Home » Eclipse Projects » EclipseLink » Proper EntityManger in multi-thread App(Is there a proper procedure for using entity managers in a multi-thread application.)
Proper EntityManger in multi-thread App [message #905141] Wed, 29 August 2012 19:38 Go to next message
Chad Curtis is currently offline Chad CurtisFriend
Is it better to have an entity manager per thread, when shared cache is off, or only open and close an entity manager when you write to the database? This comes from the ConcurrancyManager.acquire() method hanging, for what i can tell is no valid reason. Would separate entity managers per thread solve this?
Re: Proper EntityManger in multi-thread App [message #905333 is a reply to message #905141] Thu, 30 August 2012 07:31 Go to previous messageGo to next message
Tom Eugelink is currently offline Tom EugelinkFriend
AFAIK an EM is not thread save, so if multiple threads are accessing the same EM, you should either synchronize them, or use separate EM's for each thread.
Re: Proper EntityManger in multi-thread App [message #908652 is a reply to message #905333] Wed, 05 September 2012 18:33 Go to previous message
Thanks for the advice, I went with multiple entity mangers.
Previous Topic:jboss tools hibernate is getting error while installing @ eclipse indigo sr2
Next Topic:Eclipselink 2.3.2 + composite persistence units + bean validation (jsr303)
Current Time: Sat Oct 31 19:39:48 GMT 2020
Powered by FUDForum. Page generated in 0.01902 seconds
