Re: Opening Files [message #910654 is a reply to message #910595] |
Mon, 10 September 2012 06:53 |
Yes, the project is usually what tells Eclipse what you're building against, and allows it to incrementally build your sources as you change them. Past the simple 'Hello, World' case, you won't be dealing with a singular class file.
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Opening Files [message #910855 is a reply to message #910595] |
Mon, 10 September 2012 13:59 |
On 9/9/2012 10:03 PM, D F wrote:
> Is it possible to simply open a file, save/compile it, and run it? I've
> been at it for a few hours and I'm only able to run a new class file
> created under a project. I can not open simply open and run a file, and
> even with a project up I am unable to bring an existing file into the
> project; it just opens and I have the same problem.
> Is this intentional? Am I missing something? I suppose I could just open
> the existing files and copy/paste their contents into a New class under
> a Project, but that seems awfully tedious and far too time-consuming to
> be reasonable.
Eclipse is really for building applications.
In my most active work spaces, I keep a scratch project around in which
I can just throw something quick to try out
FUDForum. Page generated in 0.09788 seconds
