Home » Eclipse Projects » WindowBuilder » why class attribute is not generated
why class attribute is not generated [message #908704] Wed, 05 September 2012 17:08 Go to next message
I drag some elements such as JTextField onto the Frame. Sometimes, the generate code declares the textField as a class attribute. But, sometimes the textField becomes a local variable in method initialize(). How can I avoid the latter case? Thanks.
Re: why class attribute is not generated [message #908752 is a reply to message #908704] Wed, 05 September 2012 20:18 Go to previous message
That is entirely controlled by the code generation prefs you have in place and whether you converted any of the text fields into local variables or not. It only take one click to convert a widget from a field to a local and vice versa.
Previous Topic:why palette view is gone after re-import
Next Topic:Disambiguating wizards
Current Time: Thu Mar 27 11:00:16 EDT 2025
Powered by FUDForum. Page generated in 0.04236 seconds
