Re: Problem charting datetime [message #904615 is a reply to message #904363] |
Tue, 28 August 2012 20:29 |
James
Can you post an image of the issue?
Jason
On 8/28/2012 6:23 AM, James Whitehead wrote:
> I've created an oda to query and read responses from a webservice. I can
> get back dates in the results. I parse these results via:
> return new java.sql.Timestamp(time.parse(sourceData.get(m_currentRowId -
> 1).get(index - 1)).getTime())
> (m_currentRowId and index point to where in my sourcedata the date is.)
> This produces a list of dates such as:
> 29 Jan 2012 20:40 27 Jan 2012 23:01 27 Jan 2012 21:53 29 Jan 2012 14:54
> 28 Jan 2012 09:05 27 Jan 2012 21:47 27 Jan 2012 19:45 30 Jan 2012 17:27
> 29 Jan 2012 12:09 28 Jan 2012 14:11
> When I chart this using date time, grouping by day, a Jan 27th bar
> appears twice and Jan 28th not at all. By looking at the size of the bar
> chart I can tell it is thinking some of the 27th Jan are the same as
> 28th Jan and labelling this 27th Jan. There is then another bar of the
> rest of 27th Jan.
> When I set the column type as Date (so all the times are the same) this
> problem does not occur.
> Any ideas to why this is happening?
> James
Re: Problem charting datetime [message #905042 is a reply to message #904859] |
Wed, 29 August 2012 15:29 |
James
I am trying to recreate the issue, but it does not look like the dates
are the same in the xls sheet. BTW do you have aggregration on the
x-axis disabled? Is the x-axis type set to date time? What are you
using for the y-axis values?
Jason
On 8/29/2012 5:32 AM, James Whitehead wrote:
> Hi Jason,
> The print screen was taken of charts using 2 datasources based on identical data and set up, with the only difference being I changed the output column type to from date time to date.
> I have also uploaded an excel file of the results shown in Preview results for each (thery are in random order but are the same data points).
> Thanks for your help,
> James
Re: Problem charting datetime [message #905074 is a reply to message #905052] |
Wed, 29 August 2012 16:27 |
James
I dumped your dates to a csv and I get the exact same charts when I
change the x and y values to be date or datetime. Are you setting the
data types in the oda correctly?
Jason
On 8/29/2012 11:42 AM, James Whitehead wrote:
> The data may be shuffled up but the dates are the same (if you get excel
> to sort them into order using data->sort then you should see they match
> up, with just the time being different.
> The x-axis is set to group type: date time, unit: days, interval: 1,
> aggregate expression: count
> y is set to date again but aggregated by count.
> Thanks for your help, I have no idea what is going on.
Re: Problem charting datetime [message #905598 is a reply to message #905480] |
Thu, 30 August 2012 17:56 |
James
I am not sure what is happening with this. In one oda I worked on I
stored all dates as Java date millis using get time and when I need to
convert I did:
public Timestamp getTimestamp( int index ) throws OdaException
try{
return new Timestamp(Long.parseLong( getString( index ) ));
}catch (Exception e){
return null;
Did you try storing the dates in a csv file. Then create the report
off the csv. I would like you to try this to verify you get the same
results as I did.
Jason
On 8/30/2012 9:05 AM, James Whitehead wrote:
> I am setting them via the code fragments:
> public Timestamp getTimestamp(int index) throws OdaException {
> try {
> //retured as sql since this is what this class is required
> to return to BIRT
> return new
> 1).get(index - 1)).getTime());
> } catch (ParseException e) {
> e.printStackTrace();
> return null;
> and
> public int getColumnType(int index) throws OdaException {
> String columnName = sourceData.get(0).get(index - 1);
> if (columnName.equalsIgnoreCase("DocID") ||
> columnName.equalsIgnoreCase("ShardID")) {
> return java.sql.Types.INTEGER;
> if (columnName.equalsIgnoreCase("ImportID")) {
> return java.sql.Types.BIGINT;
> if (columnName.equalsIgnoreCase("Score")) {
> return java.sql.Types.DOUBLE;
> } if (columnName.equalsIgnoreCase("Date")) {
> return java.sql.Types.TIMESTAMP;
> else {
> return java.sql.Types.CHAR;
> It is showing up as date time in the output column window of the data
> set, so it seems as though it is set properly...
Re: Problem charting datetime [message #906108 is a reply to message #905935] |
Fri, 31 August 2012 16:26 |
Can you send me a report with the csv that shows the issue?
Jason
On 8/31/2012 6:35 AM, James Whitehead wrote:
> I just tried this with a fresh install of eclipse and BIRT and still
> have the same problem..
Re: Problem charting datetime [message #908020 is a reply to message #907048] |
Tue, 04 September 2012 14:50 |
James
For some reason I can not read the report. Can you zip it an the data
and email to me at jasonweathersby at windstream dot net?
Jason
On 9/3/2012 4:03 AM, James Whitehead wrote:
> Hi, I have included my .csv too.
> James
FUDForum. Page generated in 0.04186 seconds
