Home » Newcomers » Newcomers » Behavior of content assist
Behavior of content assist [message #916502] Wed, 19 September 2012 04:57 Go to next message
Essoje Oliveira de Almeida is currently offline Essoje Oliveira de AlmeidaFriend
Is there any way to change the key behavior of the content assist of java?
I'm using the Juno release, and I'd like to make so that the only key that confirms adding the content selected in the content assist window to be <Enter> and nothing else.
Pressing <Spacebar> or <=> will confirm the selection and add space or = after it as well, but that's bad when used with auto-completion with a trigger like ".(abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ@" (it works like intellisense of Visual Studio), because as simple as "String s = null;" forces me to press <ESC> then space after the "String s" or it'll just name it "String string ", which is not the behavior I want or expect.
Thanks in advance.
Re: Behavior of content assist [message #916665 is a reply to message #916502] Wed, 19 September 2012 09:40 Go to previous message
Dani Megert is currently offline Dani MegertFriend
> java?
No. See https://bugs.eclipse.org/348857
Dani
> a trigger like
> or expect.
> Thanks in advance.
Previous Topic:CFeclipse
Next Topic:Problem with marker for printStackTrace
Current Time: Thu Jun 30 00:35:37 GMT 2022
Powered by FUDForum. Page generated in 0.04528 seconds
