Home » Modeling » M2T (model-to-text transformation) » [Xpand] How to use local variable in a template
[Xpand] How to use local variable in a template [message #917627] Thu, 20 September 2012 09:06 Go to next message
Hai Le is currently offline Hai LeFriend
Hello everyone,
There is a need of using local variable in a template (in scope of «DEFINE» ... «ENDDEFINE»).
Could it be using let expression (i.e «let strLst = {} : strLst.add("str") -> ""»)?
My temporary solution is to use globalvar extension from xtend stdlib.
Hope to hear from you soon.
Thanks in advance,
Hai LE
Re: [Xpand] How to use local variable in a template [message #917709 is a reply to message #917627] Thu, 20 September 2012 10:50 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi what about <<LET ...>><<ENDLET>>
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: [Xpand] How to use local variable in a template [message #918404 is a reply to message #917709] Fri, 21 September 2012 01:49 Go to previous messageGo to next message
Hi Christian,
In fact, <<LET>>...<<ENDLET>> just allows the variable evaluated one time at the beginning. We are not able to change the value of variable in block.
Re: [Xpand] How to use local variable in a template [message #918512 is a reply to message #918404] Fri, 21 September 2012 04:39 Go to previous message
Could you show an example Of your usecase?
Previous Topic:[xpand.support.cdt] DefaultCodeFormatterOptions not found
Next Topic:[Xpand] Version in Juno SR1: 1.2.1 or 1.2.2?
Current Time: Mon Nov 30 10:54:34 GMT 2020
Powered by FUDForum. Page generated in 0.01522 seconds
