example models and metamodel.
Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #124027 is a reply to message #123636] Fri, 30 May 2008 07:43 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------080104060404080102060603
We already have some bugs on references resolving, namely bugs #199877 (
https://bugs.eclipse.org/bugs/show_bug.cgi?id=199877 ) and #229663 (
https://bugs.eclipse.org/bugs/show_bug.cgi?id=229663 ).
If the issue you encounter doesn't fit in those, could you create a new
bug report with example models to reproduce this?
Thanks!
Laurent Goubet
Obeo
V
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #124847 is a reply to message #124027] Mon, 02 June 2008 10:45 Go to previous messageGo to next message
Laurent,
these bugs seems somehow related with what I've detected: proxy
resolution and broken references. The example I posted seems to match
both of those cases. However, I've got also some invalid diffs over
references to elements on the same model. As I have said, these
multivalued refences seemed equal when I take a look at the XMI, so
there most probable reason would problems during proxy resolution.
Curiously enough, these false triggering only appears if there is at
least 1 real difference in the model. If the models are completely
equal, no false differences are shown.
I have a model with one only real difference that actually returns like
45 false differences, all related with this problem. Unfortunately, I
cant provide it since its property of the company I work for. All I have
is this false triggering over some UMLX QVT Core instances. I'll try to
get these with some public metamodels so I can send them to you.
Víctor.
laurent Goubet escribió:
> Thanks!
> Laurent Goubet
> Obeo
> Víctor Roldán Betancort a écrit :
>> Hi!
>> same metamodel I've noticed is having no EOpposite and containment=false.
>> xmi:id="ast0" name="umlRdbms" nsURI="umlRdbms" nsPrefix="umlRdbms">
>> <usedPackage
>> </modelParameter>
>> <usedPackage
>> </modelParameter>
>> going on.
>> retrieve from the map the matchModel of
>> that reference wasn't matched during first matching phase).
>> Best regards,
>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #124872 is a reply to message #124847] Mon, 02 June 2008 11:38 Go to previous messageGo to next message
--------------010006020507080801070700
V
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #125048 is a reply to message #124872] Tue, 03 June 2008 15:26 Go to previous messageGo to next message
Hi Laurent,
after 2 days searching, I found the source of the problem for these
false positives. And it's not about containment. It's about the
"derived" attribute of an EAttribute/EReference. In my case, I had a
derived EReference (it shouldn't be that way, actually), which was also
container. Any model element contained by this "derived" EReference was
ignored by the engine during the matching. Is this a correct behaviour?
Should I raise a bugzilla?
Thanks!
Víctor.
> Víctor,
> Yes, if there isn't any real differences, the two files are exactly the
> same and compare won't go through the trouble of finding other
> comparators (such as EMF Compare) to try and find what has been changed.
> Having example models would indeed be the best for us to understand the
> actual issue. I can easily understand that having 1 difference
> triggerring 45 false positives is unexploitable.
> Laurent Goubet
> Obeo
>> Laurent,
>> like 45 false differences, all related with this problem.
>> Unfortunately, I cant provide it since its property of the company I
>> work for. All I have is this false triggering over some UMLX QVT Core
>> instances. I'll try to get these with some public metamodels so I can
>> send them to you.
>> Cheers,
>> Víctor.
>>> Hi,
>>> #199877 ( https://bugs.eclipse.org/bugs/show_bug.cgi?id=199877 ) and
>>> #229663 ( https://bugs.eclipse.org/bugs/show_bug.cgi?id=229663 ).
>>> new bug report with example models to reproduce this?
>>> Thanks!
>>> Laurent Goubet
>>> Obeo
>>>> Hi!
>>>> containment=false.
>>>> (using UMLX's QVT Core metamodel):
>>>> <usedPackage
>>>> </modelParameter>
>>>> <usedPackage
>>>> </modelParameter>
>>>> changes on "usedPackage" EReference, indicating that
>>>> been
>>>> going on.
>>>> and "GenericDiffEngine::computeDeletedReferences", while trying to
>>>> which doesn't actually exist in "eObjectToMatch" (what makes sense,
>>>> since that reference wasn't matched during first matching phase).
>>>> Best regards,
>>>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #125060 is a reply to message #125048] Tue, 03 June 2008 15:37 Go to previous messageGo to next message
--------------020200050600030204010705
V
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #125073 is a reply to message #125060] Tue, 03 June 2008 15:50 Go to previous messageGo to next message
Laurent,
To me it does make sense to ignore derived things for much the same
reason that a copier doesn't copy them. Presumably the information is
derived from other things in the model and if there's a difference, it
will be those non-derived differences that matter.
laurent Goubet wrote:
> Víctor,
> Ha, we indeed ignore derived references for comparison
> (GenericDiffEngine#shouldBeIgnored(EReference)) :
> * Determines if we should ignore a reference for diff detection.
> * <p>
> * Default is to ignore references marked either
> * <ul>
> * <li>Containment</li>
> * <li>Container</li>
> * <li>Transient</li>
> * <li>Derived</li>
> * </ul>
> * </p>
> * <p>
> * Clients should override this if they wish to ignore other
> references.
> * </p>
> * @param reference
> * Reference to determine whether it should be ignored.
> * @return <code>True</code> if reference has to be ignored,
> <code>False</code> otherwise.
> protected boolean shouldBeIgnored(EReference reference) {
> boolean ignore = reference.isContainment();
> ignore |= reference.isDerived();
> ignore |= reference.isTransient();
> ignore |= reference.isContainer();
> return ignore;
> What I don't understand is ... if we ignore them, why are there
> differences reported on it? I wonder if this truly is the source of
> the issue but will look into it some more. Thanks for the feedback.
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> also container. Any model element contained by this "derived"
>> EReference was ignored by the engine during the matching. Is this a
>> correct behaviour? Should I raise a bugzilla?
>> Thanks!
>> Víctor.
>>> Víctor,
>>> the same and compare won't go through the trouble of finding other
>>> changed.
>>> the actual issue. I can easily understand that having 1 difference
>>> Laurent Goubet
>>> Obeo
>>>> Laurent,
>>>> match both of those cases. However, I've got also some invalid
>>>> diffs over references to elements on the same model. As I have
>>>> said, these multivalued refences seemed equal when I take a look at
>>>> the XMI, so there most probable reason would problems during proxy
>>>> resolution.
>>>> at least 1 real difference in the model. If the models are
>>>> completely equal, no false differences are shown.
>>>> I work for. All I have is this false triggering over some UMLX QVT
>>>> Core instances. I'll try to get these with some public metamodels
>>>> Cheers,
>>>> Víctor.
>>>>> Hi,
>>>>> and #229663 ( https://bugs.eclipse.org/bugs/show_bug.cgi?id=229663 ).
>>>>> a new bug report with example models to reproduce this?
>>>>> Thanks!
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Hi!
>>>>>> false positives (sometime too much false positives). Those occur
>>>>>> only in multivalued EReferences that are apparently equal
>>>>>> (referenced values where equal). The only different thing from
>>>>>> other ERefereces of the same metamodel I've noticed is having no
>>>>>> <usedPackage
>>>>>> </modelParameter>
>>>>>> <usedPackage
>>>>>> </modelParameter>
>>>>>> node.
>>>>>> has been
>>>>>> what's going on.
>>>>>> sense, since that reference wasn't matched during first matching
>>>>>> phase).
>>>>>> the example models and metamodel.
>>>>>> Best regards,
>>>>>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #125083 is a reply to message #125073] Tue, 03 June 2008 16:02 Go to previous messageGo to next message
--------------050203020707020409080207
Ed,
Yup, that's the reason why we decided on ignoring it, better have a
single difference than two on this. What I do not understand here is
that we seem to detect a difference on derived references even when
ignoring them, which would be a bug ;).
Ed Merks a
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #125093 is a reply to message #125060] Tue, 03 June 2008 16:07 Go to previous messageGo to next message
Laurent,
I think I know why it's repored as a difference. As far As I've seen in
the source code, every element that's matched is put into a hashmap
(GenericDiffEngine.java:82 -> eObjectToMatch), linked with a
"match2element" structure. During differences analysis, anything that is
not inside that hashmap is considered a difference (check
"computeAddedReferences" and "computeDeletedReferences" methods). Since
you ignore derived elements, these won't appear in the hashmap.
> Víctor,
> * <p>
> * <ul>
> * <li>Derived</li>
> * </ul>
> * </p>
> * <p>
> references.
> * </p>
> * @param reference
> return ignore;
> differences reported on it? I wonder if this truly is the source of the
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> Thanks!
>> Víctor.
>>> Víctor,
>>> Laurent Goubet
>>> Obeo
>>>> Laurent,
>>>> match both of those cases. However, I've got also some invalid diffs
>>>> over references to elements on the same model. As I have said, these
>>>> Core instances. I'll try to get these with some public metamodels so
>>>> Cheers,
>>>> Víctor.
>>>>> Hi,
>>>>> Thanks!
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Hi!
>>>>>> <usedPackage
>>>>>> </modelParameter>
>>>>>> <usedPackage
>>>>>> </modelParameter>
>>>>>> node.
>>>>>> has been
>>>>>> what's going on.
>>>>>> phase).
>>>>>> Best regards,
>>>>>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #125121 is a reply to message #125093] Wed, 04 June 2008 08:31 Go to previous messageGo to next message
--------------000203010606040403080209
V
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #125124 is a reply to message #125121] Wed, 04 June 2008 09:27 Go to previous messageGo to next message
Sure thing, I'll do that ASAP.
> Víctor,
> I can't seem to reproduce this bug with either setting I can put in a
> test metamodel :/. Could you provide us with a dummy metamodel
> presenting a reference producing this bug? Preferrably on bugzilla.
> Laurent Goubet
> Obeo
>> Laurent,
>> in the source code, every element that's matched is put into a hashmap
>> is not inside that hashmap is considered a difference (check
>> Since you ignore derived elements, these won't appear in the hashmap.
>>> Víctor,
>>> * <p>
>>> * <ul>
>>> * <li>Derived</li>
>>> * </ul>
>>> * </p>
>>> * <p>
>>> references.
>>> * </p>
>>> * @param reference
>>> return ignore;
>>> Laurent Goubet
>>> Obeo
>>>> Hi Laurent,
>>>> Thanks!
>>>> Víctor.
>>>>> Víctor,
>>>>> changed.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Laurent,
>>>>>> at the XMI, so there most probable reason would problems during
>>>>>> proxy resolution.
>>>>>> Cheers,
>>>>>> Víctor.
>>>>>>> Hi,
>>>>>>> and #229663 (
>>>>>>> Thanks!
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>>> Hi!
>>>>>>>> <usedPackage
>>>>>>>> </modelParameter>
>>>>>>>> <usedPackage
>>>>>>>> </modelParameter>
>>>>>>>> node.
>>>>>>>> has been
>>>>>>>> what's going on.
>>>>>>>> phase).
>>>>>>>> Best regards,
>>>>>>>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #125132 is a reply to message #125121] Wed, 04 June 2008 14:37 Go to previous messageGo to next message
Done :)
Metamodel, genmodel, test instances and .emfdiff file.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=235606
Víctor
> Víctor,
> Laurent Goubet
> Obeo
>> Laurent,
>>> Víctor,
>>> * <p>
>>> * <ul>
>>> * <li>Derived</li>
>>> * </ul>
>>> * </p>
>>> * <p>
>>> references.
>>> * </p>
>>> * @param reference
>>> return ignore;
>>> Laurent Goubet
>>> Obeo
>>>> Hi Laurent,
>>>> Thanks!
>>>> Víctor.
>>>>> Víctor,
>>>>> changed.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Laurent,
>>>>>> proxy resolution.
>>>>>> Cheers,
>>>>>> Víctor.
>>>>>>> Hi,
>>>>>>> and #229663 (
>>>>>>> Thanks!
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>>> Hi!
>>>>>>>> <usedPackage
>>>>>>>> </modelParameter>
>>>>>>>> <usedPackage
>>>>>>>> </modelParameter>
>>>>>>>> node.
>>>>>>>> has been
>>>>>>>> what's going on.
>>>>>>>> phase).
>>>>>>>> Best regards,
>>>>>>>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #125154 is a reply to message #125132] Thu, 05 June 2008 14:02 Go to previous messageGo to next message
--------------050004070602070402010902
Thanks for that ;). The issue didn't come from the diff engine
(difference detection) but rather from the match engine (elements
mapping). the content of a derived containment difference doesn't appear
in the eobject's content list (EObject#eContents() /
EObject#eAllContents()) so we weren't able to match them and they were
detected as differences.
Ed, is this a bug in EMF or derived references weren't meant to appear
in the content list event when they are containment references?
Thanks for the feedback!
Laurent Goubet
Obeo
V
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #125160 is a reply to message #125154] Thu, 05 June 2008 17:35 Go to previous messageGo to next message
Laurent,
The problem with a derived containment reference is that you can't
really derive a containment reference; Kenn ran into this issue with UML
as well with subset/superset features. The only scenario where EMF
supports such a thing directly is in the case where the feature derives
from the information in a feature map, and in that case, we ensure that
the contents derived from the feature map are properly included in the
right order where the feature map determines the order. Some of the
problems with trying to make this work are issues like the eContainer
must be consistent and in particular
x.eContainer().eGet(x.eContainmentFeature()) must return x or a list
containing x. So if the containment reference derives from another
containment reference, the containment feature isn't consistent. If the
containment reference derives from a non-containment reference, it's
hard to imagine that the eContainer will be correct. So it's likely
that there's something inconsistent about a model that has derived
containment features. The subject line talks about multi-valued
non-containment references which makes me think that the derivation is
perhaps done in a bad direction. I.e., while it's fine to derive a
non-containment reference from a containment reference, the other
direction doesn't work well at all.
> appear in the eobject's content list (EObject#eContents() /
> Laurent Goubet
> Obeo
>> Done :)
>> Cheers,
>> Víctor
>>> Víctor,
>>> a test metamodel :/. Could you provide us with a dummy metamodel
>>> Laurent Goubet
>>> Obeo
>>>> Laurent,
>>>> seen in the source code, every element that's matched is put into a
>>>> hashmap (GenericDiffEngine.java:82 -> eObjectToMatch), linked with
>>>> a "match2element" structure. During differences analysis, anything
>>>> that is not inside that hashmap is considered a difference (check
>>>>> Víctor,
>>>>> * <p>
>>>>> * <ul>
>>>>> * <li>Derived</li>
>>>>> * </ul>
>>>>> * </p>
>>>>> * <p>
>>>>> references.
>>>>> * </p>
>>>>> * @param reference
>>>>> ignored.
>>>>> return ignore;
>>>>> of the issue but will look into it some more. Thanks for the
>>>>> feedback.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Hi Laurent,
>>>>>> these false positives. And it's not about containment. It's about
>>>>>> the "derived" attribute of an EAttribute/EReference. In my case,
>>>>>> I had a derived EReference (it shouldn't be that way, actually),
>>>>>> which was also container. Any model element contained by this
>>>>>> "derived" EReference was ignored by the engine during the
>>>>>> matching. Is this a correct behaviour? Should I raise a bugzilla?
>>>>>> Thanks!
>>>>>> Víctor.
>>>>>>> Víctor,
>>>>>>> exactly the same and compare won't go through the trouble of
>>>>>>> finding other comparators (such as EMF Compare) to try and find
>>>>>>> understand the actual issue. I can easily understand that having
>>>>>>> 1 difference triggerring 45 false positives is unexploitable.
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>>> Laurent,
>>>>>>>> look at the XMI, so there most probable reason would problems
>>>>>>>> is at least 1 real difference in the model. If the models are
>>>>>>>> returns like 45 false differences, all related with this
>>>>>>>> problem. Unfortunately, I cant provide it since its property of
>>>>>>>> the company I work for. All I have is this false triggering
>>>>>>>> over some UMLX QVT Core instances. I'll try to get these with
>>>>>>>> Cheers,
>>>>>>>> Víctor.
>>>>>>>>> Hi,
>>>>>>>>> ) and #229663 (
>>>>>>>>> create a new bug report with example models to reproduce this?
>>>>>>>>> Thanks!
>>>>>>>>> Laurent Goubet
>>>>>>>>> Obeo
>>>>>>>>>> Hi!
>>>>>>>>>> some false positives (sometime too much false positives).
>>>>>>>>>> Those occur only in multivalued EReferences that are
>>>>>>>>>> apparently equal (referenced values where equal). The only
>>>>>>>>>> different thing from other ERefereces of the same metamodel
>>>>>>>>>> positive (using UMLX's QVT Core metamodel):
>>>>>>>>>> <usedPackage
>>>>>>>>>> </modelParameter>
>>>>>>>>>> <usedPackage
>>>>>>>>>> </modelParameter>
>>>>>>>>>> root node.
>>>>>>>>>> also changes on "usedPackage" EReference, indicating that
>>>>>>>>>> has been
>>>>>>>>>> what's going on.
>>>>>>>>>> to retrieve from the map the matchModel of
>>>>>>>>>> matching phase).
>>>>>>>>>> returns
>>>>>>>>>> method)
>>>>>>>>>> you the example models and metamodel.
>>>>>>>>>> Best regards,
>>>>>>>>>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #125175 is a reply to message #125160] Fri, 06 June 2008 07:32 Go to previous message
--------------090109060409090606050500
Ed,
Yes, I can understand the problem with such references. And As V
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619094 is a reply to message #123636] Fri, 30 May 2008 07:43 Go to previous message
Thanks!
Laurent Goubet
Obeo
V
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619140 is a reply to message #124027] Mon, 02 June 2008 10:45 Go to previous message
Laurent,
Víctor.
> Thanks!
> Laurent Goubet
> Obeo
>> Hi!
>> <usedPackage
>> </modelParameter>
>> <usedPackage
>> </modelParameter>
>> going on.
>> Best regards,
>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619142 is a reply to message #124847] Mon, 02 June 2008 11:38 Go to previous message
V
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619156 is a reply to message #124872] Tue, 03 June 2008 15:26 Go to previous message
Hi Laurent,
Thanks!
Víctor.
> Víctor,
> Laurent Goubet
> Obeo
>> Laurent,
>> send them to you.
>> Cheers,
>> Víctor.
>>> Hi,
>>> Thanks!
>>> Laurent Goubet
>>> Obeo
>>>> Hi!
>>>> containment=false.
>>>> <usedPackage
>>>> </modelParameter>
>>>> <usedPackage
>>>> </modelParameter>
>>>> been
>>>> going on.
>>>> Best regards,
>>>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619157 is a reply to message #125048] Tue, 03 June 2008 15:37 Go to previous message
V
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619158 is a reply to message #125060] Tue, 03 June 2008 15:50 Go to previous message
Laurent,
> Víctor,
> * <p>
> * <ul>
> * <li>Derived</li>
> * </ul>
> * </p>
> * <p>
> references.
> * </p>
> * @param reference
> return ignore;
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> Thanks!
>> Víctor.
>>> Víctor,
>>> changed.
>>> Laurent Goubet
>>> Obeo
>>>> Laurent,
>>>> resolution.
>>>> Cheers,
>>>> Víctor.
>>>>> Hi,
>>>>> Thanks!
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Hi!
>>>>>> <usedPackage
>>>>>> </modelParameter>
>>>>>> <usedPackage
>>>>>> </modelParameter>
>>>>>> node.
>>>>>> has been
>>>>>> what's going on.
>>>>>> phase).
>>>>>> Best regards,
>>>>>> Víctor.
Ed Merks
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619159 is a reply to message #125073] Tue, 03 June 2008 16:02 Go to previous message
Ed,
Ed Merks a
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619160 is a reply to message #125060] Tue, 03 June 2008 16:07 Go to previous message
Laurent,
> Víctor,
> * <p>
> * <ul>
> * <li>Derived</li>
> * </ul>
> * </p>
> * <p>
> references.
> * </p>
> * @param reference
> return ignore;
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> Thanks!
>> Víctor.
>>> Víctor,
>>> Laurent Goubet
>>> Obeo
>>>> Laurent,
>>>> Cheers,
>>>> Víctor.
>>>>> Hi,
>>>>> Thanks!
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Hi!
>>>>>> <usedPackage
>>>>>> </modelParameter>
>>>>>> <usedPackage
>>>>>> </modelParameter>
>>>>>> node.
>>>>>> has been
>>>>>> what's going on.
>>>>>> phase).
>>>>>> Best regards,
>>>>>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619164 is a reply to message #125093] Wed, 04 June 2008 08:31 Go to previous message
V
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619165 is a reply to message #125121] Wed, 04 June 2008 09:27 Go to previous message
> Víctor,
> Laurent Goubet
> Obeo
>> Laurent,
>>> Víctor,
>>> * <p>
>>> * <ul>
>>> * <li>Derived</li>
>>> * </ul>
>>> * </p>
>>> * <p>
>>> references.
>>> * </p>
>>> * @param reference
>>> return ignore;
>>> Laurent Goubet
>>> Obeo
>>>> Hi Laurent,
>>>> Thanks!
>>>> Víctor.
>>>>> Víctor,
>>>>> changed.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Laurent,
>>>>>> proxy resolution.
>>>>>> Cheers,
>>>>>> Víctor.
>>>>>>> Hi,
>>>>>>> and #229663 (
>>>>>>> Thanks!
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>>> Hi!
>>>>>>>> <usedPackage
>>>>>>>> </modelParameter>
>>>>>>>> <usedPackage
>>>>>>>> </modelParameter>
>>>>>>>> node.
>>>>>>>> has been
>>>>>>>> what's going on.
>>>>>>>> phase).
>>>>>>>> Best regards,
>>>>>>>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619167 is a reply to message #125121] Wed, 04 June 2008 14:37 Go to previous message
Done :)
Víctor
> Víctor,
> Laurent Goubet
> Obeo
>> Laurent,
>>> Víctor,
>>> * <p>
>>> * <ul>
>>> * <li>Derived</li>
>>> * </ul>
>>> * </p>
>>> * <p>
>>> references.
>>> * </p>
>>> * @param reference
>>> return ignore;
>>> Laurent Goubet
>>> Obeo
>>>> Hi Laurent,
>>>> Thanks!
>>>> Víctor.
>>>>> Víctor,
>>>>> changed.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Laurent,
>>>>>> proxy resolution.
>>>>>> Cheers,
>>>>>> Víctor.
>>>>>>> Hi,
>>>>>>> and #229663 (
>>>>>>> Thanks!
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>>> Hi!
>>>>>>>> <usedPackage
>>>>>>>> </modelParameter>
>>>>>>>> <usedPackage
>>>>>>>> </modelParameter>
>>>>>>>> node.
>>>>>>>> has been
>>>>>>>> what's going on.
>>>>>>>> phase).
>>>>>>>> Best regards,
>>>>>>>> Víctor.
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619177 is a reply to message #125132] Thu, 05 June 2008 14:02 Go to previous message
Laurent Goubet
Obeo
V
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619179 is a reply to message #125154] Thu, 05 June 2008 17:35 Go to previous message
Laurent,
> Laurent Goubet
> Obeo
>> Done :)
>> Cheers,
>> Víctor
>>> Víctor,
>>> Laurent Goubet
>>> Obeo
>>>> Laurent,
>>>>> Víctor,
>>>>> * <p>
>>>>> * <ul>
>>>>> * <li>Derived</li>
>>>>> * </ul>
>>>>> * </p>
>>>>> * <p>
>>>>> references.
>>>>> * </p>
>>>>> * @param reference
>>>>> ignored.
>>>>> return ignore;
>>>>> feedback.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Hi Laurent,
>>>>>> Thanks!
>>>>>> Víctor.
>>>>>>> Víctor,
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>>> Laurent,
>>>>>>>> Cheers,
>>>>>>>> Víctor.
>>>>>>>>> Hi,
>>>>>>>>> ) and #229663 (
>>>>>>>>> Thanks!
>>>>>>>>> Laurent Goubet
>>>>>>>>> Obeo
>>>>>>>>>> Hi!
>>>>>>>>>> <usedPackage
>>>>>>>>>> </modelParameter>
>>>>>>>>>> <usedPackage
>>>>>>>>>> </modelParameter>
>>>>>>>>>> root node.
>>>>>>>>>> has been
>>>>>>>>>> what's going on.
>>>>>>>>>> matching phase).
>>>>>>>>>> returns
>>>>>>>>>> method)
>>>>>>>>>> Best regards,
>>>>>>>>>> Víctor.
Ed Merks
Re: [EMF Compare] False positives on multivalued EReferences with containment=false [message #619193 is a reply to message #125160] Fri, 06 June 2008 07:32 Go to previous message
Ed,
Previous Topic:[EMF Compare] is the javadoc broken?
Next Topic:[Announce] EMF Teneo Builds
Current Time: Tue Apr 16 17:26:18 GMT 2024
Powered by FUDForum. Page generated in 1.95321 seconds
