Re: Missing 'Build Path' menue item [message #904989 is a reply to message #904858] |
Wed, 29 August 2012 14:16   |
On 8/29/2012 3:32 AM, Dirk Ulrich wrote:
> Hello.
> When clicking on the context menue of a project usually a menue item
> Build Path appears.
> Somehow it happened that this menue item disappeared.
> When I create a completely new Java project this menue item is
> displayed. How can I achieve that this menue point is displayed again
> with existing projects?
> Thank you.
Context is dependent upon what perspective you're in as well as which
file or other object you right-click on. If you're in the Java or Java
EE perspective and you right-click on your project (at top of all
project contents), do you not see Build Path? Do you know and can you
tell what perspective you're in?
Re: Missing 'Build Path' menue item [message #905070 is a reply to message #905062] |
Wed, 29 August 2012 16:21  |
On 8/29/2012 10:03 AM, Dirk Ulrich wrote:
> [snip]
> Do YOU see the Build Path menue item in the Java EE perspective??
Yes. It wouldn't be very helpful if I didn't. I hope someone more
knowledgeable will be able to explain why you cannot and what to do
about it.
FUDForum. Page generated in 0.02664 seconds
