Home » Eclipse Projects » BIRT » can we connect BIRT with any community forum and create the reports
can we connect BIRT with any community forum and create the reports [message #905828] Fri, 31 August 2012 06:49 Go to next message
Sameer Singh is currently offline Sameer SinghFriend
In my company we have a community. So can i connect BIRT Report Designer with that community and create the reports from the information present in the community. Please suggest some solution.
Re: can we connect BIRT with any community forum and create the reports [message #906186 is a reply to message #905828] Fri, 31 August 2012 20:00 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Where is the information stored? Do you have an API or URL to connect
and retrieve data? If so the answer is yes.
Jason
On 8/31/2012 2:49 AM, Sameer Singh wrote:
> Hi
Re: can we connect BIRT with any community forum and create the reports [message #906707 is a reply to message #906186] Sun, 02 September 2012 09:34 Go to previous messageGo to next message
Jason
I want to know which API or URL will use to connect with Community. Information stored as a list in the community.
Re: can we connect BIRT with any community forum and create the reports [message #907012 is a reply to message #906186] Mon, 03 September 2012 06:32 Go to previous messageGo to next message
Jason
Information stored in the community is a sharepoint list.
Re: can we connect BIRT with any community forum and create the reports [message #908015 is a reply to message #907012] Tue, 04 September 2012 14:47 Go to previous messageGo to next message
Sameer
I have not tried this but if you can access a sharepoint list from Java,
like:
http://davidsit.wordpress.com/2010/02/10/reading-a-sharepoint-list-with-java-tutorial/
You should be able to call those same Java Classes from BIRT using a
Scripted Data Source. If the share point list can be accessed using a
Web Service you could also use the BIRT Web Service data source.
Jason
On 9/3/2012 2:32 AM, Sameer Singh wrote:
> Jason
Re: can we connect BIRT with any community forum and create the reports [message #909428 is a reply to message #908015] Fri, 07 September 2012 06:03 Go to previous messageGo to next message
Jason
I tried with to create data source using web service data sources. When i am testing the connection it is showing "ping succeded". But when i am creating data set i am getting this error " WSDLException: faultCode=PARSER_ERROR: Problem parsing 'site_name'.: The prefix "ie" for element "ie:menuitem" is not bound."
Re: can we connect BIRT with any community forum and create the reports [message #909716 is a reply to message #909428] Fri, 07 September 2012 16:30 Go to previous messageGo to next message
Is the web service publicly available? If so can you post it?
Jason
Re: can we connect BIRT with any community forum and create the reports [message #910652 is a reply to message #909716] Mon, 10 September 2012 06:51 Go to previous messageGo to next message
Jason
No it's not a public web service. You can't access the site.
Re: can we connect BIRT with any community forum and create the reports [message #910956 is a reply to message #910652] Mon, 10 September 2012 17:43 Go to previous message
It will be difficult to determine what is wrong without being able to run it. Can you try the example in this dev share entry?
http://www.birt-exchange.org/org/devshare/designing-birt-reports/175-birt-web-services-example/
Jason
Previous Topic:Bug? Tooltip still shows up when series is invisible
Next Topic:The output format of
Current Time: Sat Nov 27 15:29:40 GMT 2021
Powered by FUDForum. Page generated in 0.01984 seconds
