Re: The server configuration is missing or invalided. [message #909314 is a reply to message #909310] |
Thu, 06 September 2012 23:41 |
howard hardaway Messages: 6 Registered: August 2012 |
Junior Member |
Now getting this.
Sep 06, 2012 4:40:56 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre7\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre7/bin/client;C:/Program Files/Java/jre7/bin;C:/Program Files/Java/jre7/lib/i386;c:\oc4j\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Java\jdk1.7.0_05\bin;C:\Program Files\Eclipse JEE Indigo\eclipse;;.
Sep 06, 2012 4:40:57 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-8080"]
Sep 06, 2012 4:40:58 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["ajp-bio-8009"]
Sep 06, 2012 4:40:58 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1900 ms
Sep 06, 2012 4:40:58 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Sep 06, 2012 4:40:58 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.29
Sep 06, 2012 4:40:59 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
INFO: Starting ProtocolHandler ["ajp-bio-8009"]
Sep 06, 2012 4:40:59 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 1110 ms
Re: The server configuration is missing or invalided. [message #909356 is a reply to message #909314] |
Fri, 07 September 2012 02:28 |
On 9/6/2012 5:41 PM, howard hardaway wrote:
> Now getting this.
> [snip]
This is a red herring; don't worry about it. If it keeps you up at
night, Google it and you'll see a) that you don't need to worry and why,
plus b) that if you do worry, just getting rid of the warning is a fair
amount of work.
By the way, these are Eclipse web tools (not newcomers') forum questions
you're asking.
FUDForum. Page generated in 0.08157 seconds
