Re: Cut,Copy commands enabledWhen [message #915823 is a reply to message #915235] |
Tue, 18 September 2012 02:49 |
Selection variable represents current selection of active part site's selection provider.
In this case, you should have to use legacy way. (IActionBars.setGlobalHandler() and Action, you can get actionbars from viewsite or editorsite)
Command and handler, menu extensions, core expressions are declarative and cost very low to create UI without code running.
But complex and dynamic situation, It's very hard to get you want.
You can also provide another variable which you need through service extensions.
Re: Cut,Copy commands enabledWhen [message #917329 is a reply to message #916664] |
Thu, 20 September 2012 02:01 |
Yes, that should be most logical way.
But I want you to consider advantage of command/menuContribution/core-expression and it's cost.
Remarkable Advantages are:
* Lazy: Can creates UI(menu/toolbar) without class loading, so no plugin will be started, no dependencies are resolved till handler will work.
* Extensible: 3rd party can extends menu or can modify behavior of command in specific context.
* Ease to manage: You can list all actions from plugin.xml, it's pretty good entry point to manage or co-operate then hard coded.
If an action which should not have to be initialized lazy(Declarative UI from plugin.xml first and load business logic later, it prevents plugin starting to just create UI)
or it has globally same policy(there is no chance to extended by client or co-worker),
or actions are reasonable in some specific view or editors only (initializing part causes expensive plugin start),
then There is no advantage with command/menuContribution/core-expression.
In your case, ui context is much more complex then business logic.
And your variable provider from service extension should start your plugin. (it's expensive since it has own dependencies)
So, to make advantage real, you should isolate service plugin which provides variables.
And publishing new variables and teach them to your co-worker or client is not so small task.
FUDForum. Page generated in 0.01995 seconds
