Home » Modeling » TMF (Xtext) » Odd double clicking ?
Re: Odd double clicking ? [message #908905 is a reply to message #908629] |
Thu, 06 September 2012 07:57 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Yes, Xtext handles this according to the lexer tokens with some special
semantics for ML comments and Strings.
See org.eclipse.xtext.ui.editor.doubleClicking.DoubleClickStrategyProvider
and
org.eclipse.xtext.ui.editor.doubleClicking.LexerTokenAndCharacterPairAwareStrategy
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 05.09.12 19:19, schrieb Henrik Lindberg:
> I have noticed odd behaviour when double clicking to select text.
> Somethimes only a single letter, sometimes two are selected, and
> sometimes the entire word is correctly selected.
> It seems related to where in the "word" the pointer is when double
> clicking - if towards the beginning or end, it does the right thing, but
> if in the middle it seems to prefer selecting a single or two characters.
> My question is if Xtext is involved in this at all, and if so, any hints
> where I should look for where this happens. I Can imagine that it
> relates to what is being clicked on, and find the significant portion to
> select.
> Regards
> - henrik
Re: Odd double clicking ? [message #908997 is a reply to message #908905] |
Thu, 06 September 2012 11:24 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
> and
I debugged this, and found that DocumentParitioner is basing its
decision on faulty information.
Clicking at the position marked | in the string 'a|bcd', returns a
partition consisting of abcd only. It returns a region based on that.
The end result is a selection if bc only.
If I double click (marked |) 'ab|cd', I also get a region consisting of
abcd, but now I get the correct selection; all of abcd.
So - mapping to typed region seems ok.
In
o.e.xtext.ui.editor.doubleClicking.AbstractPartitionDoubleClickSelector.findExtendedDoubleClickSelection(IDocument,
int offset) however, it does this:
if (offset == region.getOffset() + 1
|| offset == region.getOffset() + region.getLength() - 1) {
return getSelectedRegion(document, region);
otherwise, it returns null. This is called for the
FixedCharCountPartitionDoubleClickSelector configured for the STRING
partition. (It in turn has margins of 1 assigned).
This seems to be the logic for "select the entire string if at one of
the ends", because if it returns null, the logic above continues with a
search for a Word match.
Everything would be ok, if the underlying region had included the
quotes. I do have a specialized implementation of
TokenTypeToStringMapper that includes these rules:
if("RULE_WORD_CHARS".equals(tokenName))
return STRING_LITERAL_PARTITION;
if("RULE_ANY_OTHER".equals(tokenName))
if("'::'".equals(tokenName))
if("'$'".equals(tokenName))
// issue #276, screws up bracket matching
// if("'${'".equals(tokenName))
// return STRING_LITERAL_PARTITION;
if("'\\''".equals(tokenName))
if("'\\\"'".equals(tokenName))
if("'\\$'".equals(tokenName))
if("'\\${'".equals(tokenName))
if("'\\\\".equals(tokenName))
if("'\''".equals(tokenName))
if("'\"'".equals(tokenName))
I have this binding:
public Class<? extends ITokenTypeToPartitionTypeMapper>
bindITokenTypeToPartitionTypeMapper() {
return PPTokenTypeToPartionMapper.class;
And I can see it gets called.
Is there another token to partition mapper involved?
- henrik
Re: Odd double clicking ? [message #909050 is a reply to message #908997] |
Thu, 06 September 2012 13:06 |
Thanks to Sebastian Zarnekow, I now know that I needed to bind a
PartitionTokenScanner that does this:
protected boolean shouldMergePartitions(String contentType) {
return super.shouldMergePartitions(contentType) ||
PPTokenTypeToPartionMapper.STRING_LITERAL_PARTITION.equals(contentType);
Since it did not expect strings to be implemented with multiple tokens.
Now it works!
- henrik
>> See
>> and
> In
> Regards
> - henrik
Current Time: Fri Mar 29 10:20:12 GMT 2024
Powered by FUDForum. Page generated in 0.05154 seconds
