Home » Archived » Visual Editor (VE) » NullPointerException when creating a new Visual class
NullPointerException when creating a new Visual class [message #120959] Tue, 28 March 2006 03:15 Go to next message
Originally posted by: luchuan.radvision.com
<b>Hi,
Also I could create a new Visual class, the following error's reported inside the ".log". Before this happens, I used to solve a problem of "IWAV0168E", which had been commonly reported. The process was like "delete the error log -> clean and rebuild the project".</b>
!ENTRY org.eclipse.ve.java.core 4 0 2006-03-28 15:06:52.293
!MESSAGE Exception thrown.
!STACK 0
at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedSing le(XMLSaveImpl.java:1988)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1215)
at org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
at org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1357)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$2.doRun(JavaSourceTranslator.java:922)
at org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
<b>Pls help, thanks a lot.
Luchuan</b>
Re: NullPointerException when creating a new Visual class [message #121003 is a reply to message #120959] Tue, 28 March 2006 14:05 Go to previous messageGo to next message
First, is this a pre 1.2M2 VE driver? If so, we had a cache race
condition which caused the cache to go bad and produce this error. We've
fixed that with 1.2M2 so it shouldn't occur as much.
The steps to clear the cache are:
1) Open a Ve and then close it. Have no other VE's open.
2) Do Project->Clean...->Clean All. Wait for build to finish
3) Open your VE. It should now be ok.
Rich Kulp
Re: NullPointerException when creating a new Visual class [message #121037 is a reply to message #120959] Wed, 29 March 2006 03:35 Go to previous message
Thanks, Kulp. It seems working ok now.
Re: NullPointerException when creating a new Visual class [message #612373 is a reply to message #120959] Tue, 28 March 2006 14:05 Go to previous message
Rich Kulp
Re: NullPointerException when creating a new Visual class [message #612377 is a reply to message #120959] Wed, 29 March 2006 03:35 Go to previous message
Previous Topic:Cant have VE working
Next Topic:custom component not displayed correctly
Current Time: Sun Jul 13 17:24:12 EDT 2025
Powered by FUDForum. Page generated in 0.25374 seconds
