Home » Newcomers » Newcomers » Cannot open Eclipse [Java Path Issue]
Cannot open Eclipse [Java Path Issue] [message #908224] Wed, 05 September 2012 01:04 Go to next message
roro bond is currently offline roro bondFriend
I have a problem with eclipse.
I've download and installed ''jdk-7u7-windows-i586'' and extracted ''eclipse-jee-juno-win32-x86_64''
I want to start coding and I chose the game Runescape as a test subject/first step.
Everytime I try to open eclipse this message pops up ; (see attachment)
Any idea on how to fix it? I've tried creating the path and copied the javaw.exe from my Java directory but another error popped up.
-Thank you in advance.
  • Attachment: 1.jpg
    (Size: 28.03KB, Downloaded 188 times)
[Updated on: Wed, 05 September 2012 01:05]
Report message to a moderator
Re: Cannot open Eclipse [Java Path Issue] [message #908273 is a reply to message #908224] Wed, 05 September 2012 04:17 Go to previous messageGo to next message
Anyone cares to help please?
Re: Cannot open Eclipse [Java Path Issue] [message #908281 is a reply to message #908273] Wed, 05 September 2012 04:45 Go to previous messageGo to next message
Roro,
You're asking questions in the middle of the night (in Europe and
certainly after working hours in NA) and expecting answers in less than
3 hours? Did you actually install an appropriate JDK on your machine?
In any case, copying just the *.exe isn't sufficicient because that exe
isn't going to find the libraries it needs. You should use the -vm
argument (which you can also put in the eclipse.ini so you don't have to
keep specifying it) to point at where the exe actually is.
http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Freference%2Fmisc%2Fruntime-options.html
Ed Merks
Re: Cannot open Eclipse [Java Path Issue] [message #908289 is a reply to message #908281] Wed, 05 September 2012 05:04 Go to previous messageGo to next message
What is the right way to install JDK?
I installed it by default, it's in C:\Program Files (x86)\Java\
The -vm didn't work whatsoever.
Re: Cannot open Eclipse [Java Path Issue] [message #908298 is a reply to message #908289] Wed, 05 September 2012 05:28 Go to previous messageGo to next message
When you get a JDK from Oracle, you install it. It sets things up in
(at least on my machine):
c:/Windows/System32
You can try java.exe -version there to see which one is there. That's
the one used by default. If it's not the right one, it's not going to work.
An alternative to specifying the -vm arguments (what exactly did you
try?) is to copy the jre folder to the folder that contains your
eclipse.exe. If you want the JDK source, be sure to copy the JDK's
src.zip into that jre folder too.
Ed Merks
Re: Cannot open Eclipse [Java Path Issue] [message #908305 is a reply to message #908298] Wed, 05 September 2012 05:59 Go to previous messageGo to next message
I'm really confused, please excuse how newbish I am.
What I did with -vm was I typed something along the lines of -vm DIRECTORYFILEOFJAVA
Re: Cannot open Eclipse [Java Path Issue] [message #908343 is a reply to message #908305] Wed, 05 September 2012 07:43 Go to previous messageGo to next message
Try specifying the full absolute path name of the javaw.exe.
> DIRECTORYFILEOFJAVA
Ed Merks
icon4.gif  Re: Cannot open Eclipse [Java Path Issue] [message #908633 is a reply to message #908224] Wed, 05 September 2012 17:35 Go to previous messageGo to next message
mathew rajan is currently offline mathew rajanFriend
i have the same issue as roro....cant figure it out though .intalled jdk too inside the eclipse folder..this makes netbeans look like a piece of cake...
Re: Cannot open Eclipse [Java Path Issue] [message #908639 is a reply to message #908633] Wed, 05 September 2012 17:56 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> cake...
NetBeans is a piece of cake, however, it's not what Java application
developers use to develop software in.
Have you looked at http://wiki.eclipse.org/Eclipse.ini
Re: Cannot open Eclipse [Java Path Issue] [message #908798 is a reply to message #908343] Thu, 06 September 2012 02:50 Go to previous messageGo to next message
Ed Merks wrote on Wed, 05 September 2012 03:43
> DIRECTORYFILEOFJAVA
There's more than 1 javaw.exe
There's 2 javaw.exe
One in C:\Program Files (x86)\Java\jdk1.6.0_33\bin
The other in C:\Program Files (x86)\Java\jdk1.6.0_33\jre
What do I do next?
P.S.
I had eclipse and used it once (months ago) I didn't have this problem.
[Updated on: Thu, 06 September 2012 02:51]
Re: Cannot open Eclipse [Java Path Issue] [message #908804 is a reply to message #908798] Thu, 06 September 2012 03:07 Go to previous messageGo to next message
Found te reason. 64bit OS ,64 bit eclipse ,32bi jdk.
Re: Cannot open Eclipse [Java Path Issue] [message #908831 is a reply to message #908804] Thu, 06 September 2012 04:44 Go to previous messageGo to next message
mathew rajan wrote on Wed, 05 September 2012 23:07
Oh god...thank you so much.
I can't believe I fell for this.
I actually believed I downloaded the 64bit, but it seems not.
[Updated on: Thu, 06 September 2012 04:53]
Re: Cannot open Eclipse [Java Path Issue] [message #908837 is a reply to message #908798] Thu, 06 September 2012 05:00 Go to previous messageGo to next message
Try the first one. Try each.
>> > What I did with -vm was I typed something along the lines of -vm >
>> DIRECTORYFILEOFJAVA
> There's 2 javaw.exe
> What do I do next?
Ed Merks
Re: Cannot open Eclipse [Java Path Issue] [message #908838 is a reply to message #908831] Thu, 06 September 2012 05:00 Go to previous message
Is your Eclipse 64 bit?
On 06/09/2012 6:44 AM, roro bond wrote:
> oracle(dot)com/technetwork/java/javase/downloads/jdk7u7-downloads-1836413.html
> I downloaded the one of Windows x86 which is 64bit.
> And my Windows is 64bit.
Ed Merks
Previous Topic:Getting the XML editor and the Android Common XML editor in the same window
Next Topic:JMenuItem Selection Event Handler
Current Time: Sun Jun 20 05:18:39 GMT 2021
Powered by FUDForum. Page generated in 0.05395 seconds
