Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » How to create a copy of an EObject with non-null Resource
Re: How to create a copy of an EObject with non-null Resource [message #122958 is a reply to message #122955] |
Sat, 24 May 2008 16:39 |
Lars,
Ideally it would be tolerant of a null resource. You'd need to access
the resource set and create a new resource of the appropriate type to
contain the copy, i.e.,
original.eResource().getResourceSet().createResource(...).ge tContents().add(copy)...
Lars Schneider wrote:
> I think this problem is better of in this newsgroup.
>> I have a little problem using EcoreUtil.copy(EObject) because the
>> eResource() of that copy returns null.
>> More precisely I want to copy the root of a model, change it and
>> compare it to the original with EMF Compare. I think the following
>> code snippet explains it best:
>> EObject copy = EcoreUtil.copy(original);
>> Transformation trans = new Transformation(copy);
>> trans.transform(); // changes copy
>> MatchModel match = null;
>> try {
>> match = MatchService.doMatch(original, copy
>> Collections.<String, Object> emptyMap());
>> } catch (InterruptedException e) {
>> e.printStackTrace();
>> The problem is that doMatch(...) ends up in a NullPointerException
>> because the resource of copy is null. Does anyone have an idea how to
>> solve this problem? I think I can either set the resource manually or
>> get another IMatchEngine implementation. But I don't know how to.
>> Lars
Re: How to create a copy of an EObject with non-null Resource [message #122963 is a reply to message #122961] |
Mon, 26 May 2008 07:22 |
--------------070501080608090002050601
Content-Type: text/plain; charset=UTF-8; format=flowed
Lars,
As Cédric mentionned, the latest builds should be tolerant to null
resources, though since you're using EMF Compare you could also take a
look at ModelUtils#createResource() and ModelUtils#attachResource()
which we mainly use in our unit tests to copy EObjects and compare them
to one another.
Laurent Goubet
Obeo
Cédric brun a écrit :
> Hi Lars,
> What EMF Compare build are you using ? The RC1 build should have fixed this
> NPE (bug 230347 - see the release
> notes :http://www.eclipse.org/modeling/emft/news/relnotes.php?proj ect=compare&version=0.8.0RC1 )
> You should not have to provide your own match engine for such a thing :)
> Cédric
>>> Hi,
>>> More precisely I want to copy the root of a model, change it and compare
>>> it to the original with EMF Compare. I think the following code snippet
>>> explains it best:
>>> try {
>>> Lars
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------070501080608090002050601--
Re: How to create a copy of an EObject with non-null Resource [message #123005 is a reply to message #122971] |
Tue, 27 May 2008 13:21 |
--------------050408070907090603030501
Lars,
Yup, GenericMatchEngine#modelMatch() does his work on the resource and
will fail if it is null, though contentMatch() shouldn't. What puzzles
me though is that GenericMatchEngine#hasSameURI() at ligne 1174 is :
if (obj1.eResource() != null && obj2.eResource() != null)
which means you're getting an NPE since one of the two compared objects
are null, not their resources... Could you provide us with the model
you're using as input? As a side note, did you take a look at
ModelUtils#attachResource() to see if it would solve the problem?
Laurent Goubet
Obeo
Lars Schneider a écrit :
> and also with a doContentMatch I get a NullPointerException
> java.lang.NullPointerException
> at
> org.eclipse.emf.compare.match.engine.GenericMatchEngine.hasS ameUri(GenericMatchEngine.java:1174)
> at
> org.eclipse.emf.compare.match.engine.GenericMatchEngine.isSi milar(GenericMatchEngine.java:593)
> at
> org.eclipse.emf.compare.match.engine.GenericMatchEngine.cont entMatch(GenericMatchEngine.java:252)
> at
> org.eclipse.emf.compare.match.service.MatchService.doContent Match(MatchService.java:118)
>> Hi Cédric,
>> I updated to 0.8.0RC1 and still get a NullPointerException.
>> at
>> org.eclipse.emf.compare.match.engine.GenericMatchEngine.filt erUnused(GenericMatchEngine.java:1094)
>> at
>> org.eclipse.emf.compare.match.engine.GenericMatchEngine.doMa tch(GenericMatchEngine.java:907)
>> at
>> org.eclipse.emf.compare.match.engine.GenericMatchEngine.mode lMatch(GenericMatchEngine.java:331)
>> at
>> org.eclipse.emf.compare.match.service.MatchService.doMatch(M atchService.java:174)
>> GenericMatchEngine.doMatch calls
>> result = doMatch(leftRoot.eResource(), rightRoot.eResource(), monitor);
>> in line 331 which is obviously null if rightRoot has a null Resource.
>> Cédric brun wrote:
>>> Hi Lars,
>>> fixed this
>>> notes
>>> Cédric
>>>>> Hi,
>>>>> compare
>>>>> snippet
>>>>> explains it best:
>>>>> try {
>>>>> Lars
--------------050408070907090603030501--
Re: How to create a copy of an EObject with non-null Resource [message #123045 is a reply to message #123005] |
Tue, 27 May 2008 20:27 |
Lars Schneider Messages: 50 Registered: July 2009 |
Member |
It seems that I still have another version of GenericMatchEngine. My
Method hasSameURI looks like this:
private boolean hasSameUri(EObject obj1, EObject obj2) {
return
obj1.eResource().getURIFragment(obj1).equals(obj2.eResource( ).getURIFragment(obj2));
ModelUtils#attachResource() really solves the problem, so I can use
GenericMatchEngine#doMatch(). But there is another strange behavior.
I am using this snippet and it does NOT work because "diff" is partly wrong:
-- snip
EObject lRoot = null;
EObject rRoot = null;
try {
rRoot = ModelUtils.load(modelURI, resourceSet);
ModelUtils.attachResource(modelURI, rRoot);
lRoot = ModelUtils.load(modelURI, resourceSet);
ModelUtils.attachResource(modelURI, lRoot);
} catch (IOException e) {
Resource lResource = lRoot.eResource();
Resource rResource = rRoot.eResource();
Map<String, Object> options = Collections
.<String, Object> emptyMap();
try {
match = MatchService.doMatch(lRoot, rRoot, options);
//match = MatchService.doContentMatch(lRoot, rRoot, options);
//match = MatchService.doResourceMatch(lResource, rResource, options);
DiffModel diff = DiffService.doDiff(match);
ModelInputSnapshot snapshot = DiffFactory.eINSTANCE
.createModelInputSnapshot();
snapshot.setMatch(match);
snapshot.setDiff(diff);
CompareUI.openCompareDialog(
new ModelCompareEditorInput(modelInputSnapshot));
-- snap
But changing
into
match = MatchService.doMatch(rRoot, lRoot, options);
WORKS!
Of course, the changings are the wrong way round. I am really desperate
because it depends on the right order.
I attached the model I am working with. It is unfortunately in german
but that shouldn't matter.
By the way I am testing the Hide Property Refactoring with class Konto
(account) and property saldo (balance).
gets this diff:
Attribute visibility in saldo has changed from public to private
org.eclipse.uml2.uml.internal.impl.OperationImpl@12c662b (name:
getSaldo, visibility: public) (isLeaf: false, isStatic: false,
isAbstract: false, concurrency: sequential) (isQuery: false) has been
*removed*
org.eclipse.uml2.uml.internal.impl.OperationImpl@144f423 (name:
setSaldo, visibility: public) (isLeaf: false, isStatic: false,
*removed*
but they are *added*
whereas
provides a correct diff:
Attribute visibility in saldo has changed from private to public
org.eclipse.uml2.uml.internal.impl.OperationImpl@847410 (name:
removed
org.eclipse.uml2.uml.internal.impl.OperationImpl@12a6200 (name:
removed
thanks for your patience,
lars
laurent Goubet wrote:
> Lars,
> Laurent Goubet
> Obeo
>> at
>> at
>> at
>> at
>>> Hi Cédric,
>>> at
>>> at
>>> at
>>> at
>>> Cédric brun wrote:
>>>> Hi Lars,
>>>> fixed this
>>>> notes
>>>> thing :)
>>>> Cédric
>>>>>> Hi,
>>>>>> compare
>>>>>> snippet
>>>>>> explains it best:
>>>>>> try {
>>>>>> Lars
Re: How to create a copy of an EObject with non-null Resource [message #123058 is a reply to message #123045] |
Tue, 27 May 2008 20:28 |
Member |
--------------000900080408050704040302
sorry, here comes the attachment
> return
> wrong:
> -- snip
> try {
> try {
> -- snap
> But changing
> into
> WORKS!
> gets this diff:
> *removed*
> *removed*
> whereas
> removed
> removed
> lars
>> Lars,
>> objects are null, not their resources... Could you provide us with the
>> model you're using as input? As a side note, did you take a look at
>> Laurent Goubet
>> Obeo
>>> at
>>> at
>>> at
>>> at
>>>> Hi Cédric,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Cédric brun wrote:
>>>>> Hi Lars,
>>>>> fixed this
>>>>> notes
>>>>> thing :)
>>>>> Cédric
>>>>>>> Hi,
>>>>>>> compare
>>>>>>> snippet
>>>>>>> explains it best:
>>>>>>> try {
>>>>>>> how to
>>>>>>> manually or
>>>>>>> Lars
Content-Type: text/xml;
name="BeispielDiagramm.uml"
Content-Disposition: inline;
filename="BeispielDiagramm.uml"
<uml:Model xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xmi:id="_1gYToAiEEdy3Go1fIkI-Ow" name="Unser Beispiel">
<packagedElement xmi:type="uml:Package" xmi:id="_4vqTEAiEEdy3Go1fIkI-Ow" name="bank">
<packagedElement xmi:type="uml:Package" xmi:id="_ger0cAniEdy7h-Bku2skcw" name="kunde"/>
<packagedElement xmi:type="uml:Package" xmi:id="_nCUgkAniEdy7h-Bku2skcw" name="konto"/>
<packagedElement xmi:type="uml:Class" xmi:id="_8HvCIAiEEdy3Go1fIkI-Ow" name="Konto">
<ownedAttribute xmi:id="_MjqMkAiGEdy3Go1fIkI-Ow" name="saldo" visibility="public" type="_32KCwAiFEdy3Go1fIkI-Ow"/>
<ownedOperation xmi:id="_EQoTEA3vEdys69yIcYldpA" name="einzahlen"/>
<ownedOperation xmi:id="_EQoTEQ3vEdys69yIcYldpA" name="abheben"/>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_jDS30AiFEdy3Go1fIkI-Ow" name="SparKonto">
<generalization xmi:id="_RKb4gAiIEdyR7ahpixc--g" general="_8HvCIAiEEdy3Go1fIkI-Ow"/>
<ownedAttribute xmi:id="_ExyywAiGEdy3Go1fIkI-Ow" name="kontonummer" type="_22hxwAiFEdy3Go1fIkI-Ow"/>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_jYTegAiFEdy3Go1fIkI-Ow" name="GiroKonto">
<generalization xmi:id="_T2sqcAiIEdyR7ahpixc--g" general="_8HvCIAiEEdy3Go1fIkI-Ow"/>
<ownedAttribute xmi:id="_rQ94UBn_Ed2G-vAjw5_nJw" name="kontonummer" type="_22hxwAiFEdy3Go1fIkI-Ow"/>
<ownedOperation xmi:id="_CnOsUA3vEdys69yIcYldpA" name="ueberweisen"/>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_XKHqYAiFEdy3Go1fIkI-Ow" name="Kunde">
<ownedAttribute xmi:id="_izWLgAkuEdyUabkMjTLepg" name="" type="_X1CPoAiFEdy3Go1fIkI-Ow" isUnique="false">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_pZMeIAkuEdyUabkMjTLepg" value="1"/>
<defaultValue xmi:type="uml:LiteralString" xmi:id="_ki9H8AkuEdyUabkMjTLepg" value=""/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_XX-gMAiFEdy3Go1fIkI-Ow" name="PrivatKunde">
<generalization xmi:id="_UdSwYAiIEdyR7ahpixc--g" general="_XKHqYAiFEdy3Go1fIkI-Ow"/>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_Xl_HAAiFEdy3Go1fIkI-Ow" name="GeschaeftsKunde">
<generalization xmi:id="_WrKWIAiIEdyR7ahpixc--g" general="_XKHqYAiFEdy3Go1fIkI-Ow"/>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_X1CPoAiFEdy3Go1fIkI-Ow" name="Adresse"/>
<packagedElement xmi:type="uml:PrimitiveType" xmi:id="_22hxwAiFEdy3Go1fIkI-Ow" name="int"/>
<packagedElement xmi:type="uml:PrimitiveType" xmi:id="_3vAR4AiFEdy3Go1fIkI-Ow" name="String"/>
<packagedElement xmi:type="uml:PrimitiveType" xmi:id="_32KCwAiFEdy3Go1fIkI-Ow" name="double"/>
<packagedElement xmi:type="uml:Association" xmi:id="_lsHFAA3nEdys69yIcYldpA" name="Kunde_Konto" memberEnd="_x6KWQA3nEdys69yIcYldpA _P4cH4A3oEdys69yIcYldpA">
<ownedEnd xmi:id="_x6KWQA3nEdys69yIcYldpA" name="kontoBesitzer" type="_XKHqYAiFEdy3Go1fIkI-Ow" association="_lsHFAA3nEdys69yIcYldpA"/>
<ownedEnd xmi:id="_P4cH4A3oEdys69yIcYldpA" name="konten" type="_8HvCIAiEEdy3Go1fIkI-Ow" association="_lsHFAA3nEdys69yIcYldpA">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_YNr7kA3oEdys69yIcYldpA" value="*"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_Xp1noA3oEdys69yIcYldpA"/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Association" xmi:id="_13aZgA3oEdys69yIcYldpA" name="Kunde_Adresse" memberEnd="_13aZgQ3oEdys69yIcYldpA _13aZgg3oEdys69yIcYldpA">
<ownedEnd xmi:id="_13aZgQ3oEdys69yIcYldpA" name="wohnhaftenKunden" type="_XKHqYAiFEdy3Go1fIkI-Ow" association="_13aZgA3oEdys69yIcYldpA">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_V5RzgA3pEdys69yIcYldpA" value="*"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_VQZOkA3pEdys69yIcYldpA"/>
</ownedEnd>
<ownedEnd xmi:id="_13aZgg3oEdys69yIcYldpA" name="kundenAdressen" type="_X1CPoAiFEdy3Go1fIkI-Ow" association="_13aZgA3oEdys69yIcYldpA">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_13aZgw3oEdys69yIcYldpA" value="*"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_13aZhA3oEdys69yIcYldpA" value="1"/>
</ownedEnd>
</packagedElement>
</packagedElement>
</uml:Model>
--------------000900080408050704040302--
Re: How to create a copy of an EObject with non-null Resource [message #123282 is a reply to message #123058] |
Wed, 28 May 2008 09:56 |
--------------000305010601080701030908
This would seem like a problem in the DiffEngine, I'll test this with
your model ASAP. Though the fact your GenericMatchEngine is at an older
version puzzles me ... the build came 3 days after I commited these
changes ;(
>> return
>> wrong:
>> -- snip
>> try {
>> try {
>> options);
>> -- snap
>> But changing
>> into
>> WORKS!
>> desperate because it depends on the right order.
>> gets this diff:
>> *removed*
>> *removed*
>> whereas
>> removed
>> removed
>> lars
>>> Lars,
>>> and will fail if it is null, though contentMatch() shouldn't. What
>>> puzzles me though is that GenericMatchEngine#hasSameURI() at ligne
>>> 1174 is :
>>> the model you're using as input? As a side note, did you take a look
>>> at ModelUtils#attachResource() to see if it would solve the problem?
>>> Laurent Goubet
>>> Obeo
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> Hi Cédric,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> monitor);
>>>>> Cédric brun wrote:
>>>>>> Hi Lars,
>>>>>> fixed this
>>>>>> notes
>>>>>> thing :)
>>>>>> Cédric
>>>>>>>> Hi,
>>>>>>>> compare
>>>>>>>> snippet
>>>>>>>> explains it best:
>>>>>>>> try {
>>>>>>>> how to
>>>>>>>> manually or
>>>>>>>> Lars
--------------000305010601080701030908--
Re: How to create a copy of an EObject with non-null Resource [message #123375 is a reply to message #123282] |
Wed, 28 May 2008 12:25 |
--------------020602020701040309050601
Lars,
Okay, just tried this via the UI ... and it worked as expected. Yet I
think your problem comes from the URI you use for your models. The
snippet you provided will never produce differences since you load the
same model twice without ever modifiying it, so I think you modified the
snippet for visibility ;).
The generic diff engine doesn't know which resource is the left model
and which is the right when computing additions/deletions. All we have
are the model URIs as can be retrieved via MatchModel#getLeftModel() and
MatchModel#getRightModel() (these are Strings instead of resources ...
AFAIK, this was because of legacy code). If you have the same URI for
both ... the diff engine will only see *removed* elements.
Something like this should work as you are expecting (I think you were
copying your models so the following will make use of EcoreUtil.copy()) :
try {
rRoot = EcoreUtil.copy(lRoot);
// This URI should use the same extension, other than that, it can
point to anything if this copy isn't meant to be saved
ModelUtils.attachResource(copyModelURI, rRoot);
And a little update : EMF Compare 0.8RC2 has been built and the changes
to GenericMatchEngine should have made its way through this time. The
build should be promoted today.
Laurent Goubet
Obeo
> changes ;(
>>> return
>>> wrong:
>>> -- snip
>>> try {
>>> try {
>>> options);
>>> -- snap
>>> But changing
>>> into
>>> WORKS!
>>> Konto (account) and property saldo (balance).
>>> gets this diff:
>>> *removed*
>>> *removed*
>>> whereas
>>> removed
>>> removed
>>> lars
>>>> Lars,
>>>> 1174 is :
>>>> Laurent Goubet
>>>> Obeo
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>> Hi Cédric,
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> monitor);
>>>>>> Cédric brun wrote:
>>>>>>> Hi Lars,
>>>>>>> fixed this
>>>>>>> notes
>>>>>>> thing :)
>>>>>>> Cédric
>>>>>>>>> Hi,
>>>>>>>>> and compare
>>>>>>>>> snippet
>>>>>>>>> explains it best:
>>>>>>>>> try {
>>>>>>>>> how to
>>>>>>>>> manually or
>>>>>>>>> Lars
--------------020602020701040309050601--
Re: How to create a copy of an EObject with non-null Resource [message #123388 is a reply to message #123375] |
Wed, 28 May 2008 13:02 |
Laurent,
Comments below.
> Lars,
> the snippet for visibility ;).
> and MatchModel#getRightModel() (these are Strings instead of resources
> ... AFAIK, this was because of legacy code). If you have the same URI
> for both ... the diff engine will only see *removed* elements.
I can see the BIDI defects now about the fact that the left model
appears on the right in the UI. :-P
> try {
> changes to GenericMatchEngine should have made its way through this
> time. The build should be promoted today.
> Cheers,
> Laurent Goubet
> Obeo
>> older version puzzles me ... the build came 3 days after I commited
>> these changes ;(
>>>> My Method hasSameURI looks like this:
>>>> return
>>>> partly wrong:
>>>> -- snip
>>>> try {
>>>> try {
>>>> options);
>>>> -- snap
>>>> But changing
>>>> into
>>>> WORKS!
>>>> german but that shouldn't matter.
>>>> gets this diff:
>>>> been *removed*
>>>> been *removed*
>>>> whereas
>>>> been removed
>>>> been removed
>>>> lars
>>>>> Lars,
>>>>> 1174 is :
>>>>> look at ModelUtils#attachResource() to see if it would solve the
>>>>> problem?
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>> Hi Cédric,
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> monitor);
>>>>>>> Resource.
>>>>>>> Cédric brun wrote:
>>>>>>>> Hi Lars,
>>>>>>>> have fixed this
>>>>>>>> notes
>>>>>>>> thing :)
>>>>>>>> Cédric
>>>>>>>>>> Hi,
>>>>>>>>>> the
>>>>>>>>>> and compare
>>>>>>>>>> code snippet
>>>>>>>>>> explains it best:
>>>>>>>>>> try {
>>>>>>>>>> idea how to
>>>>>>>>>> manually or
>>>>>>>>>> to.
>>>>>>>>>> Lars
Re: How to create a copy of an EObject with non-null Resource [message #123402 is a reply to message #123388] |
Wed, 28 May 2008 13:20 |
--------------020801030101010103000600
Ed,
BIDI?
And no ... left appearing in the right also comes from a (discutable)
choice from our side ... and will be reverted back to normal as soon as
we come to https://bugs.eclipse.org/bugs/show_bug.cgi?id=232277 .
Laurent Goubet
Obeo
Ed Merks a écrit :
> Laurent,
> Comments below.
>> Lars,
>> try {
>> Cheers,
>> Laurent Goubet
>> Obeo
>>> these changes ;(
>>>>> return
>>>>> partly wrong:
>>>>> -- snip
>>>>> try {
>>>>> try {
>>>>> options);
>>>>> -- snap
>>>>> But changing
>>>>> into
>>>>> WORKS!
>>>>> gets this diff:
>>>>> been *removed*
>>>>> been *removed*
>>>>> whereas
>>>>> been removed
>>>>> been removed
>>>>> lars
>>>>>> Lars,
>>>>>> 1174 is :
>>>>>> problem?
>>>>>> Laurent Goubet
>>>>>> Obeo
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>> Hi Cédric,
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> monitor);
>>>>>>>> Resource.
>>>>>>>> Cédric brun wrote:
>>>>>>>>> Hi Lars,
>>>>>>>>> have fixed this
>>>>>>>>> notes
>>>>>>>>> thing :)
>>>>>>>>> Cédric
>>>>>>>>>>> Hi,
>>>>>>>>>>> the
>>>>>>>>>>> and compare
>>>>>>>>>>> code snippet
>>>>>>>>>>> explains it best:
>>>>>>>>>>> try {
>>>>>>>>>>> idea how to
>>>>>>>>>>> manually or
>>>>>>>>>>> to.
>>>>>>>>>>> Lars
--------------020801030101010103000600--
Re: How to create a copy of an EObject with non-null Resource [message #123431 is a reply to message #123402] |
Wed, 28 May 2008 14:31 |
--------------010002060507070000070800
Laurent,
Try running Eclipse with -dir rtl. It's even more fun if you use a
Hebrew or Arabic locale and have actual right to left characters it's
even more fun. And if you mix them all up, the fun in simply endless:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=131711
> Ed,
> BIDI?
> as we come to https://bugs.eclipse.org/bugs/show_bug.cgi?id=232277 .
> Laurent Goubet
> Obeo
> Ed Merks a écrit :
>> Laurent,
>> Comments below.
>>> Lars,
>>> I think your problem comes from the URI you use for your models. The
>>> the same model twice without ever modifiying it, so I think you
>>> modified the snippet for visibility ;).
>>> model and which is the right when computing additions/deletions. All
>>> we have are the model URIs as can be retrieved via
>>> MatchModel#getLeftModel() and MatchModel#getRightModel() (these are
>>> Strings instead of resources ... AFAIK, this was because of legacy
>>> code). If you have the same URI for both ... the diff engine will
>>> were copying your models so the following will make use of
>>> EcoreUtil.copy()) :
>>> try {
>>> can point to anything if this copy isn't meant to be saved
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>> with your model ASAP. Though the fact your GenericMatchEngine is at
>>>> an older version puzzles me ... the build came 3 days after I
>>>> commited these changes ;(
>>>>>> return
>>>>>> use GenericMatchEngine#doMatch(). But there is another strange
>>>>>> behavior.
>>>>>> partly wrong:
>>>>>> -- snip
>>>>>> try {
>>>>>> try {
>>>>>> options);
>>>>>> -- snap
>>>>>> But changing
>>>>>> into
>>>>>> WORKS!
>>>>>> gets this diff:
>>>>>> (name: getSaldo, visibility: public) (isLeaf: false, isStatic:
>>>>>> false, isAbstract: false, concurrency: sequential) (isQuery:
>>>>>> false) has been *removed*
>>>>>> (name: setSaldo, visibility: public) (isLeaf: false, isStatic:
>>>>>> whereas
>>>>>> false) has been removed
>>>>>> lars
>>>>>>> Lars,
>>>>>>> resource and will fail if it is null, though contentMatch()
>>>>>>> shouldn't. What puzzles me though is that
>>>>>>> with the model you're using as input? As a side note, did you
>>>>>>> take a look at ModelUtils#attachResource() to see if it would
>>>>>>> solve the problem?
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>> Hi Cédric,
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> monitor);
>>>>>>>>> Resource.
>>>>>>>>> Cédric brun wrote:
>>>>>>>>>> Hi Lars,
>>>>>>>>>> have fixed this
>>>>>>>>>> notes
>>>>>>>>>> a thing :)
>>>>>>>>>> Cédric
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> because the
>>>>>>>>>>>> it and compare
>>>>>>>>>>>> code snippet
>>>>>>>>>>>> explains it best:
>>>>>>>>>>>> try {
>>>>>>>>>>>> idea how to
>>>>>>>>>>>> manually or
>>>>>>>>>>>> how to.
>>>>>>>>>>>> Lars
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Laurent,<br>
<br>
even more fun. And if you mix them all up, the fun in simply endless:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=131711">https://bugs.eclipse.org/bugs/show_bug.cgi?id=131711</a><br>
</blockquote>
<br>
<blockquote cite="mid:g1jm6t$1r2$1@build.eclipse.org" type="cite">Ed,
<br>
<br>
BIDI?
<br>
<br>
we come to <a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=232277">https://bugs.eclipse.org/bugs/show_bug.cgi?id=232277</a> .
<br>
<br>
Laurent Goubet
<br>
Obeo
<br>
<br>
Ed Merks a écrit :
<br>
<blockquote type="cite">Laurent,
<br>
<br>
Comments below.
<br>
<br>
<br>
<blockquote type="cite">Lars,
<br>
<br>
<br>
<br>
.... AFAIK, this was because of legacy code). If you have the same URI
<br>
</blockquote>
<br>
<blockquote type="cite"><br>
<br>
try {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Laurent Goubet
<br>
Obeo
<br>
<br>
<br>
<blockquote type="cite">This would seem like a problem in the
DiffEngine, I'll test this with your model ASAP. Though the fact your
GenericMatchEngine is at an older version puzzles me ... the build came
3 days after I commited these changes ;(
<br>
<br>
<br>
<blockquote type="cite">sorry, here comes the attachment
<br>
<br>
<br>
<blockquote type="cite">It seems that I still have another
version of GenericMatchEngine. My Method hasSameURI looks like this:
<br>
<br>
return
<br>
<br>
<br>
<br>
wrong:
<br>
<br>
-- snip
<br>
<br>
<br>
<br>
try {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
try {
<br>
<br>
<br>
options);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
-- snap
<br>
<br>
But changing
<br>
<br>
into
<br>
<br>
WORKS!
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gets this diff:
<br>
<br>
<br>
*removed*
<br>
<br>
*removed*
<br>
<br>
<br>
<br>
whereas
<br>
<br>
<br>
<br>
<br>
removed
<br>
<br>
removed
<br>
<br>
<br>
lars
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Laurent Goubet
<br>
Obeo
<br>
<br>
<br>
<blockquote type="cite">and also with a doContentMatch I
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi Cédric,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Cédric brun wrote:
<br>
<blockquote type="cite">Hi Lars,
<br>
<br>
this
<br>
<br>
notes
:<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/modeling/emft/news/relnotes.php?proje ct=compare&version=0.8.0RC1"> http://www.eclipse.org/modeling/emft/news/relnotes.php?proje ct=compare&version=0.8.0RC1</a>
<br>
<br>
<br>
<br>
Cédric
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">I think this problem is
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
compare
<br>
<br>
explains it best:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
try {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Lars
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
--------------010002060507070000070800--
Re: How to create a copy of an EObject with non-null Resource [message #618958 is a reply to message #122955] |
Ed Merks Messages: 33137 Registered: July 2009 |
Lars,
>> try {
>> Lars
Ed Merks
Re: How to create a copy of an EObject with non-null Resource [message #618961 is a reply to message #122955] |
Sun, 25 May 2008 18:23 |
Cedric Brun Messages: 431 Registered: July 2009 |
Hi Lars,
Cédric
>> explains it best:
>> try {
>> Lars
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
Re: How to create a copy of an EObject with non-null Resource [message #618963 is a reply to message #122961] |
Lars,
to one another.
Laurent Goubet
Obeo
> Hi Lars,
> Cédric
>>> Hi,
>>> explains it best:
>>> try {
>>> Lars
Re: How to create a copy of an EObject with non-null Resource [message #618981 is a reply to message #122971] |
Lars,
Laurent Goubet
Obeo
> at
> at
> at
> at
>> Hi Cédric,
>> at
>> at
>> at
>> at
>> Cédric brun wrote:
>>> Hi Lars,
>>> fixed this
>>> notes
>>> Cédric
>>>>> Hi,
>>>>> compare
>>>>> snippet
>>>>> explains it best:
>>>>> try {
>>>>> Lars
Re: How to create a copy of an EObject with non-null Resource [message #618992 is a reply to message #123005] |
Member |
return
-- snip
try {
try {
-- snap
But changing
into
WORKS!
gets this diff:
*removed*
*removed*
whereas
removed
removed
lars
> Lars,
> Laurent Goubet
> Obeo
>> at
>> at
>> at
>> at
>>> Hi Cédric,
>>> at
>>> at
>>> at
>>> at
>>> Cédric brun wrote:
>>>> Hi Lars,
>>>> fixed this
>>>> notes
>>>> thing :)
>>>> Cédric
>>>>>> Hi,
>>>>>> compare
>>>>>> snippet
>>>>>> explains it best:
>>>>>> try {
>>>>>> Lars
Re: How to create a copy of an EObject with non-null Resource [message #618994 is a reply to message #123045] |
Member |
> return
> wrong:
> -- snip
> try {
> try {
> -- snap
> But changing
> into
> WORKS!
> gets this diff:
> *removed*
> *removed*
> whereas
> removed
> removed
> lars
>> Lars,
>> Laurent Goubet
>> Obeo
>>> at
>>> at
>>> at
>>> at
>>>> Hi Cédric,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Cédric brun wrote:
>>>>> Hi Lars,
>>>>> fixed this
>>>>> notes
>>>>> thing :)
>>>>> Cédric
>>>>>>> Hi,
>>>>>>> compare
>>>>>>> snippet
>>>>>>> explains it best:
>>>>>>> try {
>>>>>>> how to
>>>>>>> manually or
>>>>>>> Lars
</packagedElement>
</packagedElement>
</packagedElement>
</ownedAttribute>
</packagedElement>
</packagedElement>
</packagedElement>
</ownedEnd>
</packagedElement>
</ownedEnd>
</ownedEnd>
</packagedElement>
</packagedElement>
</uml:Model>
Re: How to create a copy of an EObject with non-null Resource [message #619010 is a reply to message #123058] |
changes ;(
>> return
>> wrong:
>> -- snip
>> try {
>> try {
>> options);
>> -- snap
>> But changing
>> into
>> WORKS!
>> gets this diff:
>> *removed*
>> *removed*
>> whereas
>> removed
>> removed
>> lars
>>> Lars,
>>> 1174 is :
>>> Laurent Goubet
>>> Obeo
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> Hi Cédric,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> monitor);
>>>>> Cédric brun wrote:
>>>>>> Hi Lars,
>>>>>> fixed this
>>>>>> notes
>>>>>> thing :)
>>>>>> Cédric
>>>>>>>> Hi,
>>>>>>>> compare
>>>>>>>> snippet
>>>>>>>> explains it best:
>>>>>>>> try {
>>>>>>>> how to
>>>>>>>> manually or
>>>>>>>> Lars
Re: How to create a copy of an EObject with non-null Resource [message #619031 is a reply to message #123282] |
Lars,
try {
Laurent Goubet
Obeo
> changes ;(
>>> return
>>> wrong:
>>> -- snip
>>> try {
>>> try {
>>> options);
>>> -- snap
>>> But changing
>>> into
>>> WORKS!
>>> gets this diff:
>>> *removed*
>>> *removed*
>>> whereas
>>> removed
>>> removed
>>> lars
>>>> Lars,
>>>> 1174 is :
>>>> Laurent Goubet
>>>> Obeo
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>>> Hi Cédric,
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> monitor);
>>>>>> Cédric brun wrote:
>>>>>>> Hi Lars,
>>>>>>> fixed this
>>>>>>> notes
>>>>>>> thing :)
>>>>>>> Cédric
>>>>>>>>> Hi,
>>>>>>>>> and compare
>>>>>>>>> snippet
>>>>>>>>> explains it best:
>>>>>>>>> try {
>>>>>>>>> how to
>>>>>>>>> manually or
>>>>>>>>> Lars
Re: How to create a copy of an EObject with non-null Resource [message #619035 is a reply to message #123375] |
Laurent,
Comments below.
> Lars,
> try {
> Cheers,
> Laurent Goubet
> Obeo
>> these changes ;(
>>>> return
>>>> partly wrong:
>>>> -- snip
>>>> try {
>>>> try {
>>>> options);
>>>> -- snap
>>>> But changing
>>>> into
>>>> WORKS!
>>>> gets this diff:
>>>> been *removed*
>>>> been *removed*
>>>> whereas
>>>> been removed
>>>> been removed
>>>> lars
>>>>> Lars,
>>>>> 1174 is :
>>>>> problem?
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>> Hi Cédric,
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> monitor);
>>>>>>> Resource.
>>>>>>> Cédric brun wrote:
>>>>>>>> Hi Lars,
>>>>>>>> have fixed this
>>>>>>>> notes
>>>>>>>> thing :)
>>>>>>>> Cédric
>>>>>>>>>> Hi,
>>>>>>>>>> the
>>>>>>>>>> and compare
>>>>>>>>>> code snippet
>>>>>>>>>> explains it best:
>>>>>>>>>> try {
>>>>>>>>>> idea how to
>>>>>>>>>> manually or
>>>>>>>>>> to.
>>>>>>>>>> Lars
Ed Merks
Re: How to create a copy of an EObject with non-null Resource [message #619038 is a reply to message #123388] |
Ed,
BIDI?
Laurent Goubet
Obeo
Ed Merks a écrit :
> Laurent,
> Comments below.
>> Lars,
>> try {
>> Cheers,
>> Laurent Goubet
>> Obeo
>>> these changes ;(
>>>>> return
>>>>> partly wrong:
>>>>> -- snip
>>>>> try {
>>>>> try {
>>>>> options);
>>>>> -- snap
>>>>> But changing
>>>>> into
>>>>> WORKS!
>>>>> gets this diff:
>>>>> been *removed*
>>>>> been *removed*
>>>>> whereas
>>>>> been removed
>>>>> been removed
>>>>> lars
>>>>>> Lars,
>>>>>> 1174 is :
>>>>>> problem?
>>>>>> Laurent Goubet
>>>>>> Obeo
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>>> Hi Cédric,
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> monitor);
>>>>>>>> Resource.
>>>>>>>> Cédric brun wrote:
>>>>>>>>> Hi Lars,
>>>>>>>>> have fixed this
>>>>>>>>> notes
>>>>>>>>> thing :)
>>>>>>>>> Cédric
>>>>>>>>>>> Hi,
>>>>>>>>>>> the
>>>>>>>>>>> and compare
>>>>>>>>>>> code snippet
>>>>>>>>>>> explains it best:
>>>>>>>>>>> try {
>>>>>>>>>>> idea how to
>>>>>>>>>>> manually or
>>>>>>>>>>> to.
>>>>>>>>>>> Lars
Re: How to create a copy of an EObject with non-null Resource [message #619050 is a reply to message #123402] |
Laurent,
> Ed,
> BIDI?
> Laurent Goubet
> Obeo
> Ed Merks a écrit :
>> Laurent,
>> Comments below.
>>> Lars,
>>> EcoreUtil.copy()) :
>>> try {
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>>>> return
>>>>>> behavior.
>>>>>> partly wrong:
>>>>>> -- snip
>>>>>> try {
>>>>>> try {
>>>>>> options);
>>>>>> -- snap
>>>>>> But changing
>>>>>> into
>>>>>> WORKS!
>>>>>> gets this diff:
>>>>>> whereas
>>>>>> lars
>>>>>>> Lars,
>>>>>>> solve the problem?
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>>> Hi Cédric,
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> monitor);
>>>>>>>>> Resource.
>>>>>>>>> Cédric brun wrote:
>>>>>>>>>> Hi Lars,
>>>>>>>>>> have fixed this
>>>>>>>>>> notes
>>>>>>>>>> a thing :)
>>>>>>>>>> Cédric
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> because the
>>>>>>>>>>>> it and compare
>>>>>>>>>>>> code snippet
>>>>>>>>>>>> explains it best:
>>>>>>>>>>>> try {
>>>>>>>>>>>> idea how to
>>>>>>>>>>>> manually or
>>>>>>>>>>>> how to.
>>>>>>>>>>>> Lars
<html>
<head>
</head>
Laurent,<br>
<br>
<blockquote><a
</blockquote>
<br>
<br>
<br>
BIDI?
<br>
<br>
<br>
<br>
Laurent Goubet
<br>
Obeo
<br>
<br>
Ed Merks a écrit :
<br>
<br>
<br>
Comments below.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
try {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Laurent Goubet
<br>
Obeo
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
return
<br>
<br>
<br>
<br>
wrong:
<br>
<br>
-- snip
<br>
<br>
<br>
<br>
try {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
try {
<br>
<br>
<br>
options);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
-- snap
<br>
<br>
But changing
<br>
<br>
into
<br>
<br>
WORKS!
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gets this diff:
<br>
<br>
<br>
*removed*
<br>
<br>
*removed*
<br>
<br>
<br>
<br>
whereas
<br>
<br>
<br>
<br>
<br>
removed
<br>
<br>
removed
<br>
<br>
<br>
lars
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Laurent Goubet
<br>
Obeo
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Cédric brun wrote:
<br>
<br>
<br>
this
<br>
<br>
notes
<br>
<br>
<br>
<br>
Cédric
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
compare
<br>
<br>
explains it best:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
try {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Lars
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
Ed Merks
Current Time: Fri Apr 19 12:15:04 GMT 2024
Powered by FUDForum. Page generated in 0.03948 seconds
