Home » Modeling » QVT-OML » QVTo editor with changing input model
QVTo editor with changing input model [message #917610] Thu, 20 September 2012 04:47 Go to next message
in my project, the input and output models (EMF Ecore and EMF XSD) are
changing quite frequently. Every time I open the QVTo editor I must
ensure that it knows the correct model version. So far I've solved this
by creating a launch configuration "QVT Editor" that contains the
generated EMF model code and loads the current XSD model on startup.
However this is a bit sub-optimal. It is a major extra step for each
developer to construct such a run-time eclipse. Opening QVTo scripts in
the normal development eclipse just blows you away with error markers as
it doesn't know any of the input/output models. That and the extra QVT
learning curve makes my client having 2nd thoughts about using the QVT
technology.
Long story short: is there a way to make the regular QVT editor aware of
changing models? Ideally, the editor would load the .ecore everytime
when opened. How can I archieve this?
Marius
Re: QVTo editor with changing input model [message #917773 is a reply to message #917610] Thu, 20 September 2012 08:21 Go to previous messageGo to next message
I don't understand your problem. I use EMF models that have never been
code generated using QVTo.
You just define the {project}->Properties->QVT Settings->Metamodel
Mappings appropriately.
Mine end up (in .settings/org.eclipse.m2m.qvt.oml.mmodel.urimap) as:
<?xml version="1.0" encoding="ASCII"?>
<uriMap:MappingContainer xmi:version="2.0"
xmlns:uriMap="http:///www.eclipse.org/m2m/qvt/oml/MModelUriMap/1.0.0">
<mapping sourceURI="http://www.eclipse.org/ocl/XBNF"
targetURI="platform:/resource/org.eclipse.ocl.examples.xtext2lpg/model/XBNF.ecore"/>
<mapping sourceURI="http://www.eclipse.org/ocl/XBNFwithCardinality"
targetURI="platform:/resource/org.eclipse.ocl.examples.xtext2lpg/model/XBNFwithCardinality.ecore"/>
</uriMap:MappingContainer>
I'm not certain the concurrent *.ecore update is perfect, so sometimes
it may be necessary to exit and restart the QVTo editor.
Ed Willink
On 20/09/2012 09:47, Marius Gröger wrote:
> Hello,
> technology.
> Thanks
> Marius
Re: QVTo editor with changing input model [message #917834 is a reply to message #917773] Thu, 20 September 2012 09:31 Go to previous messageGo to next message
On 20.09.2012 14:21, Ed Willink wrote:
> Hi
Oh. Ok. I didn't have that option in my project's properties. I've now
added the nature and the QVTo builder to the .project and restarted. (Is
that enough? I don't get the fancy QVTo icon...)
I've even managed to set up the model uri map for some of my EMF models.
But as I said in my OP, I'm also using XSD based models. And the model
uri map dialog doesn't seem to allow me adding those: "Failed to load
...." Any idea?
Marius
Re: QVTo editor with changing input model [message #917865 is a reply to message #917834] Thu, 20 September 2012 10:12 Go to previous messageGo to next message
QVTo support Ecore models.
EMF provides a magic translation so that as far as I am aware your 'XSD
model' should appear to be an Ecore model to QVTo; you just need to
ensure that your Ecore to XSD configuration is coherent. The Sample
Ecore Editor is always a good test of whether EMF is correctly configured.
Ed Willink
>> Hi
> ...." Any idea?
> Thanks
> Marius
Re: QVTo editor with changing input model [message #917882 is a reply to message #917865] Thu, 20 September 2012 10:24 Go to previous messageGo to next message
On 20.09.2012 16:12, Ed Willink wrote:
> Hi
I'm not sure I'm getting you (or vice versa). Previously, with my
"hand-rolled" runtime Eclipse I had to throw in a small own plugin which
basically used the XSDEcoreBuilder() to generate dynamic Ecore models
from my XSD files and add them to EMFs global registry. I guess this is
process is what you refer to as "magic translation".
But with the Model URI map approach - who would be doing that for me?
The map doesn't accept .xsd files. I could be using my plugin of course
to load the XSDs into the EMF registry, but this way I'd be losing any
chances of dynamic updates upon changes to the XSD.
Marius
Re: QVTo editor with changing input model [message #917917 is a reply to message #917882] Thu, 20 September 2012 11:04 Go to previous messageGo to next message
I don't use XSD much, but my understanding is that you create an Ecore
metamodel from your XSD, so that your XSD files are loadable as EMF
resources.
If you have particular serialisation concerns you customize the
ExtendedMetaData so that your XSD round-trips via an Ecore Resource to
your satisfaction.
That done, you then have a registration so that whenever a *.yourxsd
file is opened, it uses your XSD configuration to provide the EMF
resource for use by a variety of Ecore-based tools of which the Sample
Ecore Editor is the simplest test that *.yourxsd is indeed correctly
registered.
Ed Willink
>> Hi
> Regards
> Marius
Re: QVTo editor with changing input model [message #918597 is a reply to message #917917] Fri, 21 September 2012 02:50 Go to previous messageGo to next message
> resources.
> your satisfaction.
> registered.
Well, so far I've loaded XSD as dynamic Ecore at runtime. A while ago I
tried the "offline" approach you mentioned and the roundtrip was broken.
The bug should have been fixed by now though. But anyway roundtrip would
be an extra gimmick which I don't necessarily need right now. Having a
fairly simple process from XSD -> .ecore would be ok. I'll try that
again when I have some time.
I'm not sure if I got you right regarding another point: if I change the
..ecore file in anyway, would the QVT editor pick that up, even if I need
to close it once? Or even more explicitly: will I not(!) have to restart
eclipse? That would be really my #1 requirement. I tried it yesterday
and after the change the editor somehow totally forgot about that (just
changed) model and even the "modeltype ..." was squiggled with an error
marker.
Marius
Re: QVTo editor with changing input model [message #918722 is a reply to message #918597] Fri, 21 September 2012 05:28 Go to previous messageGo to next message
Needing to close Eclipse is definitely unacceptable and certainly a bug.
Generally this only occurs with applications that abuse the global
registries; hopefully not QVTo.
Needing to close the editor is a pain but in principle EMF does not
support meta-model mutation, so this should only occur in model rather
than meta-model editors. Xtext is very good at spotting *.ecore changes.
Other tools seem to be patchy; hence I suspect that QVTo is imperfect here.
If you can provide a repro, please submit a Bugzilla.
Ed Willink
>> resources.
>> your satisfaction.
>> registered.
> marker.
> Thanks
> Marius
Re: QVTo editor with changing input model [message #921503 is a reply to message #917773] Mon, 24 September 2012 03:05 Go to previous messageGo to next message
> Hi
For some reason the QVT builder doesn't always run properly. Very often
I get the stack trace below. For all I can see, the plugin containing
AggregateProxyPackage is present. Is there anything I can do about this?
java.lang.NoClassDefFoundError: Could not initialize class
org.eclipse.emf.facet.aggregate.metamodel.v0_2_0.aggregate.internal.aggregateProxy.AggregateProxyPackage
at sun.misc.Unsafe.ensureClassInitialized(Native Method)
at
sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(UnsafeFieldAccessorFactory.java:43)
at
sun.reflect.ReflectionFactory.newFieldAccessor(ReflectionFactory.java:140)
at java.lang.reflect.Field.acquireFieldAccessor(Field.java:936)
at java.lang.reflect.Field.getFieldAccessor(Field.java:917)
at java.lang.reflect.Field.get(Field.java:376)
at
org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor.getEPackage(RegistryReader.java:273)
at
org.eclipse.emf.ecore.impl.EPackageImpl$1.getEPackage(EPackageImpl.java:162)
at
org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:127)
at
org.eclipse.m2m.internal.qvt.oml.emf.util.mmregistry.EmfMetamodelDesc.getModel(EmfMetamodelDesc.java:64)
at
org.eclipse.m2m.internal.qvt.oml.emf.util.mmregistry.EmfMetamodelDesc.getLoadStatus(EmfMetamodelDesc.java:86)
at
org.eclipse.m2m.internal.qvt.oml.emf.util.mmregistry.MetamodelRegistry.toEPackageRegistry(MetamodelRegistry.java:85)
at
org.eclipse.m2m.internal.qvt.oml.compiler.CompilerUtils.getEPackageRegistry(CompilerUtils.java:106)
at
org.eclipse.m2m.internal.qvt.oml.compiler.QVTOCompiler.getEPackageRegistry(QVTOCompiler.java:569)
at
org.eclipse.m2m.internal.qvt.oml.compiler.QVTOCompiler.parse(QVTOCompiler.java:272)
at
org.eclipse.m2m.internal.qvt.oml.compiler.QVTOCompiler.doCompile(QVTOCompiler.java:416)
at
org.eclipse.m2m.internal.qvt.oml.compiler.QVTOCompiler.compileSingleFile(QVTOCompiler.java:373)
at
org.eclipse.m2m.internal.qvt.oml.compiler.QVTOCompiler.compile(QVTOCompiler.java:218)
at
org.eclipse.m2m.internal.qvt.oml.project.builder.QVTOBuilder.rebuildAll(QVTOBuilder.java:223)
at
org.eclipse.m2m.internal.qvt.oml.project.builder.QVTOBuilder.fullBuild(QVTOBuilder.java:109)
at
org.eclipse.m2m.internal.qvt.oml.project.builder.QVTOBuilder.build(QVTOBuilder.java:92)
at
org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at
org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at
org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at
org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Re: QVTo editor with changing input model [message #921628 is a reply to message #921503] Mon, 24 September 2012 05:34 Go to previous messageGo to next message
HI
I'm afraid that I see EMF Facet in the stack trace.
My knowledge of EMF Facet is limited, but it appears that they do
'clever' things to meta-models, and from my experience they do not
always avoid causing problems for standard dumb users.
"doesn't always" and "Very often" are a strong indication that some
protocol is being abused; probably meta-model registries.
If you want to use EMF Facet in conjunction with other tools, you will
need to help contribute rather than consume the tools.
I suggest identifying
- a scenario that always works; possibly the first run after starting
Eclipse
- a similar scenario that never works; possibly just a rerun of the first
and create dumps of various meta-models and registries to find out the
difference and then determine where that difference comes from.
My guess is that the problem is that either
some registration is missing and gets created or changed
some meta-model element evolves in response to EMF Facet usage
The NoClassDefFoundError suggests that EMF Facet is being activated
unexpectedly. Try putting it on the classpath explicitly.
Ed Willink
>> Hi
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
Re: QVTo editor with changing input model [message #921783 is a reply to message #921628] Mon, 24 September 2012 08:22 Go to previous messageGo to next message
Just for completeness, I've taken the issue over to the EMF news group:
http://www.eclipse.org/forums/index.php/m/921753/
Summary thus far: I've been able to locate an issue with the order of
initialization of the various Aggregate*Packages.
Marius
Re: QVTo editor with changing input model [message #921911 is a reply to message #921783] Mon, 24 September 2012 10:46 Go to previous messageGo to next message
One more question: it seems like a silly question, but for what purpose
do I actually need the QVT builder? I noticed that if I uncheck it in
the properties, I still get a working QVT editor with syntax coloring
and completion?!
Marius
Re: QVTo editor with changing input model [message #921923 is a reply to message #921911] Mon, 24 September 2012 10:58 Go to previous messageGo to next message
> and completion?!
Hm, probably for the error markers if I *don't* open the QVT editor, right?
Marius
Re: QVTo editor with changing input model [message #922007 is a reply to message #921911] Mon, 24 September 2012 12:40 Go to previous message
The same as why do you need a Java builder. If you only edit you never
need to compile.
Since QVTo doesn't currently persist compiled artefacts, the only
benefit is probably refreshing of problem markers on closed files.
Ed Willink
> and completion?!
> Marius
Previous Topic:Exception when invoking a helper method
Next Topic:[QVTo] Multiple Output Models
Current Time: Mon Jun 23 09:46:25 EDT 2025
Powered by FUDForum. Page generated in 0.14200 seconds
