How to prevent Hudson from entering Shutdown mode automatically or when idle? [message #905084] |
Wed, 29 August 2012 16:47 |
Greg Kraft Messages: 3 Registered: August 2012 |
After several months of successful and unadulterated continuous integration, my Hudson instance decides it wants to enter shutdown mode after every 20-30 minutes of inactivity.
For those of you familiar with shutdown mode, the instance of course doesn't shutdown, but has the undesirable effect (in this case) of stopping new jobs from starting.
I know I haven't changed any settings, so it makes me think the problem was slowly growing and keeps triggering shutdown mode.
I know there is plenty of storage space on the machine with 400+ GB to go so I'm wondering what else would trigger shutdown mode without actually using the Hudson web portal to manually do it.
As mentioned before, the problem also seems to be tied to inactivity. I tried creating a quick fix, which is a build job that does nothing every 5 minutes. It appeared to work at first, but after long periods of inactivity I will find it back in shutdown mode.
Any ideas what might be going on?
[Updated on: Wed, 29 August 2012 16:48] Report message to a moderator
Re: How to prevent Hudson from entering Shutdown mode automatically or when idle? [message #911760 is a reply to message #911716] |
Wed, 12 September 2012 09:15 |
According to the documentation for the thinBackup plugin there is actual reason for entering shutdown mode. When a backup is scheduled, the hudson instance will enter something called a "quiet-mode" or the shutdown mode you were seeing. The reason for this is because the plugin wants to perform a backup when there are no jobs being executed. If you are executing several jobs at backup time, there could be a small issue with that where it will try to back up a file that's currently being written to.
* @author Steven Christou
* @dev Hudson-ci
FUDForum. Page generated in 0.03729 seconds
