Problem in testing remote machine using agent controller [message #123051] |
Tue, 12 February 2008 05:56 |
Originally posted by: swati_gkd.rediffmail.com
(Eclipse 3.3.0, TPTP 4.4, Agent Controller 4.4)
I could launch the eclipse from windows to Linux for TPTP automation
using Agent controller.
I am facing another problem.
Consider the scenario: Start the Agent Controller on Linux-64bit
(remote) machine
1: Launch the eclipse using ant script (tptp:execution task) to
remote machine using deployment file for Linux.
The eclipse gets launched and starts replaying recorded tests. I have
a set of recorded tests in another perspective (not default java). When
eclipse starts executing tests in the respective perspective eclipse
crashes.... .
2: When I try to execute tests for the second time without stopping
agent controller, Test continues by launching eclipse perspective and
passes. This is very strange behavior. For both the cases a new workspace
is used.
3: After successful testing, If I try to test once again then even
the eclipse launch fails.
I have tried this for many times. Same cash takes place for the first
time from the agent controller started. This is very strange behavior.
When I try to execute the test case from eclipse in standard mode
using the respective deployment (for Linux) same crash takes place and a
core dumps to the bin directory of agent controller.
What can be the problem. Is it with agent controller problem? Is it a
known issue?
Please let me know the solution to resolve this problem.
Thanks and Regards,
Swati
Re: Problem in testing remote machine using agent controller [message #123482 is a reply to message #123051] |
Wed, 20 February 2008 07:21 |
Swati wrote:
> Hello,
> (remote) machine
> crashes.... .
> is used.
> known issue?
> Thanks and Regards,
> Swati
The generated crash log ( hs_err_pid*.log )file has following contents
(snippet of file) :-
j
org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/la ng/Object;)Ljava/lang/Object;+149
j
org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/l ang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
v ~StubRoutines::call_stub
j
sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;+0
j
sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
j
sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
j
java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+111
j
org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lan g/String;[Ljava/net/URL;)V+210
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/Strin g;)V+114
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+ 4
j org.eclipse.equinox.launcher.Main.main([Ljava/lang/String;)V +10
j org.eclipse.core.launcher.Main.main([Ljava/lang/String;)V+1
Please help me to solve this problem. Thanks in advanced.
-Swati
Re: Problem in testing remote machine using agent controller [message #124088 is a reply to message #123482] |
Mon, 25 February 2008 12:42 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Swati,
This appears to be a defect in the test execution on the remote machine.
Can you reproduce the same behavor when using the local workbench UI to
launch the AGR tests on the remote machine? If so, this would be an AGR
defect and
in TPTP 4.5, the AGR was moved from a Technology Preview component to an
As-Is component. As-Is components are primarily provided for prior users
but imply no support (for example, defects, news group, and mailing lists).
If not, please open a defect against the ASF runtime with the details in
this post.
Paul
"Swati" <swati_gkd@rediffmail.com> wrote in message
news:4c92eda7c11979f668c875b266287381$1@www.eclipse.org...
> Swati wrote:
>> Hello,
>> I am facing another problem. Consider the scenario: Start the Agent
>> Controller on Linux-64bit (remote) machine
>> crashes.... .
>> is used.
>> first time from the agent controller started. This is very strange
>> behavior.
>> known issue?
>> Thanks and Regards,
>> Swati
> j
> j
> j
> j
> j
> j
> j
> -Swati
FUDForum. Page generated in 0.04177 seconds
