[delete me] [message #907836] |
Tue, 04 September 2012 09:21 |
David B. Messages: 24 Registered: February 2012 |
I'm using BIRT 3.7.1 and I have some issues when exporting to DOC format:
- The hyperlinks and bookmarks don't work correctly, however they are working fine with PDF export. The link is correct but the bookmark is not created in the DOC file, so when I click on the link it goes nowhere in the document.
- I have trouble with the crosstab layout: in the PDF export it looks OK but in the DOC export, the crosstab layout is very bad. I am using the auto layout because the number of columns is variable.
Here is a Java project with a report example showing both of my issues: dl.dropbox.com/u/70923442/HyperlinkAndCrosstabLayoutIssue.zip
Maybe I did something wrong in the report but I think it may be some configuration issue in the code calling the report generation, since the PDF export works pretty well.
Thanks in advance for your help!
David
[Updated on: Tue, 04 September 2012 14:30] Report message to a moderator
FUDForum. Page generated in 0.03299 seconds
