NullPointerException when creating a new Visual class [message #120959] |
Tue, 28 March 2006 03:15  |
Originally posted by: luchuan.radvision.com
<b>Hi,
Also I could create a new Visual class, the following error's reported inside the ".log". Before this happens, I used to solve a problem of "IWAV0168E", which had been commonly reported. The process was like "delete the error log -> clean and rebuild the project".</b>
!ENTRY org.eclipse.ve.java.core 4 0 2006-03-28 15:06:52.293
!MESSAGE Exception thrown.
!STACK 0
at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedSing le(XMLSaveImpl.java:1988)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1215)
at org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
at org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1357)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$2.doRun(JavaSourceTranslator.java:922)
at org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
<b>Pls help, thanks a lot.
Luchuan</b>
Re: NullPointerException when creating a new Visual class [message #612373 is a reply to message #120959] |
Tue, 28 March 2006 14:05  |
First, is this a pre 1.2M2 VE driver? If so, we had a cache race
condition which caused the cache to go bad and produce this error. We've
fixed that with 1.2M2 so it shouldn't occur as much.
The steps to clear the cache are:
1) Open a Ve and then close it. Have no other VE's open.
2) Do Project->Clean...->Clean All. Wait for build to finish
3) Open your VE. It should now be ok.
Rich Kulp
FUDForum. Page generated in 0.05083 seconds
