Home » Eclipse Projects » EclipseLink » Creating BLOBs
Creating BLOBs [message #917807] Thu, 20 September 2012 12:58 Go to next message
Johannes Becker is currently offline Johannes BeckerFriend
I'm trying to switch from Hibernate to EclipseLink. Now I'm facing the problem of creating BLOBs. With Hibernate I solved it this way:
import org.hibernate.LobHelper;
import org.hibernate.classic.Session;
  public Blob createBlob(InputStream inputStream, long length)
    Session session = entityManager.unwrap(Session.class);
    LobHelper lobHelper = session.getLobHelper();
    Blob blob = lobHelper.createBlob(inputStream, length);
    return blob;
Any hints how I can do this with EclipseLink? (I'm on an Oracle DB if this matters).
Jonny
Re: Creating BLOBs [message #923027 is a reply to message #917807] Tue, 25 September 2012 14:45 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
Normally you can just treat a BLOB as a byte array (byte[]).
If you want the JDBC Blob you can use the unwrap(java.sql.Connection.class) to get the JDBC Connection.
James : Wiki : Book : Blog : Twitter
Re: Creating BLOBs [message #923049 is a reply to message #923027] Tue, 25 September 2012 15:05 Go to previous messageGo to next message
Hi James,
thanks for your reply.
I have large files, so the streaming ability of BLOBs would come handy.
Do you have an example? My knowledge in this particlar field isn't too deep.
Jonny
Re: Creating BLOBs [message #923063 is a reply to message #923049] Tue, 25 September 2012 15:14 Go to previous messageGo to next message
Search for "JDBC BLOB examples", you basically just create a select Statement execute it to get the Blob and write into it.
Unless the file is extremely large, it would probably fit into memory as a byte[].
Re: Creating BLOBs [message #923082 is a reply to message #923063] Tue, 25 September 2012 15:33 Go to previous message
Ok, I'll do that. Thanks. My hope was, that maybe EclipseLink provided such helper-classes as Hibernate.
Jonny
Previous Topic:AggregateCollectionMapping in DyanmicMapping
Next Topic:Transform xml from one XSD version to another
Current Time: Wed Aug 04 01:08:50 GMT 2021
Powered by FUDForum. Page generated in 0.01923 seconds
