Global AdapterFactory vs one per each EditingDomain [message #904383] |
Tue, 28 August 2012 10:59 |
Sorin Fagateanu Messages: 46 Registered: July 2009 |
Member |
What are the differences of using the same instance of an AdapterFactory with all loaded EditingDomains over using an AdapterFactory per each loaded EditingDomain?
The first difference that comes to my mind is that when using a global AdapterFactory, only a single set of item providers exist whereas using one per each EditingDomain would result in a set of item providers for each domain.
Is the performance (memory, speed) of the overall EMF mechanism affected in any way by using a global instance?
What are the other important/notable differences?
Thank you in advance,
Sorin.
[Updated on: Tue, 28 August 2012 11:02] Report message to a moderator
FUDForum. Page generated in 0.01529 seconds
