Home » Archived » Visual Editor (VE) » Can't resize JFrame in VE
Can't resize JFrame in VE [message #120812] Wed, 22 March 2006 21:24 Go to next message
Originally posted by: demshoes.bridgerunner.com
Something has happened seemingly out of the blue. I have a number of
projects
that have visual classes created in VE. Suddenly the design window shows
the
main frame quite small in all projects. Though the resizing handles are
shown
I cannot expand the frames. If I try to do so holding the control key the
frame
disappears completely. I have tried setting the minimum size, preferred
size,
etc. but nothing solves the problem. When I run the application the frame
and
components display correctly. Is there some universal setting in VE that
caused
this to happen? I use absolute positioning in some of the projects and a
layout
manager in others. What gives?
Re: Can't resize JFrame in VE [message #120829 is a reply to message #120812] Thu, 23 March 2006 09:30 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Do you have anything unusual in the .log file in your workspace's
..metadata directory? You may also try Project->Clean->Clean All and
reopening the file. If that doesn't work, try opening a new workspace
and see if you get the same behavior there.
Hope this helps,
- Jeff
Re: Can't resize JFrame in VE [message #120833 is a reply to message #120829] Thu, 23 March 2006 14:44 Go to previous message
'Cleaning' all projects and rebuilding solved the problem.
Re: Can't resize JFrame in VE [message #612350 is a reply to message #120812] Thu, 23 March 2006 09:30 Go to previous message
Hope this helps,
- Jeff
Re: Can't resize JFrame in VE [message #612351 is a reply to message #120829] Thu, 23 March 2006 14:44 Go to previous message
Previous Topic:GoupLayout would be integreted into Mustang
Next Topic:How does the VE get invoked
Current Time: Mon Jul 14 15:43:15 EDT 2025
Powered by FUDForum. Page generated in 0.04309 seconds
