Home » Archived » Memory Analyzer (MAT) » DTFJ queries
DTFJ queries [message #11179] Tue, 07 July 2009 05:09 Go to next message
It is possible to get access to the DTFJ Image and JavaRuntime handles
when writing MAT queries for dumps from IBM virtual machines.
This is done using the ISnapshot.getSnapshotAddons() call. This API takes
the class of the object required and returns an instance of that class.
The DTFJ adapter can return com.ibm.dtfj.image.Image or
com.ibm.dtfj.java.JavaRuntime objects.
You'll need to add the com.ibm.dtfj.api plug-in in the required plug-ins
list for your query plug-in so you get access to Image or JavaRuntime.
I haven't done much with this yet, so this information could be subject to
change if it doesn't work as we would like. Please let me know if this is
useful.
Image im = snapshot.getSnapshotAddons(Image.class);
JavaRuntime jr = snapshot.getSnapshotAddons(JavaRuntime.class);
* Get additional JVM information, if available.
* <p>
* @return SnapshotAddons - extended information, e.g. perm info, OoM
stack
* trace info, JVM arguments, etc.
* @throws SnapshotException
public <A> A getSnapshotAddons(Class<A> addon) throws
SnapshotException;
Re: DTFJ queries [message #11183 is a reply to message #11179] Wed, 08 July 2009 08:00 Go to previous message
Cool.
This code should also be possible:
public class SomeQuery implements IQuery {
@Argument
public Image image;
If you do it this way, the query will only appear if the heap dump has an
'Image' available. This way it is possible to have queries only for DTFJ
based dumps - for example to print JVM startup parameters which are not
available in HPROF but maybe in DTFJ.
Andreas.
Previous Topic:update site zip
Next Topic:Setting up MAT with eclipse
Current Time: Wed May 14 08:44:09 EDT 2025
Powered by FUDForum. Page generated in 0.03306 seconds
