Home » Eclipse Projects » Equinox » DynamicImport-Package fails
DynamicImport-Package fails [message #121326] Thu, 20 November 2008 05:43 Go to next message
Prashant Deva is currently offline Prashant DevaFriend
Member
I am trying to instrument eclipse classes during runtime using a
ClassLoadingHook.
In the hook, for each bundle's manifest I am setting the property
dynamicimport-package : '*'
however despite this, i am getting a classnotfoundexception.
The technique I am trying to implement the class loading hook is very
similar to the one mentioned here -
http://www.eclemma.org/research/instrumentingosgi/index.html
After a lot of debugging I have traced the error to the following line of
code in org.eclipse.osgi.internal.resolver.StateImpl in the method
linkDynamicImport() -
BundleDescriptionImpl importer = (BundleDescriptionImpl) importingBundle;
if (importer.getDynamicStamp(requestedPackage) == getTimeStamp())
return null;
As it turns out this check passes and the null is returned, thus making my
class fail to load.
What here does dynamicStamp() and TimeStamp() stand for and why do they
fail?
Prashant
Re: DynamicImport-Package fails [message #1219604 is a reply to message #121326] Wed, 04 December 2013 21:04 Go to previous messageGo to next message
Aron L is currently offline Aron LFriend
I have come across this same issue.
Prashant, did you ever figure out a solution?
Re: DynamicImport-Package fails [message #1220244 is a reply to message #1219604] Tue, 10 December 2013 15:08 Go to previous message
Thomas Watson is currently offline Thomas WatsonFriend
The dynamicStamp() and TimeStamp() are used to cache results which allow the resolver to return quickly if "nothing has changed" since the last time an attempt was done to resolve a dynamic import package. One pretty hackish workaround would be to install a dummy bundle and keep updating it each time you change the dynamic import policy of a bundle from your class loading hook. This would force the state timestamp to change which then would invalidate the dyanamic import cache.
For the current release being developed (luna) I think this issue should be fixed. But keep in mind the equinox specific hooks have been significantly redone which will require anyone implementing equinox specific hooks to migrate to the new hooks in luna.
Tom.
Previous Topic:Target Platform Jar Inter-dependencies
Next Topic:static fields at LocationManager
Current Time: Sat Dec 04 13:48:48 GMT 2021
Powered by FUDForum. Page generated in 0.01960 seconds
