Home » Eclipse Projects » Remote Application Platform (RAP) » Read data from custom widget.
Read data from custom widget. [message #122413] Tue, 24 February 2009 12:43 Go to next message
Originally posted by: haglund86.hotmail.com
Hello.
I have created a custom widget which is built on qooxdoo and consists of
two lists. I can populate one of the lists from the java code, but how
do I read data from the list to the RAP application?
I have looked at the google maps example and they are using the function
readData in the LCA-file. But the example was to complex for me to fully
understand.
So my question is how do I read a variable from the javascript?
I would appreciate if someone could post an simple example of a custom
widget that reads data from the qooxdoo code.
Re: Read data from custom widget. [message #122443 is a reply to message #122413] Tue, 24 February 2009 14:22 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Erik,
here is a simple code that put in the request the value of your variable
"this.myParam" and send the request to the server:
var widgetManager = org.eclipse.swt.WidgetManager.getInstance();
var req = org.eclipse.swt.Request.getInstance();
var id = widgetManager.findIdByWidget( this );
req.addParameter( id + ".myParam", this.myParam );
req.send();
In your LCA#readData, you can read this parameter from the request:
String value = WidgetLCAUtil.readPropertyValue( widget, "myParam" );
if( value != null ) {
// do something if the parameter is found
Hope that this will help.
Best,
Ivan
Erik Haglund wrote:
> Hello.
> of two lists. I can populate one of the lists from the java code, but
> how do I read data from the list to the RAP application?
> function readData in the LCA-file. But the example was to complex for
> me to fully understand.
Re: Read data from custom widget. [message #122463 is a reply to message #122443] Tue, 24 February 2009 16:05 Go to previous messageGo to next message
Hi thank you for the example code.
However I have a problem related to this topic.
I wan't to be able to call my qooxdoo function and read my variable at a
given time.
So how do I call a function in qooxdoo from the LCA?
/Erik
Ivan Furnadjiev skrev:
> Hi Erik,
> var id = widgetManager.findIdByWidget( this ); req.addParameter(
> req.send();
> // do something if the parameter is found }
> Best,
> Ivan
> Erik Haglund wrote:
>> Hello.
Re: Read data from custom widget. [message #122473 is a reply to message #122463] Tue, 24 February 2009 16:32 Go to previous messageGo to next message
Hi Erik,
in your LCA#renderChanges method you can use:
JSWriter writer = JSWriter.getWriterFor( widget );
writer.call(......) or writer.callStatic(......) depend on your function.
Check the existing RAP LCAs for more details.
Best,
Ivan
> a given time.
> /Erik
>> Hi Erik,
>> variable "this.myParam" and send the request to the server:
>> req.send();
>> Best,
>> Ivan
>> Erik Haglund wrote:
>>> Hello.
>>> consists of two lists. I can populate one of the lists from the java
>>> code, but how do I read data from the list to the RAP application?
>>> for me to fully understand.
>>> custom widget that reads data from the qooxdoo code.
Re: Read data from custom widget. [message #122544 is a reply to message #122473] Wed, 25 February 2009 10:01 Go to previous messageGo to next message
When I use the function call:
writer.call();
from readData in the LCA-file I get an infinity loop (probably because
req.send() in the qooxdoo code triggers the readData function in the
LCA-file again and so on). This is taking alot of resources. Is it
possible to get around this problem?
Erik
> Hi Erik,
> Best,
> Ivan
>> a given time.
>> /Erik
>>> Hi Erik,
>>> req.send();
>>> Best,
>>> Ivan
>>> Erik Haglund wrote:
>>>> Hello.
Re: Read data from custom widget. [message #122552 is a reply to message #122544] Wed, 25 February 2009 10:14 Go to previous messageGo to next message
Hi Erik,
I do not understand why you call writer.call(); from LCA#readData? The
LCA#readData method is called to get the data from the JavaScript.
LCA#renderChanges is the place to call the JavaScript function.
Best,
Ivan
> writer.call();
> Regards
> Erik
>> Hi Erik,
>> function.
>> Best,
>> Ivan
>>> at a given time.
>>> /Erik
>>>> Hi Erik,
>>>> req.send();
>>>> Best,
>>>> Ivan
>>>> Erik Haglund wrote:
>>>>> Hello.
>>>>> java code, but how do I read data from the list to the RAP
>>>>> application?
Re: Read data from custom widget. [message #122563 is a reply to message #122552] Wed, 25 February 2009 11:18 Go to previous messageGo to next message
Thank you for your reply.
Unfortunately this did not fix my problem with the infinity loop.
To give you a clear view of what I am doing:
LCA file:
public void renderChanges(Widget widget) throws IOException
JSWriter writer = JSWriter.getWriterFor(widget);
try {
writer.call("readItem", null);
} catch (IOException e) {
e.printStackTrace();
public void readData(Widget widget)
Dnd dnd = (Dnd) widget;
String location = WidgetLCAUtil.readPropertyValue(dnd, "listan" );
System.out.println(location);
javascript file:
readItem: function()
var test = "FREDD";
req.addParameter( id + ".listan", test );
req.send();
This code will perform a infinite loop of calls to the readItem function
in the javascript file.
> Hi Erik,
> Best,
> Ivan
>> writer.call();
>> Regards
>> Erik
>>> Hi Erik,
>>> function.
>>> Best,
>>> Ivan
>>>> at a given time.
>>>> /Erik
>>>>> Hi Erik,
>>>>> req.send();
>>>>> Best,
>>>>> Ivan
>>>>> Erik Haglund wrote:
>>>>>> Hello.
>>>>>> application?
Re: Read data from custom widget. [message #122606 is a reply to message #122563] Wed, 25 February 2009 13:05 Go to previous message
Hi Erik,
with your code it is normal to go into infinity loop. I will suggest the
following:
1. When there is a change in the your JavaScript variable - send the new
value to the server with the code in readItem function.
2. Store the new value in your server-side Dnd widget in LCA#readData.
2. When you need to access this value just get it from your server-side
Dnd widget directly.
Best,
Ivan
> LCA file:
> try {
> javascript file:
> var test = "FREDD";
> req.send();
> function in the javascript file.
>> Hi Erik,
>> The LCA#readData method is called to get the data from the
>> JavaScript. LCA#renderChanges is the place to call the JavaScript
>> function.
>> Best,
>> Ivan
>>> writer.call();
>>> because req.send() in the qooxdoo code triggers the readData
>>> function in the LCA-file again and so on). This is taking alot of
>>> resources. Is it possible to get around this problem?
>>> Regards
>>> Erik
>>>> Hi Erik,
>>>> function.
>>>> Best,
>>>> Ivan
>>>>> variable at a given time.
>>>>> /Erik
>>>>>> Hi Erik,
>>>>>> req.send();
>>>>>> Best,
>>>>>> Ivan
>>>>>> Erik Haglund wrote:
>>>>>>> Hello.
>>>>>>> application?
>>>>>>> complex for me to fully understand.
Previous Topic:Again GridLayout difference with RCP (1.2 M5)
Next Topic:Multithread RAP application, ui contribution
Current Time: Mon Sep 26 10:49:48 GMT 2022
Powered by FUDForum. Page generated in 0.01961 seconds
