Unable to deploy stardust in weblogic 10.3.3 [message #905846] |
Fri, 31 August 2012 07:29 |
gayatri devi Messages: 7 Registered: August 2012 |
I am trying to deploy stardust in weblogic 10.3.3, I getting following issue
software
Eclipse Helios R2
Weblogic 10.3.3
1) Running Using Eclipse adapter server
-> created sample dynamic project added stardust portal
-> Added Oracle weblogic server tool to eclipse server & did all configuration
-> Right click on project and try to run as "Run on server"
Getting following issue
Error with publish task 'Split Source Mapping Generation Task'.
Error processing split source mapping:
'C:/D/tutorial/weblogic/TestStardust/carnot-jackrabbit/WEB-INF'='/WEB-INF'
WebLogic split source deployment only supports resource folder mapping to EAR or web content root.
Please change the deployment mode to exploded archive in Server Editor.
[/color]
2)Running weblogic console individually
->created sample dynamic project added stardust portal in eclipse
-> Exported as war file
-> Deployed in server
getting following issue.
There was a failure when processing annotations for application stardust.war.
Class not found exception .
com.infinity.bpm.rt.impl.api.ws.servlet.IppWsServlet
Please help on this...
[Updated on: Fri, 31 August 2012 09:05] Report message to a moderator
Re: Unable to deploy stardust in weblogic 10.3.3 [message #905909 is a reply to message #905846] |
Fri, 31 August 2012 09:45 |
Gayatri
the WTP weblogic plugin seems not to be compatible with the Stardust WTP project.
You could either
a) create a WAR file based on the maven archetype for weblogic:
(https infinity dot sungard dot com)/documentation/ipp/7.0/index.jsp?topic=/org.eclipse.stardust.docs.dev/html/handbooks/installation/ig-maven.html"
Or on the Stardust knowledge base:
"(wiki dot eclipse dot org)/Stardust/Knowledge_Base/Build_and_Change_Management/Maven/Basic_Setup"
or
(for some reason I am not allowed to post links to eclipse web sites anymore)
or
b) Export your dynamic web project as a war (project context menu) which you then adjust as required for a weblogic deployment.
(https infinity dot sungard dot com)/documentation/ipp/7.0/index.jsp?topic=/org.eclipse.stardust.docs.deployment/html/applicationserversetup/weblogic.html
In a Weblogic environment a number of things are different from a tomcat deployment (which is what the RAD environment is based on). That includes JMS, transaction manager, probably the database, Jackrabbit DMS.
Best regards
Robert
[Updated on: Fri, 31 August 2012 10:30] Report message to a moderator
Re: Unable to deploy stardust in weblogic 10.3.3 [message #948981 is a reply to message #947834] |
Thu, 18 October 2012 15:11 |
Gayatri,
by latest Stardust eclipse plugin you used the the nightly eclipse update site?
This build works for you on RAD/Tomcat?
We have not tested the Stardust builds in other deployment scenarios than Spring/Tomcat so far. We will provide archetypes for platforms like Weblogic one we have a maven repository for Stardust. Then we will also test on those platforms. This work is currently in progress.
If you have access to IPP then you can use that weblogic archetype instead of the RAD export for the time being.
Could be a class loading issue. Did you add anything to the WLS default class path?
Best
Robert
FUDForum. Page generated in 0.04097 seconds
