Re: change type of problem markers [message #911058 is a reply to message #910787] |
Mon, 10 September 2012 22:36 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Am 10.09.12 13:51, schrieb Vlad Dumitrescu:
> Ah, thanks, I forgot to check that file!
> By the way, I notice there are a couple of extensions that are no longer
> generated, should they be deleted?
> <extension
> point="org.eclipse.emf.ecore.extension_parser">
> <parser
> class="org.erlide.ui.ErlangExecutableExtensionFactory:org.eclipse.xtext.resource.IResourceFactory"
> type="hrl">
> </parser>
> </extension>
> <extension
> point="org.eclipse.xtext.extension_resourceServiceProvider">
> <resourceServiceProvider
> class="org.erlide.ui.ErlangExecutableExtensionFactory:org.eclipse.xtext.ui.resource.IResourceUIServiceProvider"
> uriExtension="hrl">
> </resourceServiceProvider>
> </extension>
> regards,
> Vlad
Hi Vlad,
those extension should (usually) not be deleted. Did you remove a
generator fragment from your workflow?
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
FUDForum. Page generated in 0.02580 seconds
