Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [CDO 0.8.0] EMap
Re: [CDO 0.8.0] EMap [message #122821 is a reply to message #122818] |
Thu, 22 May 2008 05:07 |
Originally posted by: stepper.sympedia.de
Simon,
Conceptually I think both approaches can be useful and I know a third
one which is like a combination of the existing HashMap based
implementation and your remote lookup. We could first look into the
HashMap and do the remote lookup (plus caching in the map) only if the
key is not present. With all three apporaches we'd have to evaluate how
the other EMap API (other than lookup) fits into the approach.
Btw. I never used an EMap but I know that EMap extends EList and I
thought EMap is implemented by subclassing an EList implementation plus
linear scanning for the lookup. Ok, I just verified that my last
assumption was wrong (does it apply to EFeatureMaps?). BasicEMap is a
subclass of java.lang.Object but delegates Entry storage to an EList
which uses a BasicEList[] (is it clever to have both delegations in one
EMap implementation, how to implement a different delegateEList without
the existing entryData?).
From a CDO client point of view I wonder how an EStore "gets a sense"
for an EMap typed attribute? I can't find the lookup API in EStore.
Cheers
/Eike
Simon McDuff schrieb:
> Hi Eike and Ed (Ed, you are more than welcome to add anything to this
> thread),
> the current implementation of Emap is using a hashmap. Unfortunately, to use
> a hashmap we need to load all the elements of the collection. This kill the
> point of proxying objects (when we are using EStore). We have cases where a
> collection reach millions of objects.... I don`t want to load all of them.
> I tought that an implementation using TreeMap would be better (It is an
> ordered collection). In this case, I can do dichotomic search... so I will
> not load all of them!
> Do you think it make sense ?
> The other solution I can think of its to catch the lookup and always go to
> the server to lookup objects. In the server side , IStoreReader will need to
> provide some functionnality to handle this (lookup(CDOFeature, Object key)
> return index).
> Maybe have both?!?!?!?
> Do you have others ideas to solve that kind of problem ?
> Thank you
> Simon
Re: [CDO 0.8.0] EMap [message #122855 is a reply to message #122851] |
Thu, 22 May 2008 11:52 |
> EMAP is a list of a class that only have a key and a value.
> EMap always add at the end of the list.
> The estore only knows index of a list!!
That's known. But what about the important part: EStore?
> "Eike Stepper" <stepper@sympedia.de> a écrit dans le message de news:
> g12v36$ik7$1@build.eclipse.org...
>> Simon,
>> Conceptually I think both approaches can be useful and I know a third one
>> which is like a combination of the existing HashMap based implementation
>> and your remote lookup. We could first look into the HashMap and do the
>> remote lookup (plus caching in the map) only if the key is not present.
>> With all three apporaches we'd have to evaluate how the other EMap API
>> Btw. I never used an EMap but I know that EMap extends EList and I thought
>> EMap is implemented by subclassing an EList implementation plus linear
>> scanning for the lookup. Ok, I just verified that my last assumption was
>> wrong (does it apply to EFeatureMaps?). BasicEMap is a subclass of
>> java.lang.Object but delegates Entry storage to an EList which uses a
>> BasicEList[] (is it clever to have both delegations in one EMap
>> implementation, how to implement a different delegateEList without the
>> From a CDO client point of view I wonder how an EStore "gets a sense" for
>> Cheers
>> /Eike
>>> thread),
>>> use a hashmap we need to load all the elements of the collection. This
>>> kill the point of proxying objects (when we are using EStore). We have
>>> cases where a collection reach millions of objects.... I don`t want to
>>> load all of them.
>>> will not load all of them!
>>> to the server to lookup objects. In the server side , IStoreReader will
>>> need to provide some functionnality to handle this (lookup(CDOFeature,
>>> Object key) return index).
>>> Thank you
>>> Simon
Re: [CDO 0.8.0] EMap [message #122874 is a reply to message #122870] |
Thu, 22 May 2008 16:02 |
> (I`m just describing the current implementation)
> But by knowing that,
> Estore doesn`t to know anything about EMap. Doesn`t need to since
> EBasicMap will only sent the following message to the Estore (not directly).
> Lookup calls are kept internally, so the Estore never know about it.. since
> EBasicMap built is hashmap at the initialization.
> Object get(InternalEObject object, EStructuralFeature feature, int index);
> Object set(InternalEObject object, EStructuralFeature feature, int index,
> Object value);
> int size(InternalEObject object, EStructuralFeature feature);
> etc....
Then I wonder how a (CDO-based) solution might look like that solves the
problem you initially described?
Cheers
/Eike
> g13mpg$1pa$4@build.eclipse.org...
>>>> Simon,
>>>> Cheers
>>>> /Eike
>>>>> thread),
>>>>> to use a hashmap we need to load all the elements of the collection.
>>>>> This kill the point of proxying objects (when we are using EStore). We
>>>>> have cases where a collection reach millions of objects.... I don`t
>>>>> Thank you
>>>>> Simon
Re: [CDO 0.8.0] EMap [message #122882 is a reply to message #122878] |
Thu, 22 May 2008 16:39 |
Hi Simon,
I suggest that you enter a feature request to discuss the details there.
Please describe where you intend to create instances of such a new EMap.
Cheers
/Eike
> OK.. basically to provide our own implementation of EMap !!
> So we can handle any cases!!
> g145fg$mtc$1@build.eclipse.org...
>>> directly). Lookup calls are kept internally, so the Estore never know
>>> about it.. since EBasicMap built is hashmap at the initialization.
>>> index);
>>> Object value);
>>> etc....
>> Cheers
>> /Eike
>>>>>> Simon,
>>>>>> how the other EMap API (other than lookup) fits into the approach.
>>>>>> plus linear scanning for the lookup. Ok, I just verified that my last
>>>>>> one EMap implementation, how to implement a different delegateEList
>>>>>> without the existing entryData?).
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> thread),
>>>>>>> We have cases where a collection reach millions of objects.... I
>>>>>>> an ordered collection). In this case, I can do dichotomic search...
>>>>>>> so I will not load all of them!
>>>>>>> go to the server to lookup objects. In the server side , IStoreReader
>>>>>>> will need to provide some functionnality to handle this
>>>>>>> (lookup(CDOFeature, Object key) return index).
>>>>>>> Thank you
>>>>>>> Simon
Re: [CDO 0.8.0] EMap [message #122890 is a reply to message #122886] |
Thu, 22 May 2008 17:25 |
> Done
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=233495
> Do you know if version 0.9 available soon in bugzilla ? This will not be in
> 0.8.0... I`m pretty sure!
This should be the version that we found a bug in, not the target
version ;-)
We stay with 0.8 for the time being...
However I cc'ed Nick...
Cheers
/Eike
> g147kt$mtc$2@build.eclipse.org...
>> Hi Simon,
>> Cheers
>> /Eike
>>>>> index);
>>>>> index, Object value);
>>>>> etc....
>>>> Cheers
>>>> /Eike
>>>>>>>> Simon,
>>>>>>>> third one which is like a combination of the existing HashMap based
>>>>>>>> the key is not present. With all three apporaches we'd have to
>>>>>>>> evaluate how the other EMap API (other than lookup) fits into the
>>>>>>>> approach.
>>>>>>>> last assumption was wrong (does it apply to EFeatureMaps?).
>>>>>>>> BasicEMap is a subclass of java.lang.Object but delegates Entry
>>>>>>>> storage to an EList which uses a BasicEList[] (is it clever to have
>>>>>>>> both delegations in one EMap implementation, how to implement a
>>>>>>>> different delegateEList without the existing entryData?).
>>>>>>>> sense" for an EMap typed attribute? I can't find the lookup API in
>>>>>>>> EStore.
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>>> this thread),
>>>>>>>>> Unfortunately, to use a hashmap we need to load all the elements of
>>>>>>>>> the collection. This kill the point of proxying objects (when we
>>>>>>>>> are using EStore). We have cases where a collection reach millions
>>>>>>>>> is an ordered collection). In this case, I can do dichotomic
>>>>>>>>> search... so I will not load all of them!
>>>>>>>>> always go to the server to lookup objects. In the server side ,
>>>>>>>>> IStoreReader will need to provide some functionnality to handle
>>>>>>>>> this (lookup(CDOFeature, Object key) return index).
>>>>>>>>> Thank you
>>>>>>>>> Simon
Re: [CDO 0.8.0] EMap [message #618117 is a reply to message #122818] |
Simon,
Cheers
/Eike
> thread),
> return index).
> Thank you
> Simon
Cheers
/Eike
http://www.esc-net.de
Re: [CDO 0.8.0] EMap [message #618131 is a reply to message #122851] |
>> Simon,
>> Cheers
>> /Eike
>>> thread),
>>> load all of them.
>>> Thank you
>>> Simon
Cheers
/Eike
Re: [CDO 0.8.0] EMap [message #618138 is a reply to message #122870] |
> Object value);
> etc....
Cheers
/Eike
>>>> Simon,
>>>> Cheers
>>>> /Eike
>>>>> thread),
>>>>> Thank you
>>>>> Simon
Cheers
/Eike
Re: [CDO 0.8.0] EMap [message #618142 is a reply to message #122878] |
Hi Simon,
Cheers
/Eike
>>> index);
>>> Object value);
>>> etc....
>> Cheers
>> /Eike
>>>>>> Simon,
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> thread),
>>>>>>> Thank you
>>>>>>> Simon
Cheers
/Eike
Re: [CDO 0.8.0] EMap [message #618146 is a reply to message #122886] |
> Done
version ;-)
Cheers
/Eike
>> Hi Simon,
>> Cheers
>> /Eike
>>>>> index);
>>>>> etc....
>>>> Cheers
>>>> /Eike
>>>>>>>> Simon,
>>>>>>>> approach.
>>>>>>>> EStore.
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>>> this thread),
>>>>>>>>> Thank you
>>>>>>>>> Simon
Cheers
/Eike
Current Time: Fri Apr 19 01:05:31 GMT 2024
Powered by FUDForum. Page generated in 0.02599 seconds
