Re: Getting xDebug working [message #918917 is a reply to message #916386] |
Fri, 21 September 2012 13:28 |
On 2012-09-19 02:41, Ben Warrick wrote:
> I'm trying to get xDebug working. I've run out of ideas and have
> followed a number of tutorials. I'm running Kubuntu 11.10 and Eclipse 3.7.0
> PDT and xDebug are both installed. I have the following setting under
> php->debug
> PHP Debugger: XDebug
> Server: Default PHP Web Server
> PHP Executable: System PHP
> The following is the config file created when I installed xDebug
> (/etc/php5/conf.d/xdebug.ini) which contains the following:
> zend_extension=/usr/lib/php5/20090626/xdebug.so
> xdebug.remote_enable=on xdebug.remote_handler=dbgp xdebug.remote_port=9000
> I reloaded apache after adding the last three lines, and I confirmed the
> zend_extension path. I also restarted Ecplipse.
> Any advice would be great. Thanks.
Check that Eclipse's web browser settings are correct.
Window/Preferences/General/Web Browser/external Web Browsers/Edit settings
If eclipse can't launch the browser (even an external browser), it'll
wait forever to come up
my 2 cents,
Knut
FUDForum. Page generated in 0.03509 seconds
