ScrollingGraphicalViewer: Auto right scroll when width increases [message #916643] |
Wed, 19 September 2012 09:12 |
Jason Lin Messages: 12 Registered: July 2012 |
(1)First Scenario
Figure 1. The element in the most right of canvas.
Figure 2. Hover the element,the button pad shows and the canvas increase size, but not scroll right.
Thus we can't see the right area of context button pad.
(2) Seconde Scenario
Figure 3. Expand the element and the scrollbars shows but not scroll right
Figure 4. Scroll manually
I want to solve this problem by:
(1) add border/inset to ScrollingGraphicalViewer. But can't find it how to add it.
(This approach is not fit to second scenario)
(2) auto scroll to right if the size expand because of drag&drop or others.
Unfortunately, I still can't implement even one of them in graphiti after reading some articles and codes for hours.
So,
If the approach is incorrect, then what is the right way?
If correct, how to do it?
Thanks in advanced.
Jason, Lin
Attachment: 1.png
(Size: 11.00KB, Downloaded 1073 times) -
Attachment: 2.png
(Size: 12.81KB, Downloaded 1025 times) -
Attachment: 3.png
(Size: 13.30KB, Downloaded 1038 times) -
Attachment: 4.png
(Size: 18.40KB, Downloaded 1069 times)
[Updated on: Wed, 19 September 2012 09:17] Report message to a moderator
Re: ScrollingGraphicalViewer: auto right scrolling when expand [message #1229175 is a reply to message #1070104] |
Wed, 08 January 2014 21:41 |
I've found that I can automatically scroll the canvas when needed (for example to fully show the Button Pad) using a Job that runs in the UI thread. In my ToolBehaviorProvider I override getContextButtonPad() which is called by the Graphiti framework to get the contents of the Button Pad. The following code calculates the top, right and bottom edges of the visible area of the canvas and the Button Pad. The IContextButtonPadData returned from the super() call contains the location and size of the Button Pad. According to the Graphiti javadoc for IContextButtonPadData.getPadLocation(), "These are not the outer bounds of the context button pad, but the inner rectangle, around which the context button pad is shown"; the extra 30 pixels account for the actual width and height of the Pad itself.
The 1/2 second start delay when scheduling the job prevents the canvas from jittering when the mouse is unintentionally moved over a shape.
IContextButtonPadData data = super.getContextButtonPad(context);
final FigureCanvas canvas = (FigureCanvas)editor.getGraphicalViewer().getControl();
Rectangle canvasBounds = canvas.getViewport().getBounds();
final int hOffset = canvas.getViewport().getHorizontalRangeModel().getValue();
final int vOffset = canvas.getViewport().getVerticalRangeModel().getValue();
final int canvasRight = canvasBounds.width + hOffset;
final int canvasBottom = canvasBounds.height + vOffset;
final int canvasTop = vOffset;
IRectangle padBounds = data.getPadLocation();
final int padRight = padBounds.getX() + padBounds.getWidth() + 30;
final int padTop = padBounds.getY() - 30;
final int padBottom = padBounds.getY() + padBounds.getHeight() + 30;
if (padRight>canvasRight || padTop<canvasTop || padBottom>canvasBottom) {
Job job = new Job("scroll") {
protected IStatus run (IProgressMonitor monitor) {
Display.getDefault().asyncExec(new Runnable() {
public void run() {
if (padRight>canvasRight)
canvas.scrollToX(hOffset + padRight - canvasRight);
if (padTop<canvasTop)
canvas.scrollToY(vOffset + padTop - canvasTop);
if (padBottom>canvasBottom)
canvas.scrollToY(vOffset + padBottom - canvasBottom);
return Status.OK_STATUS;
job.schedule(600);
Hope this helps.
Bob
Re: ScrollingGraphicalViewer: auto right scrolling when expand [message #1229899 is a reply to message #1229175] |
Fri, 10 January 2014 13:46 |
After playing around with this some more, I have decided to use another approach - the proposed solution is kind of annoying because it still causes the diagram canvas to jitter as the mouse is moved across shapes.
Instead I've decided to increase the size of the canvas' margin border, which adds enough space on all edges of the canvas to display the button pad. This needs to be done immediately after setting the Diagram into the Graphical Viewer contents, like so:
GraphicalViewer viewer = getGraphicalViewer();
viewer.setContents(diagram);
EditPart ep = viewer.getRootEditPart().getContents();
if (ep instanceof AbstractGraphicalEditPart) {
IFigure fig = ((AbstractGraphicalEditPart)ep).getFigure();
fig.setBorder(new MarginBorder(50));
This can usually be handled in the Diagram Editor's initializeGraphicalViewer() method.
FUDForum. Page generated in 0.01838 seconds
