Re: How to tell buckminster to build from a concrete plugin [message #910727 is a reply to message #909706] |
Mon, 10 September 2012 09:33 |
Hi Jan,
You can add an advisorNode to you cquery so that it will instruct Bucky to disregard the target platform during
resolution. Put this one last to "catch-all":
<cq:advisorNode namePattern=".*" useTargetPlatform="false" useMaterialization="false"/>
and then alter the existing nodes and add useTargetPlatform="false" useMaterialization="false" to them too (there's no
merging of advisornodes, the first one to match a component is used).
HTH,
- thomas
On 2012-09-07 18:17, Jan Krakora wrote:
> I have a target platform containing many bundles. One of that bundle is modified and stored on my file system. How can I
> tell the Buckminster to use this one instead of the original from the target platform?
> My site.rmap file:
> <rmap
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
> xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
> xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
> xmlns:pp="http://www.eclipse.org/buckminster/PDEMapProvider-1.0">
> <searchPath name="resources">
> <provider readerType="local" componentTypes="osgi.bundle,eclipse.feature"
> mutable="true" source="true">
> <uri format="file:///{0}/{1}/">
> <bc:propertyRef key="workspace.root" />
> <bc:propertyRef key="buckminster.component" />
> </uri>
> </provider>
> </searchPath>
> <locator searchPathRef="resources"/>
> </rmap>
> My cquery"
> <cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="site.rmap">
> <cq:rootRequest name="cz.tigra.spl.site" componentType="eclipse.feature"/>
> <cq:advisorNode namePattern="cz.tigra.spl*" componentType="osgi.bundle" allowCircularDependency="true"/>
> <cq:advisorNode namePattern="cz.tigra.spl.client.feature" componentType="eclipse.feature"
> </cq:componentQuery>
> Thanks
Re: How to tell buckminster to build from a concrete plugin [message #910801 is a reply to message #910768] |
Mon, 10 September 2012 12:08 |
On 2012-09-10 13:20, Jan Krakora wrote:
> Hi Thomas,
> thanks for your response.
> 1) Why is there useMaterialization="false"?
Because only p2 aware components will end up in your target platform. Components fetched from Maven or using URL's will
end up in a special project called .buckminster. You can also use an mspec to make them end up elsewhere. Those
components are considered materialized (and can thus be found) although they are not in your TP. If you want to force
buckminster to bypass the and search the net during resolution, then you must use userMaterialization="false".
> 2) I use headless Buckminster, when I call buckminster import ".../bucminster.cquery" it resolves and materializes the
> required components to the workspace, right?
> So the cquery is used for materialization. And then, when I call buckminster perform "some build action", it operates on
> the materialized components. Does it mean that the buckminster's workspace is always regenerated when it's materialized?
No, not unless you use useWorkspace="false" in your cquery. That would force Buckminster to regenerate the workspace. I
would recommend starting with an empty workspace instead when running unattended build. In your IDE, you generally
"regenerate" your workspace using other means such as "git pull" or "svn update".
- thomas
Re: How to tell buckminster to build from a concrete plugin [message #910892 is a reply to message #910868] |
Mon, 10 September 2012 15:13 |
On 2012-09-10 16:33, Jan Krakora wrote:
> Ok, just the last question.
> I have about 20 plugin projects stored on a local file system. They are fetched by local reader using RMAP.
> I invoke an ant action creating p2.site from a feature (it contains many plugins from target platform and also those 20
> plugins) and then an action creating product from that site.
> The product contains all required plugins, but there is one source plugin for one of those 20 from local file system.
> Why is that? There are about 100 plugins (20 from local file system, 80 from target platform) and none of them has there
> its source, but the one.
> It's just a normal plugin project like the others.
> Do you have any idea???
Sorry, but no. I would need to look at more details.
- thomas
FUDForum. Page generated in 0.01843 seconds
