Home » Archived » Koneki » Property selection with the DM simulator & FUMO
Property selection with the DM simulator & FUMO [message #906780] Sun, 02 September 2012 10:35 Go to next message
I'm using the Koneki DM simulator with the Funambol DM server and everything works fine, except the work with parameters.
For example the command
GET ./DevDetail?prop=Name
should return the name of the DevDetail node.
Another parameter which doesn't work would be
GET ./DevDetail?list=StructData
which should return all the leaf nodes including their data.
Does Koneki not support these parameter works or am I using them wrong?
What I would love would be a support of the access control list (ACL).
More about the parameters can be found here:
h**p://www.openmobilealliance.org/Technical/release_program/docs/copyrightclick.aspx?pck=DM&file=V1_2_1-20080617-A/OMA-TS-DM_TND-V1_2_1-20080617-A.pdf in chapter 7.
And my second question:
Is there a way to use FUMO without generating all the needed nodes manually? It would be great if there was an automatic way to set up all the needed nodes so all you had to do would be an EXEC.
Best regards
Brandon
Re: Property selection with the DM simulator & FUMO [message #907266 is a reply to message #906780] Mon, 03 September 2012 12:21 Go to previous messageGo to next message
[Updated on: Tue, 04 September 2012 04:18] by Moderator
Re: Property selection with the DM simulator & FUMO [message #907269 is a reply to message #906780] Mon, 03 September 2012 12:21 Go to previous messageGo to next message
Re: Property selection with the DM simulator & FUMO [message #907272 is a reply to message #906780] Mon, 03 September 2012 12:30 Go to previous message
Hi Brandon,
1#
Actually the simulator doesn't support those metadata GET/REPLACE operation. IIRC it's optional in the OMA-DM standard for clients.
It's not a huge feature to implement. Benjamin can probably help you if you feel like providing a patch for adding this feature Smile
2#
If you don't want to recreate FUMO node all the time you can simply save the XML bits (edit the simulation in plain text) and insert them in your new simulation.
HTH
Julien
Next Topic:Bugs of OMA DM simulator ver 0.8
Current Time: Sun Nov 02 09:45:05 EST 2025
Powered by FUDForum. Page generated in 0.05796 seconds
