Password Required Query [message #916002] |
Tue, 18 September 2012 11:39  |
Alan Farroll Messages: 60 Registered: June 2012 |
Member |
I am fairly new to Eclipse and Java so require some guidance on a question.
Recently when I start Eclipse each day a small window appears title "Password Required", and can be seen in the attached file.
I have tried my organisation network login a number of times but it continouously appears about 6 or 7 times then stops. Can anyone tell me what this is for please?
Is it to do with an addin from the Eclipse Marketplace perhaps?
Thanks in advance
AJF
[Updated on: Tue, 18 September 2012 11:40] Report message to a moderator
Re: Password Required Query [message #916808 is a reply to message #916649] |
Wed, 19 September 2012 13:49  |
I say "bogus" because that dialog is not telling you what the credentials are used for. I would not type anything in there.
If you go to Help > About Eclipse there should be a button called Installation Details. That would reveal other plugins that may be responsible for the dialog.
Denis Roy
Eclipse Webmaster -- webmaster@eclipse.org
FUDForum. Page generated in 0.03310 seconds
