Re: Unable to invoke JUnit tests (org.eclipse.hyades.internal.execution.local.control.InactiveProces [message #121013 is a reply to message #121005] |
Thu, 17 January 2008 12:26 |
Stefan Holzknecht Messages: 31 Registered: July 2009 |
Member |
Hi Paul,
I installed it from the ZIP file. The problem occures for 'Regular JUnit
Test's as well as for 'TPTP JUnit Test's. Actually I was able to run
tests, but when the problem occured it doesn't went away, even restarts,
or removing the deployment area did not help. Have you any hints what
I should check or verify? Are there some log files that might be
helpfull (does
eclipse\plugins\org.eclipse.tptp.platform.ac.win_ia32_4.4.1. v200709261752\agent_controller\config\servicelog.log
provide regarding information)?
Stefan
Paul Slauenwhite wrote:
> Hi Stefan,
> Are you converting the JUnit test classes to TPTP JUnit test suites
> before running them? Also, how did you install TPTP 4.4.0.3, from a ZIP or
> through Update Manager?
> Paul
> "Stefan Holzknecht" <s.holzknecht@intershop.de> wrote in message
> news:fmn2dq$5ot$1@build.eclipse.org...
>> Hello,
>> I'm trying to execute JUnit tests as TPTP test. I'm using the internal
>> Agent Controller with tptp 4.4.0.3 along with eclipse 3.3.1.
>> But performing tests fails with an exception:
>> java.lang.RuntimeException:
>> org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
>> at
>> org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.handleException(TestExecutionHarnessExecutorStub.j ava:347)
>> at
>> org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:434)
>> at
>> org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2098)
>> at
>> org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$2(TestExecutionHarness.java:1830)
>> at
>> org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:750)
>> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
>> Caused by:
>> at
>> org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:422)
>> ... 4 more
>> !ENTRY org.eclipse.hyades.test.core 4 0 2008-01-17 08:56:22.151
>> !MESSAGE IWAT4039E The Test Execution Harness reported the following
>> problems:org.eclipse.hyades.internal.execution.local.control .InactiveProcessException
>> During a debug session I figured out that
>> TestExecutionHarnessExecutorStub.waitForProcess() is being called with a
>> process id -1, which does not exist. Has someone experienced a similar
>> problem? How can I fix that?
>> Kind regards,
>> Stefan
Re: Unable to invoke JUnit tests (org.eclipse.hyades.internal.execution.local.control.InactiveProces [message #121022 is a reply to message #121013] |
Fri, 18 January 2008 11:33 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Stefan,
Very strange. This behavior is usually caused by a bad test deployment,
usually not an issue when running a regular JUnit test suite. Can you
attach the following:
-IAC servicelog.log
-Eclipse .log
-Test suite
-Deployment files (*.deployment, *.artifact, *.location).
In the meantime, can you try with the stand-alone Agent Controller?
Paul
news:fmnhh6$a4p$1@build.eclipse.org...
> Hi Paul,
> or removing the deployment area did not help. Have you any hints what I
> should check or verify? Are there some log files that might be helpfull
> (does
> Stefan
>> Hi Stefan,
>> or through Update Manager?
>> Paul
>>> Hello,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> ... 4 more
>>> Kind regards,
>>> Stefan
FUDForum. Page generated in 0.03663 seconds
