services fail with same method names [message #912490] |
Thu, 13 September 2012 16:55 |
Flavio Donze Messages: 211 Registered: July 2009 Location: Switzerland |
Hello
I have a problem which is bothering me for quite a while.
If I create a service which has two methods with the same name, I can not connect to the service, even if it has a different amount of parameters or different parameters.
To make sure it is not a problem from our environment I tested it with the PingPong example.
I added another
Pong ping(String ping);
to the interface and I get the following exception as a result.
com.caucho.hessian.client.HessianConnectionException: HessianProxy cannot connect to 'http://localhost:8080/hessian/PingPongWS
at com.caucho.hessian.client.HessianProxy.invoke(HessianProxy.java:194)
at $Proxy13.ping(Unknown Source)
at org.eclipse.riena.communication.core.hooks.AbstractHooksProxy.invoke(AbstractHooksProxy.java:69)
at org.eclipse.riena.communication.core.hooks.AbstractHooksProxy.invoke(AbstractHooksProxy.java:38)
at org.eclipse.riena.internal.communication.core.factory.CallHooksProxy.invoke(CallHooksProxy.java:66)
at $Proxy14.ping(Unknown Source)
at org.eclipse.riena.internal.communication.sample.pingpong.client.Activator$PingClient$1.run(Activator.java:78)
at java.util.TimerThread.mainLoop(Unknown Source)
at java.util.TimerThread.run(Unknown Source)
Caused by: java.io.FileNotFoundException: http://localhost:8080/hessian/PingPongWS?ping&RID-fpx45sbj
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection$6.run(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getChainedException(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at com.caucho.hessian.client.HessianProxy.invoke(HessianProxy.java:179)
... 12 more
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.caucho.hessian.client.HessianProxy.invoke(HessianProxy.java:168)
... 12 more
Is it a bug? I would be happy to create a bugzilla issue .
Is there some other reason for this?
greets
Flavio
Prozessmanagement und Qualitätsmanagement Software QMS/IMS
https://www.scodi.ch
FUDForum. Page generated in 0.03350 seconds
