Cant have VE working [message #120898] |
Mon, 27 March 2006 09:32  |
Originally posted by: adoneborione.gmail.com
I did following operations, please tell me what I did wrong or what I am
missing:
Unzipped VE files in the same folder where eclipse is
Ran eclipse
Create a Java project
file -> new -> Visual Class???
Well, I can`t see the visual class option. I can't see nowhere VE hues in
the eclipse environment. Only help files are there, but I can't figure out
how to get VE working.
Please Help!
Re: Cant have VE working [message #120994 is a reply to message #120941] |
Tue, 28 March 2006 14:02  |
You shouldn't of had to download JEM because JEM is a part of VE and
should of come with the VE.
To create a visual class you use the New->Other->Java->Visual Class. To
open a java visual class that was never opened using the VE, use Open
with->Visual Editor to open with the VE.
Rich Kulp
Re: Cant have VE working [message #612362 is a reply to message #120898] |
Mon, 27 March 2006 10:25  |
Did you also install the required versions of GEF and EMF? Are you sure
the version of VE you installed is compatible with the version of
Eclipse you're using?
- Jeff
Re: Cant have VE working [message #612363 is a reply to message #120898] |
Mon, 27 March 2006 10:27  |
Did you include the pre-reqs? The download page has a big section at the
top indicating you need the pre-reqs. Did you get the required EMF and
GEF builds that go with the download?
> missing:
> Ran eclipse
> in the eclipse environment. Only help files are there, but I can't
> figure out how to get VE working.
> Please Help!
> Thanks
Rich Kulp
Re: Cant have VE working [message #612364 is a reply to message #120907] |
Mon, 27 March 2006 12:34  |
Uhmm.... really not. Can you send a link where to read such information?
I am using VE 1.1.0.1, eclipse 3.1.2
Adone
> - Jeff
Re: Cant have VE working [message #612365 is a reply to message #120916] |
Mon, 27 March 2006 12:36  |
Really not. Thanks for the information, I will do the thing I should do at
the beginnign: READ THE MANUAL FIRST!
>> missing:
>> Ran eclipse
>> Please Help!
>> Thanks
Re: Cant have VE working [message #612366 is a reply to message #120907] |
Mon, 27 March 2006 19:23  |
Originally posted by: adoneborione.cantv.netNOSPAM
Hello
I ran update manager from inside eclipse and it asked me to download jem
library (do not really know what is it) and EMF
It didn't ask me to download GEF which I downloaded directly from the
website.
Now, what's next? I run eclipse but I do not see how to create a visual
class (??)
I will appreciate so much your help (Sorry, I come from the JBuilder
environment and there things were a little easier, install and that's it :)
> - Jeff
Re: Cant have VE working [message #612372 is a reply to message #120941] |
Rich Kulp
FUDForum. Page generated in 0.22539 seconds
